RTEMS  5.1
bsp.h
1
9 /*===============================================================*\
10 | Project: RTEMS generic MPC5200 BSP |
11 +-----------------------------------------------------------------+
12 | Partially based on the code references which are named below. |
13 | Adaptions, modifications, enhancements and any recent parts of |
14 | the code are: |
15 | Copyright (c) 2005 |
16 | Embedded Brains GmbH |
17 | Obere Lagerstr. 30 |
18 | D-82178 Puchheim |
19 | Germany |
20 | rtems@embedded-brains.de |
21 +-----------------------------------------------------------------+
22 | The license and distribution terms for this file may be |
23 | found in the file LICENSE in this distribution or at |
24 | |
25 | http://www.rtems.org/license/LICENSE. |
26 | |
27 +-----------------------------------------------------------------+
28 | this file contains board specific definitions |
29 \*===============================================================*/
30
31 #ifndef LIBBSP_POWERPC_GEN5200_BSP_H
32 #define LIBBSP_POWERPC_GEN5200_BSP_H
33
44 #include <bspopts.h>
45
46 #include <libcpu/powerpc-utility.h>
47
48 /*
49  * Some symbols defined in the linker command file.
50  */
51
52 LINKER_SYMBOL(bsp_ram_start);
53 LINKER_SYMBOL(bsp_ram_end);
54 LINKER_SYMBOL(bsp_ram_size);
55
56 LINKER_SYMBOL(bsp_rom_start);
57 LINKER_SYMBOL(bsp_rom_end);
58 LINKER_SYMBOL(bsp_rom_size);
59
60 LINKER_SYMBOL(bsp_dpram_start);
61 LINKER_SYMBOL(bsp_dpram_end);
62 LINKER_SYMBOL(bsp_dpram_size);
63
64 LINKER_SYMBOL(bsp_section_text_start);
65 LINKER_SYMBOL(bsp_section_text_end);
66 LINKER_SYMBOL(bsp_section_text_size);
67
68 LINKER_SYMBOL(bsp_section_data_start);
69 LINKER_SYMBOL(bsp_section_data_end);
70 LINKER_SYMBOL(bsp_section_data_size);
71
72 LINKER_SYMBOL(bsp_section_bss_start);
73 LINKER_SYMBOL(bsp_section_bss_end);
74 LINKER_SYMBOL(bsp_section_bss_size);
75
76 LINKER_SYMBOL(bsp_work_area_start);
77
78 LINKER_SYMBOL(MBAR);
79
80 /* Provide legacy defines */
81
82 #ifdef MPC5200_BOARD_PM520_ZE30
83 #define PM520_ZE30
84 #endif
85
86 #ifdef MPC5200_BOARD_PM520_CR825
87 #define PM520_CR825
88 #endif
89
90 #ifdef MPC5200_BOARD_ICECUBE
91 #define icecube
92 #endif
93
94 #ifdef MPC5200_BOARD_BRS5L
95 #define BRS5L
96 #endif
97
98 /*
99  * distinguish board characteristics
100  */
101 /*
102  * for PM520 mdule on a ZE30 carrier
103  */
104 #if defined(MPC5200_BOARD_PM520_ZE30)
105 #define PM520
106 #endif
107 /*
108  * for PM520 mdule on a CR825 carrier
109  */
110 #if defined(MPC5200_BOARD_PM520_CR825)
111 #define PM520
112 #endif
113
114 #if !defined(HAS_UBOOT)
115  /* we need the low level initialization in start.S*/
116  #define NEED_LOW_LEVEL_INIT
117 #endif
118
119 #if defined(MPC5200_BOARD_BRS5L)
120 /*
121  * IMD Custom Board BRS5L
122  */
123
124 #define HAS_NVRAM_93CXX
125
126 #elif defined(MPC5200_BOARD_BRS6L)
127  #define MPC5200_BRS6L_FPGA_BEGIN 0x800000
128  #define MPC5200_BRS6L_FPGA_SIZE (64 * 1024)
129  #define MPC5200_BRS6L_FPGA_END \
130  (MPC5200_BRS6L_FPGA_BEGIN + MPC5200_BRS6L_FPGA_SIZE)
131
132  #define MPC5200_BRS6L_MRAM_BEGIN 0xff000000
133  #define MPC5200_BRS6L_MRAM_SIZE (4 * 1024 * 1024)
134  #define MPC5200_BRS6L_MRAM_END \
135  (MPC5200_BRS6L_MRAM_BEGIN + MPC5200_BRS6L_MRAM_SIZE)
136 #elif defined (PM520)
137
138 /* Nothing special */
139
140 #elif defined (MPC5200_BOARD_ICECUBE)
141 /*
142  * Codename: IceCube
143  * Compatible Boards:
144  * Freescape MPC5200LITE
145  * Embedded Planet EP5200
146  */
147
148 #elif defined (MPC5200_BOARD_DP2)
149
150 /* Nothing special */
151
152 #else
153 #error "board type not defined"
154 #endif
155
156 #ifndef ASM
157
158 #include <rtems.h>
159 #include <bsp/i2cdrv.h>
160 #include <bsp/irq.h>
161 #include <bsp/vectors.h>
162 #include <bsp/u-boot.h>
164
165 #ifdef __cplusplus
166 extern "C" {
167 #endif
168
169 /*
170  * Network driver configuration
171  */
172 struct rtems_bsdnet_ifconfig;
173 extern int rtems_mpc5200_fec_driver_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching);
174 #define RTEMS_BSP_NETWORK_DRIVER_NAME "eth1"
175 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_mpc5200_fec_driver_attach_detach
176
177 /* miscellaneous stuff assumed to exist */
178
179 /*
180  * We need to decide how much memory will be non-cacheable. This
181  * will mainly be memory that will be used in DMA (network and serial
182  * buffers).
