RTEMS  5.1
irq.h
1 /*===============================================================*\
2 | Project: RTEMS Haleakala BSP |
3 | by Michael Hamel ADInstruments Ltd 2008 |
4 +-----------------------------------------------------------------+
5 | The license and distribution terms for this file may be |
6 | found in the file LICENSE in this distribution or at |
7 | |
8 | http://www.rtems.org/license/LICENSE. |
9 | |
10 \*===============================================================*/
11
12
13 #ifndef Haleakala_IRQ_IRQ_H
14 #define Haleakala_IRQ_IRQ_H
15
16 /* Implemented for us in bsp_irq_dispatch_list */
17 #define BSP_SHARED_HANDLER_SUPPORT 1
18
19 #include <rtems/irq.h>
20
21 #ifndef ASM
22
23 #include <bsp/irq-default.h>
24
25 #ifdef __cplusplus
26 extern "C" {
27 #endif
28
29  /* Define UIC interrupt numbers; IRQs that cause an external interrupt that needs further decode.
30  These are arbitrary but it makes things easier if they match the CPU interrupt numbers */
31
32  /*
33
34  #define BSP_UIC_UART0_GP (BSP_UIC_IRQ_LOWEST_OFFSET + 0)
35  #define BSP_UIC_UART1 (BSP_UIC_IRQ_LOWEST_OFFSET + 1)
36  #define BSP_UIC_IIC0 (BSP_UIC_IRQ_LOWEST_OFFSET + 2)
37  #define BSP_UIC_ExtMaster (BSP_UIC_IRQ_LOWEST_OFFSET + 3)
38  #define BSP_UIC_PCI (BSP_UIC_IRQ_LOWEST_OFFSET + 4)
39  #define BSP_UIC_DMA0 (BSP_UIC_IRQ_LOWEST_OFFSET + 5)
40  #define BSP_UIC_DMA1 (BSP_UIC_IRQ_LOWEST_OFFSET + 6)
41  #define BSP_UIC_DMA2 (BSP_UIC_IRQ_LOWEST_OFFSET + 7)
42  #define BSP_UIC_DMA3 (BSP_UIC_IRQ_LOWEST_OFFSET + 8)
43  #define BSP_UIC_ENetWU (BSP_UIC_IRQ_LOWEST_OFFSET + 9)
44  #define BSP_UIC_MALSERR (BSP_UIC_IRQ_LOWEST_OFFSET + 10)
45  #define BSP_UIC_MALTXEOB (BSP_UIC_IRQ_LOWEST_OFFSET + 11)
46  #define BSP_UIC_MALRXEOB (BSP_UIC_IRQ_LOWEST_OFFSET + 12)
47  #define BSP_UIC_MALTXDE (BSP_UIC_IRQ_LOWEST_OFFSET + 13)
48  #define BSP_UIC_MALRXDE (BSP_UIC_IRQ_LOWEST_OFFSET + 14)
49  #define BSP_UIC_ENet (BSP_UIC_IRQ_LOWEST_OFFSET + 15)
50  #define BSP_UIC_PCISERR (BSP_UIC_IRQ_LOWEST_OFFSET + 16)
51  #define BSP_UIC_ECCERR (BSP_UIC_IRQ_LOWEST_OFFSET + 17)
52  #define BSP_UIC_PCIPower (BSP_UIC_IRQ_LOWEST_OFFSET + 18)
53  #define BSP_UIC_IRQ0 (BSP_UIC_IRQ_LOWEST_OFFSET + 25)
54  #define BSP_UIC_IRQ1 (BSP_UIC_IRQ_LOWEST_OFFSET + 26)
55  #define BSP_UIC_IRQ2 (BSP_UIC_IRQ_LOWEST_OFFSET + 27)
56  #define BSP_UIC_IRQ3 (BSP_UIC_IRQ_LOWEST_OFFSET + 28)
57  #define BSP_UIC_IRQ4 (BSP_UIC_IRQ_LOWEST_OFFSET + 29)
58  #define BSP_UIC_IRQ5 (BSP_UIC_IRQ_LOWEST_OFFSET + 30)
59  #define BSP_UIC_IRQ6 (BSP_UIC_IRQ_LOWEST_OFFSET + 31)
60
61  #define BSP_UIC_IRQ_NUMBER (32)
62
63  */
64  /* PPC405EX interrupt vectors */
65  #define BSP_UIC_UART1 (BSP_UIC_IRQ_LOWEST_OFFSET + 1)
