RTEMS  5.1
irq.h
1 /*===============================================================*\
2 | Project: RTEMS generic MPC83xx BSP |
3 +-----------------------------------------------------------------+
4 | Copyright (c) 2007, 2010 |
5 | Embedded Brains GmbH |
6 | Obere Lagerstr. 30 |
7 | D-82178 Puchheim |
8 | Germany |
9 | rtems@embedded-brains.de |
10 +-----------------------------------------------------------------+
11 | The license and distribution terms for this file may be |
12 | found in the file LICENSE in this distribution or at |
13 | |
14 | http://www.rtems.org/license/LICENSE. |
15 | |
16 +-----------------------------------------------------------------+
17 | this file declares constants of the interrupt controller |
18 \*===============================================================*/
19
20
21 #ifndef GEN83xx_IRQ_IRQ_H
22 #define GEN83xx_IRQ_IRQ_H
23
24 #include <rtems.h>
25 #include <rtems/irq.h>
26 #include <rtems/irq-extension.h>
27
28 #include <bspopts.h>
29
30 /*
31  * the following definitions specify the indices used
32  * to interface the interrupt handler API
33  */
34
35 /*
36  * Peripheral IRQ handlers related definitions
37  */
38 #define BSP_IPIC_PER_IRQ_NUMBER 128
39 #define BSP_IPIC_IRQ_LOWEST_OFFSET 0
40 #define BSP_IPIC_IRQ_MAX_OFFSET (BSP_IPIC_IRQ_LOWEST_OFFSET\
41  +BSP_IPIC_PER_IRQ_NUMBER-1)
42
43 #define BSP_IS_IPIC_IRQ(irqnum) \
44  (((irqnum) >= BSP_IPIC_IRQ_LOWEST_OFFSET) && \
45  ((irqnum) <= BSP_IPIC_IRQ_MAX_OFFSET))
46 /*
47  * Processor IRQ handlers related definitions
48  */
49 #define BSP_PROCESSOR_IRQ_NUMBER 1
50 #define BSP_PROCESSOR_IRQ_LOWEST_OFFSET (BSP_IPIC_IRQ_MAX_OFFSET+1)
51 #define BSP_PROCESSOR_IRQ_MAX_OFFSET (BSP_PROCESSOR_IRQ_LOWEST_OFFSET\
52  +BSP_PROCESSOR_IRQ_NUMBER-1)
53
54 #define BSP_IS_PROCESSOR_IRQ(irqnum) \
55  (((irqnum) >= BSP_PROCESSOR_IRQ_LOWEST_OFFSET) && \
56  ((irqnum) <= BSP_PROCESSOR_IRQ_MAX_OFFSET))
57 /*
58  * Summary
59  */
60 #define BSP_IRQ_NUMBER (BSP_PROCESSOR_IRQ_MAX_OFFSET+1)
61 #define BSP_LOWEST_OFFSET BSP_IPIC_IRQ_LOWEST_OFFSET
62 #define BSP_MAX_OFFSET BSP_PROCESSOR_IRQ_MAX_OFFSET
63
64 #define BSP_IS_VALID_IRQ(irqnum) \
65  (BSP_IS_PROCESSOR_IRQ(irqnum) \
66  || BSP_IS_IPIC_IRQ(irqnum))
67
68 #ifndef ASM
69 #ifdef __cplusplus
70 extern "C" {
71 #endif
72
73 /*
74  * index table for the module specific handlers, a few entries are only placeholders
75  */
76  typedef enum {
77  BSP_IPIC_IRQ_FIRST = BSP_IPIC_IRQ_LOWEST_OFFSET,
