RTEMS  5.1
irq.h
1 /*===============================================================*\
2 | Project: RTEMS generic MPC5200 BSP |
3 +-----------------------------------------------------------------+
4 | Partially based on the code references which are named below. |
5 | Adaptions, modifications, enhancements and any recent parts of |
6 | the code are: |
7 | Copyright (c) 2005, 2010 |
8 | Embedded Brains GmbH |
9 | Obere Lagerstr. 30 |
10 | D-82178 Puchheim |
11 | Germany |
12 | rtems@embedded-brains.de |
13 +-----------------------------------------------------------------+
14 | The license and distribution terms for this file may be |
15 | found in the file LICENSE in this distribution or at |
16 | |
17 | http://www.rtems.org/license/LICENSE. |
18 | |
19 +-----------------------------------------------------------------+
20 | this file contains declarations for the irq controller handler |
21 \*===============================================================*/
22 /***********************************************************************/
23 /* */
24 /* Module: irq.h */
25 /* Date: 07/17/2003 */
26 /* Purpose: RTEMS MPC5x00 CPU interrupt header file */
27 /* */
28 /*---------------------------------------------------------------------*/
29 /* */
30 /* Description: This include file describe the data structure and */
31 /* the functions implemented by rtems to write */
32 /* interrupt handlers. */
33 /* */
34 /*---------------------------------------------------------------------*/
35 /* */
36 /* Code */
37 /* References: MPC8260ads CPU interrupt header file */
38 /* Module: irq.h */
39 /* Project: RTEMS 4.6.0pre1 / MCF8260ads BSP */
40 /* Version 1.1 */
41 /* Date: 10/10/2002 */
42 /* */
43 /* Author(s) / Copyright(s): */
44 /* */
45 /* Copyright (C) 1999 valette@crf.canon.fr */
46 /* */
47 /* This code is heavilly inspired by the public specification of */
48 /* STREAM V2 that can be found at: */
49 /* */
50 /* <http://www.chorus.com/Documentation/index.html> by following */
51 /* the STREAM API Specification Document link. */
52 /* */
53 /* Modified for mpc8260 by Andy Dachs <a.dachs@sstl.co.uk> */
54 /* Surrey Satellite Technology Limited */
55 /* The interrupt handling on the mpc8260 seems quite different from */
56 /* the 860 (I don't know the 860 well). Although some interrupts */
57 /* are routed via the CPM irq and some are direct to the SIU they */
58 /* all appear logically the same.Therefore I removed the distinction */
59 /* between SIU and CPM interrupts. */
60 /* */
61 /* The license and distribution terms for this file may be */
62 /* found in the file LICENSE in this distribution or at */
63 /* http://www.rtems.org/license/LICENSE. */
64 /* */
65 /*---------------------------------------------------------------------*/
66 /* */
67 /* Partially based on the code references which are named above. */
68 /* Adaptions, modifications, enhancements and any recent parts of */
69 /* the code are under the right of */
70 /* */
71 /* IPR Engineering, Dachauer Straße 38, D-80335 München */