66  #define BSP_UIC_IIC0 (BSP_UIC_IRQ_LOWEST_OFFSET + 2)
67  #define BSP_UIC_EIPPKP_READY (BSP_UIC_IRQ_LOWEST_OFFSET + 3)
68  #define BSP_UIC_EIPPKP_TRNG (BSP_UIC_IRQ_LOWEST_OFFSET + 4)
69  #define BSP_UIC_EBM (BSP_UIC_IRQ_LOWEST_OFFSET + 5)
70  #define BSP_UIC_OPBtoPLB (BSP_UIC_IRQ_LOWEST_OFFSET + 6)
71  #define BSP_UIC_IIC1 (BSP_UIC_IRQ_LOWEST_OFFSET + 7)
72  #define BSP_UIC_SPI (BSP_UIC_IRQ_LOWEST_OFFSET + 8)
73  #define BSP_UIC_IRQ0 (BSP_UIC_IRQ_LOWEST_OFFSET + 9)
74  #define BSP_UIC_MALTXEOB (BSP_UIC_IRQ_LOWEST_OFFSET + 10)
75  #define BSP_UIC_MALRXEOB (BSP_UIC_IRQ_LOWEST_OFFSET + 11)
76  #define BSP_UIC_DMA0 (BSP_UIC_IRQ_LOWEST_OFFSET + 12)
77  #define BSP_UIC_DMA1 (BSP_UIC_IRQ_LOWEST_OFFSET + 13)
78  #define BSP_UIC_DMA2 (BSP_UIC_IRQ_LOWEST_OFFSET + 14)
79  #define BSP_UIC_DMA3 (BSP_UIC_IRQ_LOWEST_OFFSET + 15)
80  #define BSP_UIC_PCIe0AL (BSP_UIC_IRQ_LOWEST_OFFSET + 16)
81  #define BSP_UIC_PCIe0VPD (BSP_UIC_IRQ_LOWEST_OFFSET + 17)
82  #define BSP_UIC_PCIe0HRst (BSP_UIC_IRQ_LOWEST_OFFSET + 18)
83  #define BSP_UIC_EIPPKP_PKA (BSP_UIC_IRQ_LOWEST_OFFSET + 19)
84  #define BSP_UIC_PCIe0TCR (BSP_UIC_IRQ_LOWEST_OFFSET + 20)
85  #define BSP_UIC_PCIe0VCO (BSP_UIC_IRQ_LOWEST_OFFSET + 21)
86  #define BSP_UIC_EIPPKP_TRNG_AL (BSP_UIC_IRQ_LOWEST_OFFSET + 22)
87  #define BSP_UIC_EIP94 (BSP_UIC_IRQ_LOWEST_OFFSET + 23)
88  #define BSP_UIC_EMAC0 (BSP_UIC_IRQ_LOWEST_OFFSET + 24)
89  #define BSP_UIC_EMAC1 (BSP_UIC_IRQ_LOWEST_OFFSET + 25)
90  #define BSP_UIC_UART0 (BSP_UIC_IRQ_LOWEST_OFFSET + 26)
91  #define BSP_UIC_IRQ4 (BSP_UIC_IRQ_LOWEST_OFFSET + 27)
92  #define BSP_UIC_UIC2_STD (BSP_UIC_IRQ_LOWEST_OFFSET + 28)
93  #define BSP_UIC_UIC2_CRIT (BSP_UIC_IRQ_LOWEST_OFFSET + 29)
94  #define BSP_UIC_UIC1_STD (BSP_UIC_IRQ_LOWEST_OFFSET + 30)
95  #define BSP_UIC_UIC1_CRIT (BSP_UIC_IRQ_LOWEST_OFFSET + 31)
96
97  #define BSP_UIC1_IRQ_LOWEST_OFFSET (BSP_UIC_IRQ_LOWEST_OFFSET + 32)
98  #define BSP_UIC_MALSERR (BSP_UIC1_IRQ_LOWEST_OFFSET + 0)
99  #define BSP_UIC_MALTXDE (BSP_UIC1_IRQ_LOWEST_OFFSET + 1)
100  #define BSP_UIC_MALRXDE (BSP_UIC1_IRQ_LOWEST_OFFSET + 2)
101  #define BSP_UIC_PCIe0DCRErr (BSP_UIC1_IRQ_LOWEST_OFFSET + 3)
102  #define BSP_UIC_PCIe1DCRErr (BSP_UIC1_IRQ_LOWEST_OFFSET + 4)
103  #define BSP_UIC_ExtBus (BSP_UIC1_IRQ_LOWEST_OFFSET + 5)
104  #define BSP_UIC_NDFC (BSP_UIC1_IRQ_LOWEST_OFFSET + 6)
105  #define BSP_UIC_EIPKP_SLAVE (BSP_UIC1_IRQ_LOWEST_OFFSET + 7)
106  #define BSP_UIC_GPT_TIMER5 (BSP_UIC1_IRQ_LOWEST_OFFSET + 8)
107  #define BSP_UIC_GPT_TIMER6 (BSP_UIC1_IRQ_LOWEST_OFFSET + 9)
108
109  #define BSP_UIC_GPT_TIMER0 (BSP_UIC1_IRQ_LOWEST_OFFSET + 16)