78  BSP_IPIC_IRQ_ERROR = BSP_IPIC_IRQ_LOWEST_OFFSET + 0,
79 #if MPC83XX_CHIP_TYPE / 10 == 830
80  BSP_IPIC_IRQ_DMA1 = BSP_IPIC_IRQ_LOWEST_OFFSET + 3,
81  BSP_IPIC_IRQ_UART = BSP_IPIC_IRQ_LOWEST_OFFSET + 9,
82  BSP_IPIC_IRQ_FLEXCAN = BSP_IPIC_IRQ_LOWEST_OFFSET + 10,
83 #else
84  BSP_IPIC_IRQ_UART1 = BSP_IPIC_IRQ_LOWEST_OFFSET + 9,
85  BSP_IPIC_IRQ_UART2 = BSP_IPIC_IRQ_LOWEST_OFFSET + 10,
86  BSP_IPIC_IRQ_SEC = BSP_IPIC_IRQ_LOWEST_OFFSET + 11,
87 #endif
88  BSP_IPIC_IRQ_I2C1 = BSP_IPIC_IRQ_LOWEST_OFFSET + 14,
89  BSP_IPIC_IRQ_I2C2 = BSP_IPIC_IRQ_LOWEST_OFFSET + 15,
90  BSP_IPIC_IRQ_SPI = BSP_IPIC_IRQ_LOWEST_OFFSET + 16,
91  BSP_IPIC_IRQ_IRQ1 = BSP_IPIC_IRQ_LOWEST_OFFSET + 17,
92  BSP_IPIC_IRQ_IRQ2 = BSP_IPIC_IRQ_LOWEST_OFFSET + 18,
93  BSP_IPIC_IRQ_IRQ3 = BSP_IPIC_IRQ_LOWEST_OFFSET + 19,
94 #if MPC83XX_CHIP_TYPE / 10 == 830
95  BSP_IPIC_IRQ_QUICC_HI = BSP_IPIC_IRQ_LOWEST_OFFSET + 32,
96  BSP_IPIC_IRQ_QUICC_LO = BSP_IPIC_IRQ_LOWEST_OFFSET + 33,
97 #else
98  BSP_IPIC_IRQ_IRQ4 = BSP_IPIC_IRQ_LOWEST_OFFSET + 20,
99  BSP_IPIC_IRQ_IRQ5 = BSP_IPIC_IRQ_LOWEST_OFFSET + 21,
100  BSP_IPIC_IRQ_IRQ6 = BSP_IPIC_IRQ_LOWEST_OFFSET + 22,
101  BSP_IPIC_IRQ_IRQ7 = BSP_IPIC_IRQ_LOWEST_OFFSET + 23,
102  BSP_IPIC_IRQ_TSEC1_TX = BSP_IPIC_IRQ_LOWEST_OFFSET + 32,
103  BSP_IPIC_IRQ_TSEC1_RX = BSP_IPIC_IRQ_LOWEST_OFFSET + 33,
104  BSP_IPIC_IRQ_TSEC1_ERR = BSP_IPIC_IRQ_LOWEST_OFFSET + 34,
105  BSP_IPIC_IRQ_TSEC2_TX = BSP_IPIC_IRQ_LOWEST_OFFSET + 35,
106  BSP_IPIC_IRQ_TSEC2_RX = BSP_IPIC_IRQ_LOWEST_OFFSET + 36,
107  BSP_IPIC_IRQ_TSEC2_ERR = BSP_IPIC_IRQ_LOWEST_OFFSET + 37,
108 #endif
109  BSP_IPIC_IRQ_USB_DR = BSP_IPIC_IRQ_LOWEST_OFFSET + 38,
110 #if MPC83XX_CHIP_TYPE / 10 == 830
111  BSP_IPIC_IRQ_ESDHC = BSP_IPIC_IRQ_LOWEST_OFFSET + 42,
112 #else
113  BSP_IPIC_IRQ_USB_MPH = BSP_IPIC_IRQ_LOWEST_OFFSET + 39,
114 #endif
115  BSP_IPIC_IRQ_IRQ0 = BSP_IPIC_IRQ_LOWEST_OFFSET + 48,
116  BSP_IPIC_IRQ_RTC_SEC = BSP_IPIC_IRQ_LOWEST_OFFSET + 64,
117  BSP_IPIC_IRQ_PIT = BSP_IPIC_IRQ_LOWEST_OFFSET + 65,
118  BSP_IPIC_IRQ_PCI1 = BSP_IPIC_IRQ_LOWEST_OFFSET + 66,
119 #if MPC83XX_CHIP_TYPE / 10 == 830
120  BSP_IPIC_IRQ_MSIR1 = BSP_IPIC_IRQ_LOWEST_OFFSET + 67,
121 #else
122  BSP_IPIC_IRQ_PCI2 = BSP_IPIC_IRQ_LOWEST_OFFSET + 67,
123 #endif
124  BSP_IPIC_IRQ_RTC_ALR = BSP_IPIC_IRQ_LOWEST_OFFSET + 68,
125  BSP_IPIC_IRQ_MU = BSP_IPIC_IRQ_LOWEST_OFFSET + 69,
126  BSP_IPIC_IRQ_SBA = BSP_IPIC_IRQ_LOWEST_OFFSET + 70,
