#define  | PCI_FIXUP_OPT_OVERRIDE_NAME   (1<<0) |
#define  | out_32(_addr,  _val)   pci_out_32(BSP_PCI_BASE_ADDRESS, _addr, _val) |
#define  | out_le32(_addr,  _val)   pci_out_le32(BSP_PCI_BASE_ADDRESS, _addr, _val) |
#define  | in_8(_addr)   pci_in_8( BSP_PCI_BASE_ADDRESS, _addr ) |
#define  | in_le16(_addr)   pci_in_le16( BSP_PCI_BASE_ADDRESS, _addr ) |
#define  | in_le32(_addr)   pci_in_le32( BSP_PCI_BASE_ADDRESS, _addr ) |
#define  | in_16(_addr)   pci_in_16( BSP_PCI_BASE_ADDRESS, _addr ) |
#define  | in_32(_addr)   pci_in_32( BSP_PCI_BASE_ADDRESS, _addr ) |
#define  | out_8(_addr,  _val)   pci_out_8( BSP_PCI_BASE_ADDRESS, _addr, _val ) |
#define  | out_le16(_addr,  _val)   pci_out_le16( BSP_PCI_BASE_ADDRESS, _addr, _val ) |
#define  | out_16(_addr,  _val)   pci_out_16( BSP_PCI_BASE_ADDRESS, _addr, _val ) |
void  | FixupPCI (const struct _int_map *, int(*swizzler)(int, int)) |
unsigned char  | pci_bus_count (void) |
int  | indirect_pci_read_config_byte (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint8_t *val) |
int  | indirect_pci_read_config_word (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint16_t *val) |
int  | indirect_pci_read_config_dword (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint32_t *val) |
int  | indirect_pci_write_config_byte (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint8_t val) |
int  | indirect_pci_write_config_word (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint16_t val) |
int  | indirect_pci_write_config_dword (unsigned char bus, unsigned char slot, unsigned char function, unsigned char offset, uint32_t val) |
int  | FindPCIbridge (int mybus, struct pcibridge *pb) |
void  | pci_out_le32 (uint32_t base, uint32_t addr, uint32_t val) |
void  | pci_out_32 (uint32_t base, uint32_t addr, uint32_t val) |
uint8_t  | pci_in_8 (uint32_t base, uint32_t addr) |
int16_t  | pci_in_le16 (uint32_t base, uint32_t addr) |
uint32_t  | pci_in_le32 (uint32_t base, uint32_t addr) |
int16_t  | pci_in_16 (uint32_t base, uint32_t addr) |
uint32_t  | pci_in_32 (uint32_t base, uint32_t addr) |
void  | pci_out_8 (uint32_t base, uint32_t addr, uint8_t val) |
void  | pci_out_le16 (uint32_t base, uint32_t addr, uint16_t val) |
void  | pci_out_16 (uint32_t base, uint32_t addr, uint16_t val) |
