29 #ifndef LIBBSP_POWERPC_GEN83XX_BSP_H    30 #define LIBBSP_POWERPC_GEN83XX_BSP_H    42 #define BSP_FEATURE_IRQ_EXTENSION    48 #include <bsp/hwreg_vals.h>    54 LINKER_SYMBOL(bsp_ram_start);
    55 LINKER_SYMBOL(bsp_ram_end);
    56 LINKER_SYMBOL(bsp_ram_size);
    58 LINKER_SYMBOL(bsp_rom_start);
    59 LINKER_SYMBOL(bsp_rom_end);
    60 LINKER_SYMBOL(bsp_rom_size);
    62 LINKER_SYMBOL(bsp_section_text_start);
    63 LINKER_SYMBOL(bsp_section_text_end);
    64 LINKER_SYMBOL(bsp_section_text_size);
    66 LINKER_SYMBOL(bsp_section_data_start);
    67 LINKER_SYMBOL(bsp_section_data_end);
    68 LINKER_SYMBOL(bsp_section_data_size);
    70 LINKER_SYMBOL(bsp_section_bss_start);
    71 LINKER_SYMBOL(bsp_section_bss_end);
    72 LINKER_SYMBOL(bsp_section_bss_size);
    74 LINKER_SYMBOL(bsp_work_area_start);
    76 LINKER_SYMBOL(IMMRBAR);
    92 #undef RTEMS_BSP_HAS_IDE_DRIVER    95 #define BSP_ARRAY_CNT(arr) (sizeof(arr)/sizeof(arr[0]))    98 #define BSP_IDLE_TASK_BODY bsp_idle_thread   107 struct rtems_bsdnet_ifconfig;
   108 extern int BSP_tsec_attach(
struct rtems_bsdnet_ifconfig *
config,
int attaching);
   109 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH BSP_tsec_attach   111 #ifdef MPC83XX_BOARD_MPC8313ERDB   112   #define RTEMS_BSP_NETWORK_DRIVER_NAME "tsec2"   113   #define RTEMS_BSP_NETWORK_DRIVER_NAME2 "tsec1"   115   #define RTEMS_BSP_NETWORK_DRIVER_NAME "tsec1"   116   #define RTEMS_BSP_NETWORK_DRIVER_NAME2 "tsec2"   119 #if defined(MPC83XX_BOARD_MPC8349EAMDS)   123 #define RTEMS_BSP_I2C_EEPROM_DEVICE_NAME "eeprom"   124 #define RTEMS_BSP_I2C_EEPROM_DEVICE_PATH "/dev/i2c1.eeprom"   129 #define RTEMS_BSP_SPI_FLASH_DEVICE_NAME "flash"   130 #define RTEMS_BSP_SPI_FLASH_DEVICE_PATH "/dev/spi.flash"   133 #if defined(MPC83XX_BOARD_HSC_CM01)   137 #define RTEMS_BSP_I2C_EEPROM_DEVICE_NAME "eeprom"   138 #define RTEMS_BSP_I2C_EEPROM_DEVICE_PATH "/dev/i2c1.eeprom"   143 #define RTEMS_BSP_SPI_FRAM_DEVICE_NAME "fram"   144 #define RTEMS_BSP_SPI_FRAM_DEVICE_PATH "/dev/spi.fram"   147 extern unsigned int BSP_bus_frequency;
   155 #define BSP_Convert_decrementer( _value ) \   156   ((int) (((_value) * 10) / bsp_clicks_per_usec))   158 void mpc83xx_zero_4(
void *dest,
size_t n);
   160 void cpu_init(
void);
   164 #if defined(HAS_UBOOT)   166   const char *bsp_uboot_getenv(
 Definition: deflate.c:115
uint32_t bsp_clicks_per_usec
Time base clicks per micro second.
Definition: bspstart.c:99
DEFAULT_INITIAL_EXTENSION Support.
General purpose assembler macros, linker command file support and some inline functions for direct re...
rtems_status_code
Classic API Status.
Definition: status.h:43
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
void bsp_restart(const void *addr)
Restarts the bsp with "addr" address.
Definition: restart.c:25