72 /* Copyright(C) 2003 */
73 /* */
74 /*---------------------------------------------------------------------*/
75 /* */
76 /* IPR Engineering makes no representation or warranties with */
77 /* respect to the performance of this computer program, and */
78 /* specifically disclaims any responsibility for any damages, */
79 /* special or consequential, connected with the use of this program. */
80 /* */
81 /*---------------------------------------------------------------------*/
82 /* */
83 /* Version history: 1.0 */
84 /* */
85 /***********************************************************************/
86
87 #ifndef LIBBSP_POWERPC_GEN5200_IRQ_H
88 #define LIBBSP_POWERPC_GEN5200_IRQ_H
89
90 #define PMCE_CE_SHADOW (1U << (31 - 31))
91 #define PMCE_CSE_STICKY (1U << (31 - 21))
92 #define PMCE_MSE_STICKY (1U << (31 - 10))
93 #define PMCE_PSE_STICKY (1U << (31 - 2))
94 #define PMCE_CSE_SOURCE(_pmce) (((_pmce) >> 8) & 0x3U)
95 #define PMCE_MSE_SOURCE(_pmce) (((_pmce) >> 16) & 0x1fU)
96 #define PMCE_PSE_SOURCE(_pmce) (((_pmce) >> 24) & 0x1fU)
97
98 /*
99  * Peripheral IRQ handlers related definitions
100  */
101 #define BSP_PER_IRQ_NUMBER 22
102 #define BSP_PER_IRQ_LOWEST_OFFSET 0
103 #define BSP_PER_IRQ_MAX_OFFSET \
104  (BSP_PER_IRQ_LOWEST_OFFSET + BSP_PER_IRQ_NUMBER - 1) /* 21 */
105 /*
106  * Main IRQ handlers related definitions
107  */
108 #define BSP_MAIN_IRQ_NUMBER 17
109 #define BSP_MAIN_IRQ_LOWEST_OFFSET BSP_PER_IRQ_MAX_OFFSET + 1 /* 22 */
110 #define BSP_MAIN_IRQ_MAX_OFFSET \
111  (BSP_MAIN_IRQ_LOWEST_OFFSET + BSP_MAIN_IRQ_NUMBER - 1) /* 38 */
112 /*
113  * Critical IRQ handlers related definitions
114  */
115 #define BSP_CRIT_IRQ_NUMBER 4
116 #define BSP_CRIT_IRQ_LOWEST_OFFSET BSP_MAIN_IRQ_MAX_OFFSET + 1 /* 39 */
117 #define BSP_CRIT_IRQ_MAX_OFFSET \
118  (BSP_CRIT_IRQ_LOWEST_OFFSET + BSP_CRIT_IRQ_NUMBER - 1) /* 42 */
119 /*
120  * Summary of SIU interrupts
121  */
122 #define BSP_SIU_IRQ_NUMBER BSP_CRIT_IRQ_MAX_OFFSET + 1 /* 43 */
123 #define BSP_SIU_IRQ_LOWEST_OFFSET BSP_PER_IRQ_LOWEST_OFFSET /* 0 */
124 #define BSP_SIU_IRQ_MAX_OFFSET BSP_CRIT_IRQ_MAX_OFFSET /* 42 */
125 /*
126  * Processor IRQ handlers related definitions
127  */
128 #define BSP_PROCESSOR_IRQ_NUMBER 3
129 #define BSP_PROCESSOR_IRQ_LOWEST_OFFSET BSP_CRIT_IRQ_MAX_OFFSET + 1 /* 44 */
130 #define BSP_PROCESSOR_IRQ_MAX_OFFSET \
131  (BSP_PROCESSOR_IRQ_LOWEST_OFFSET + BSP_PROCESSOR_IRQ_NUMBER - 1) /* 46 */
132 /*
133  * Summary
134  */
135 #define BSP_IRQ_NUMBER BSP_PROCESSOR_IRQ_MAX_OFFSET + 1 /* 47 */
136 #define BSP_LOWEST_OFFSET BSP_PER_IRQ_LOWEST_OFFSET /* 0 */
137 #define BSP_MAX_OFFSET BSP_PROCESSOR_IRQ_MAX_OFFSET /* 46 */
138
139 #ifndef ASM
140
141 #include <rtems.h>
142 #include <rtems/irq.h>
143 #include <rtems/irq-extension.h>
144
145 /*
146  * index table for the module specific handlers, a few entries are only placeholders
147  */
148 typedef enum {
149  BSP_SIU_IRQ_SMARTCOMM = BSP_PER_IRQ_LOWEST_OFFSET + 0,
150  BSP_SIU_IRQ_PSC1 = BSP_PER_IRQ_LOWEST_OFFSET + 1,
151  BSP_SIU_IRQ_PSC2 = BSP_PER_IRQ_LOWEST_OFFSET + 2,
