RTEMS
5.1
bsps
powerpc
include
bsp
pci.h
1
2
* PCI defines and function prototypes
3
4
* For more information, please consult the following manuals (look at
5
* http://www.pcisig.com/ for how to get them):
6
7
* PCI BIOS Specification
8
* PCI Local Bus Specification
9
* PCI to PCI Bridge Specification
10
* PCI System Design Guide
11
12
13
14
* Copyright 1994, Drew Eckhardt
15
* Copyright 1997, 1998 Martin Mares <mj@atrey.karlin.mff.cuni.cz>
16
17
18
#ifndef BSP_POWERPC_PCI_H
19
#define BSP_POWERPC_PCI_H
20
21
rtems/pci.h
22
24
struct
_pin_routes
25
26
int
pin;
27
int
int_name[4];
28
29
struct
_int_map
30
31
int
bus;
32
int
slot;
33
int
opts;
34
struct
_pin_routes
pin_route[5];
35
36
37
/* If there's a conflict between a name in the routing table and
38
* what's already set on the device, reprogram the device setting
39
* to reflect int_name[0] for the routing table entry
40
41
#define PCI_FIXUP_OPT_OVERRIDE_NAME (1<<0)
42
43
44
* This is assumed to be provided by the BSP.
45
46
void
detect_host_bridge(
void
47
48
void
FixupPCI(
const
struct
_int_map
int
(*swizzler)(
int
int
49
50
/* FIXME: This probably belongs into rtems/pci.h */
51
extern
unsigned
char
pci_bus_count(
void
52
53
/* FIXME: This also is generic and could go into rtems/pci.h */
54
55
/* Scan pci config space and run a user callback on each
56
* device present; the user callback may return 0 to
57
* continue the scan or a value > 0 to abort the scan.
58
* Return values < 0 are reserved and must not be used.
59
60
* RETURNS: a (opaque) handle pointing to the bus/slot/fn-triple
61
* just after where the scan was aborted by a callback
62
* returning 1 (see above) or NULL if all devices were
63
* scanned.
64
* The handle may be passed to this routine to resume the
65
* scan continuing with the device after the one causing the
66
* abort.
67
* Pass a NULL 'handle' argument to start scanning from
68
* the beginning (bus/slot/fn = 0/0/0).
69
70
typedef
void
*BSP_PciScanHandle;
71
typedef
int (*BSP_PciScannerCb)(
int
bus,
int
slot,
int
fun,
void
*uarg);
72
73
BSP_PciScanHandle
74
BSP_pciScan(BSP_PciScanHandle handle, BSP_PciScannerCb cb,
void
*uarg);
75
76
/* Dump basic config. space info to a file. The argument may
77
* be NULL in which case 'stdout' is used.
78
* NOTE: the C-library must be functional before you can use
79
* this routine.
80
81
void
82
BSP_pciConfigDump(FILE *
fp
83
84
#endif
/* BSP_POWERPC_PCI_H */
fp
#define fp
frame-pointer */
Definition:
regs.h:65
_int_map
Definition:
pci.h:40
_pin_routes
Definition:
pci.h:36
pci.h
