RTEMS
5.1
bsps
powerpc
include
libcpu
byteorder.h
1
2
* byteorder.h
3
4
* This file contains inline implementation of function to
5
* deal with endian conversion.
6
7
* It is a stripped down version of linux ppc file...
8
9
* Copyright (C) 1999 Eric Valette (valette@crf.canon.fr)
10
* Canon Centre Recherche France.
11
12
* The license and distribution terms for this file may be
13
* found in the file LICENSE in this distribution or at
14
* http://www.rtems.org/license/LICENSE.
15
16
17
#ifndef _LIBCPU_BYTEORDER_H
18
#define _LIBCPU_BYTEORDER_H
19
20
#ifdef __cplusplus
21
extern
"C"
22
#endif
23
24
static
inline
unsigned
ld_le16(
volatile
uint16_t *addr)
25
26
unsigned
val;
27
28
__asm__
volatile
"lhbrx %0,0,%1"
"=r"
(val) :
"r"
(addr),
"m"
(*addr));
29
return
val;
30
31
32
static
inline
void
st_le16(
volatile
uint16_t *addr,
unsigned
val)
33
34
__asm__
volatile
"sthbrx %1,0,%2"
"=m"
(*addr) :
"r"
(val),
"r"
(addr));
35
36
37
static
inline
unsigned
ld_le32(
volatile
uint32_t *addr)
38
39
unsigned
val;
40
41
__asm__
volatile
"lwbrx %0,0,%1"
"=r"
(val) :
"r"
(addr),
"m"
(*addr));
42
return
val;
43
44
45
static
inline
void
st_le32(
volatile
uint32_t *addr,
unsigned
val)
46
47
__asm__
volatile
"stwbrx %1,0,%2"
"=m"
(*addr) :
"r"
(val),
"r"
(addr));
48
49
50
#ifdef __cplusplus
51
52
#endif
53
54
#endif
/* _LIBCPU_BYTEORDER_H */
__asm__
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