152  BSP_SIU_IRQ_PSC3 = BSP_PER_IRQ_LOWEST_OFFSET + 3,
153  BSP_SIU_IRQ_PSC6 = BSP_PER_IRQ_LOWEST_OFFSET + 4,
154  BSP_SIU_IRQ_ETH = BSP_PER_IRQ_LOWEST_OFFSET + 5,
155  BSP_SIU_IRQ_USB = BSP_PER_IRQ_LOWEST_OFFSET + 6,
156  BSP_SIU_IRQ_ATA = BSP_PER_IRQ_LOWEST_OFFSET + 7,
157  BSP_SIU_IRQ_PCI_CRT = BSP_PER_IRQ_LOWEST_OFFSET + 8,
158  BSP_SIU_IRQ_PCI_SC_RX = BSP_PER_IRQ_LOWEST_OFFSET + 9,
159  BSP_SIU_IRQ_PCI_SC_TX = BSP_PER_IRQ_LOWEST_OFFSET + 10,
160  BSP_SIU_IRQ_PSC4 = BSP_PER_IRQ_LOWEST_OFFSET + 11,
161  BSP_SIU_IRQ_PSC5 = BSP_PER_IRQ_LOWEST_OFFSET + 12,
162  BSP_SIU_IRQ_SPI_MODF = BSP_PER_IRQ_LOWEST_OFFSET + 13,
163  BSP_SIU_IRQ_SPI_SPIF = BSP_PER_IRQ_LOWEST_OFFSET + 14,
164  BSP_SIU_IRQ_I2C1 = BSP_PER_IRQ_LOWEST_OFFSET + 15,
165  BSP_SIU_IRQ_I2C2 = BSP_PER_IRQ_LOWEST_OFFSET + 16,
166  BSP_SIU_IRQ_MSCAN1 = BSP_PER_IRQ_LOWEST_OFFSET + 17,
167  BSP_SIU_IRQ_MSCAN2 = BSP_PER_IRQ_LOWEST_OFFSET + 18,
168  BSP_SIU_IRQ_IR_RX = BSP_PER_IRQ_LOWEST_OFFSET + 19,
169  BSP_SIU_IRQ_IR_TX = BSP_PER_IRQ_LOWEST_OFFSET + 20,
170  BSP_SIU_IRQ_XLB_ARB = BSP_PER_IRQ_LOWEST_OFFSET + 21,
171
172  /* SL_TIMER1 -- handler entry only used in case of SMI */
173  BSP_SIU_IRQ_SL_TIMER1 = BSP_MAIN_IRQ_LOWEST_OFFSET + 0,
174  BSP_SIU_IRQ_IRQ1 = BSP_MAIN_IRQ_LOWEST_OFFSET + 1,
175  BSP_SIU_IRQ_IRQ2 = BSP_MAIN_IRQ_LOWEST_OFFSET + 2,
176  BSP_SIU_IRQ_IRQ3 = BSP_MAIN_IRQ_LOWEST_OFFSET + 3,
177  /* LO_INT -- handler entry never used (only placeholder) */
178  BSP_SIU_IRQ_LO_INT = BSP_MAIN_IRQ_LOWEST_OFFSET + 4,
179  BSP_SIU_IRQ_RTC_PER = BSP_MAIN_IRQ_LOWEST_OFFSET + 5,
180  BSP_SIU_IRQ_RTC_STW = BSP_MAIN_IRQ_LOWEST_OFFSET + 6,
181  BSP_SIU_IRQ_GPIO_STD = BSP_MAIN_IRQ_LOWEST_OFFSET + 7,
182  BSP_SIU_IRQ_GPIO_WKUP = BSP_MAIN_IRQ_LOWEST_OFFSET + 8,
183  BSP_SIU_IRQ_TMR0 = BSP_MAIN_IRQ_LOWEST_OFFSET + 9,
184  BSP_SIU_IRQ_TMR1 = BSP_MAIN_IRQ_LOWEST_OFFSET + 10,
185  BSP_SIU_IRQ_TMR2 = BSP_MAIN_IRQ_LOWEST_OFFSET + 1,
186  BSP_SIU_IRQ_TMR3 = BSP_MAIN_IRQ_LOWEST_OFFSET + 12,
187  BSP_SIU_IRQ_TMR4 = BSP_MAIN_IRQ_LOWEST_OFFSET + 13,
188  BSP_SIU_IRQ_TMR5 = BSP_MAIN_IRQ_LOWEST_OFFSET + 14,
189  BSP_SIU_IRQ_TMR6 = BSP_MAIN_IRQ_LOWEST_OFFSET + 15,
190  BSP_SIU_IRQ_TMR7 = BSP_MAIN_IRQ_LOWEST_OFFSET + 16,
191
192  BSP_SIU_IRQ_IRQ0 = BSP_CRIT_IRQ_LOWEST_OFFSET + 0,
193  BSP_SIU_IRQ_SL_TIMER0 = BSP_CRIT_IRQ_LOWEST_OFFSET + 1,
194  /* HI_INT -- handler entry never used (only placeholder) */
195  BSP_SIU_IRQ_HI_INT = BSP_CRIT_IRQ_LOWEST_OFFSET + 2,
196  BSP_SIU_IRQ_CSS_WKUP = BSP_CRIT_IRQ_LOWEST_OFFSET + 3,
197
198  BSP_DECREMENTER = BSP_PROCESSOR_IRQ_LOWEST_OFFSET + 0,
199  BSP_SYSMGMT = BSP_PROCESSOR_IRQ_LOWEST_OFFSET + 1,
200  BSP_EXT = BSP_PROCESSOR_IRQ_LOWEST_OFFSET + 2
201 } rtems_irq_symbolic_name;
202
203 #define BSP_CRIT_IRQ_PRIO_LEVELS 4
204 #define BSP_PERIODIC_TIMER BSP_SIU_IRQ_TMR6
205
206 #define BSP_INTERRUPT_VECTOR_MIN BSP_LOWEST_OFFSET
207
208 #define BSP_INTERRUPT_VECTOR_MAX BSP_MAX_OFFSET
209
210 #endif
211
212 #endif /* LIBBSP_POWERPC_GEN5200_IRQ_H */
Header file for the Interrupt Manager Extension.