110  #define BSP_UIC_GPT_TIMER1 (BSP_UIC1_IRQ_LOWEST_OFFSET + 17)
111  #define BSP_UIC_IRQ7 (BSP_UIC1_IRQ_LOWEST_OFFSET + 18)
112  #define BSP_UIC_IRQ8 (BSP_UIC1_IRQ_LOWEST_OFFSET + 19)
113  #define BSP_UIC_IRQ9 (BSP_UIC1_IRQ_LOWEST_OFFSET + 20)
114  #define BSP_UIC_GPT_TIMER2 (BSP_UIC1_IRQ_LOWEST_OFFSET + 21)
115  #define BSP_UIC_GPT_TIMER3 (BSP_UIC1_IRQ_LOWEST_OFFSET + 22)
116  #define BSP_UIC_GPT_TIMER4 (BSP_UIC1_IRQ_LOWEST_OFFSET + 23)
117  #define BSP_UIC_SERIAL_ROM (BSP_UIC1_IRQ_LOWEST_OFFSET + 24)
118  #define BSP_UIC_GPT_DEC (BSP_UIC1_IRQ_LOWEST_OFFSET + 25)
119  #define BSP_UIC_IRQ2 (BSP_UIC1_IRQ_LOWEST_OFFSET + 26)
120  #define BSP_UIC_IRQ5 (BSP_UIC1_IRQ_LOWEST_OFFSET + 27)
121  #define BSP_UIC_IRQ6 (BSP_UIC1_IRQ_LOWEST_OFFSET + 28)
122  #define BSP_UIC_EMAC0WU (BSP_UIC1_IRQ_LOWEST_OFFSET + 29)
123  #define BSP_UIC_IRQ1 (BSP_UIC1_IRQ_LOWEST_OFFSET + 30)
124  #define BSP_UIC_EMAC1WU (BSP_UIC1_IRQ_LOWEST_OFFSET + 31)
125
126  #define BSP_UIC2_IRQ_LOWEST_OFFSET (BSP_UIC_IRQ_LOWEST_OFFSET + 64)
127  #define BSP_UIC_PCIe0INTA (BSP_UIC2_IRQ_LOWEST_OFFSET + 0)
128  #define BSP_UIC_PCIe0INTB (BSP_UIC2_IRQ_LOWEST_OFFSET + 1)
129  #define BSP_UIC_PCIe0INTC (BSP_UIC2_IRQ_LOWEST_OFFSET + 2)
130  #define BSP_UIC_PCIe0INTD (BSP_UIC2_IRQ_LOWEST_OFFSET + 3)
131  #define BSP_UIC_IRQ3 (BSP_UIC2_IRQ_LOWEST_OFFSET + 4)
132
133  #define BSP_UIC_USBOTG (BSP_UIC2_IRQ_LOWEST_OFFSET + 30)
134
135  #define BSP_UIC_IRQ_NUMBER (95)
136
137
138  #define BSP_UIC_IRQ_LOWEST_OFFSET 0
139  #define BSP_UIC_IRQ_MAX_OFFSET (BSP_UIC_IRQ_LOWEST_OFFSET + BSP_UIC_IRQ_NUMBER - 1)
140
141  #define BSP_UART_COM1_IRQ BSP_UIC_UART0 /* Required by shared/console/uart.c */
142  #define BSP_UART_COM2_IRQ BSP_UIC_UART1
143
144  /* Define processor IRQ numbers; IRQs that are handled by the exception vectors */
145
146  #define BSP_PIT BSP_PROCESSOR_IRQ_LOWEST_OFFSET /* Required by ppc403/clock.c */
147  #define BSP_FIT BSP_PROCESSOR_IRQ_LOWEST_OFFSET + 1
148  #define BSP_WDOG BSP_PROCESSOR_IRQ_LOWEST_OFFSET + 2
149
150  #define BSP_PROCESSOR_IRQ_NUMBER (3)
151  #define BSP_PROCESSOR_IRQ_LOWEST_OFFSET (BSP_UIC_IRQ_MAX_OFFSET + 1)
152  #define BSP_PROCESSOR_IRQ_MAX_OFFSET (BSP_PROCESSOR_IRQ_LOWEST_OFFSET + BSP_PROCESSOR_IRQ_NUMBER - 1)
153
154  /* Summary and totals */
155
156  #define BSP_IRQ_NUMBER (BSP_PROCESSOR_IRQ_MAX_OFFSET + 1)
157  #define BSP_LOWEST_OFFSET (BSP_UIC_IRQ_LOWEST_OFFSET)
158  #define BSP_MAX_OFFSET (BSP_IRQ_NUMBER - 1)
159
160  extern void BSP_rtems_irq_mng_init(unsigned cpuId); // Implemented in irq_init.c
161  #include <bsp/irq_supp.h>
162
163  #ifdef __cplusplus
164  }
165  #endif
166 #endif /* ASM */
167
168 #endif /* Haleakala_IRQ_IRQ_H */