183  */
184 /*
185 #define NOCACHE_MEM_SIZE 512*1024
186 */
187
188 /*
189  * Device Driver Table Entries
190  */
191
192 #ifdef HAS_NVRAM_93CXX
193 #define NVRAM_DRIVER_TABLE_ENTRY \
194  { nvram_driver_initialize, nvram_driver_open, nvram_driver_close, \
195  nvram_driver_read, nvram_driver_write, NULL }
196 #endif
197
198 /*
199  * indicate, that BSP has IDE driver
200  */
201 #define RTEMS_BSP_HAS_IDE_DRIVER
202
203 /* functions */
204
205 /* #define SHOW_MORE_INIT_SETTINGS 1 */
206
207 /* ata modes */
208 /* #undef ATA_USE_INT */
209 #define ATA_USE_INT
210
211 /* clock settings */
212 #if defined(HAS_UBOOT)
213 #define IPB_CLOCK (bsp_uboot_board_info.bi_ipbfreq)
214 #define XLB_CLOCK (bsp_uboot_board_info.bi_busfreq)
215 #define G2_CLOCK (bsp_uboot_board_info.bi_intfreq)
216 #elif defined(MPC5200_BOARD_BRS5L) || defined(MPC5200_BOARD_BRS6L)
217 #define IPB_CLOCK 66000000 /* 66 MHz */
218 #define XLB_CLOCK 132000000 /* 132 MHz */
219 #define G2_CLOCK 396000000 /* 396 MHz */
220 #else
221 #define IPB_CLOCK 33000000 /* 33 MHz */
222 #define XLB_CLOCK 66000000 /* 66 MHz */
223 #define G2_CLOCK 231000000 /* 231 MHz */
224 #endif
225
226 #if defined(HAS_UBOOT)
227 #define GEN5200_CONSOLE_BAUD (bsp_uboot_board_info.bi_baudrate)
228 #else
229 #define GEN5200_CONSOLE_BAUD 115200
230 #endif
231
232 /*
233  * Convert decrement value to tenths of microsecnds (used by
234  * shared timer driver).
235  *
236  * + CPU has a XLB_CLOCK bus,
237  * + There are 4 bus cycles per click
238  * + We return value in 1/10 microsecond units.
239  * Modified following equation to integer equation to remove
240  * floating point math.
241  * (int) ((float)(_value) / ((XLB_CLOCK/1000000 * 0.1) / 4.0))
242  */
243
244 #define BSP_Convert_decrementer( _value ) \
245  (int) (((_value) * 4000) / (XLB_CLOCK/10000))
246
247 /* slicetimer settings */
248 #define USE_SLICETIMER_0 TRUE
249 #define USE_SLICETIMER_1 FALSE
250
251 void *bsp_idle_thread( uintptr_t ignored );
252 #define BSP_IDLE_TASK_BODY bsp_idle_thread
253
254 /* BSP specific IRQ Benchmarking support */
255 void BSP_IRQ_Benchmarking_Reset(void);
256 void BSP_IRQ_Benchmarking_Report(void);
257
258 #if defined(HAS_UBOOT)
259  /* Routine to obtain U-Boot environment variables */
260  const char *bsp_uboot_getenv(
261  const char *name
262  );
263 #endif
264
265 void cpu_init(void);
266
267 int mpc5200_eth_mii_read(
268  int phyAddr,
269  void *arg,
270  unsigned regAddr,
271  uint32_t *retVal
272 );
273
274 #ifdef __cplusplus
275 }
276 #endif
277
278 #endif /* ASM */
279
282 #endif /* GEN5200 */
Definition: deflate.c:115
DEFAULT_INITIAL_EXTENSION Support.
PowerPC Exceptions API.
General purpose assembler macros, linker command file support and some inline functions for direct re...
U_BOOT Support.
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