127  BSP_IPIC_IRQ_DMA = BSP_IPIC_IRQ_LOWEST_OFFSET + 71,
128  BSP_IPIC_IRQ_GTM4 = BSP_IPIC_IRQ_LOWEST_OFFSET + 72,
129  BSP_IPIC_IRQ_GTM8 = BSP_IPIC_IRQ_LOWEST_OFFSET + 73,
130 #if MPC83XX_CHIP_TYPE / 10 == 830
131  BSP_IPIC_IRQ_QUICC_PORTS = BSP_IPIC_IRQ_LOWEST_OFFSET + 74,
132  BSP_IPIC_IRQ_GPIO = BSP_IPIC_IRQ_LOWEST_OFFSET + 75,
133 #else
134  BSP_IPIC_IRQ_GPIO1 = BSP_IPIC_IRQ_LOWEST_OFFSET + 74,
135  BSP_IPIC_IRQ_GPIO2 = BSP_IPIC_IRQ_LOWEST_OFFSET + 75,
136 #endif
137  BSP_IPIC_IRQ_DDR = BSP_IPIC_IRQ_LOWEST_OFFSET + 76,
138  BSP_IPIC_IRQ_LBC = BSP_IPIC_IRQ_LOWEST_OFFSET + 77,
139  BSP_IPIC_IRQ_GTM2 = BSP_IPIC_IRQ_LOWEST_OFFSET + 78,
140  BSP_IPIC_IRQ_GTM6 = BSP_IPIC_IRQ_LOWEST_OFFSET + 79,
141  BSP_IPIC_IRQ_PMC = BSP_IPIC_IRQ_LOWEST_OFFSET + 80,
142 #if MPC83XX_CHIP_TYPE / 10 == 830
143  BSP_IPIC_IRQ_MSIR2 = BSP_IPIC_IRQ_LOWEST_OFFSET + 81,
144  BSP_IPIC_IRQ_MSIR3 = BSP_IPIC_IRQ_LOWEST_OFFSET + 82,
145 #else
146  BSP_IPIC_IRQ_GTM3 = BSP_IPIC_IRQ_LOWEST_OFFSET + 84,
147  BSP_IPIC_IRQ_GTM7 = BSP_IPIC_IRQ_LOWEST_OFFSET + 85,
148 #endif
149 #if MPC83XX_CHIP_TYPE / 10 == 830
150  BSP_IPIC_IRQ_MSIR4 = BSP_IPIC_IRQ_LOWEST_OFFSET + 86,
151  BSP_IPIC_IRQ_MSIR5 = BSP_IPIC_IRQ_LOWEST_OFFSET + 87,
152  BSP_IPIC_IRQ_MSIR6 = BSP_IPIC_IRQ_LOWEST_OFFSET + 88,
153  BSP_IPIC_IRQ_MSIR7 = BSP_IPIC_IRQ_LOWEST_OFFSET + 89,
154 #endif
155  BSP_IPIC_IRQ_GTM1 = BSP_IPIC_IRQ_LOWEST_OFFSET + 90,
156  BSP_IPIC_IRQ_GTM5 = BSP_IPIC_IRQ_LOWEST_OFFSET + 91,
157 #if MPC83XX_CHIP_TYPE / 10 == 830
158  BSP_IPIC_IRQ_DMA1_ERR = BSP_IPIC_IRQ_LOWEST_OFFSET + 94,
159  BSP_IPIC_IRQ_DPTC = BSP_IPIC_IRQ_LOWEST_OFFSET + 95,
160 #endif
161
162  BSP_IPIC_IRQ_LAST = BSP_IPIC_IRQ_MAX_OFFSET,
163  } rtems_irq_symbolic_name;
164
165 #define BSP_INTERRUPT_VECTOR_MIN BSP_LOWEST_OFFSET
166
167 #define BSP_INTERRUPT_VECTOR_MAX BSP_MAX_OFFSET
168
169 rtems_status_code mpc83xx_ipic_set_mask( rtems_vector_number vector, rtems_vector_number mask_vector, bool mask);
170
171 #define MPC83XX_IPIC_INTERRUPT_NORMAL 0
172
173 #define MPC83XX_IPIC_INTERRUPT_SYSTEM 1
174
175 #define MPC83XX_IPIC_INTERRUPT_CRITICAL 2
176
177 rtems_status_code mpc83xx_ipic_set_highest_priority_interrupt( rtems_vector_number vector, int type);
178
179 #ifdef __cplusplus
180 }
181 #endif
182 #endif /* ASM */
183
184 #endif /* GEN83XX_IRQ_IRQ_H */
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_status_code
Classic API Status.
Definition: status.h:43
Header file for the Interrupt Manager Extension.
