18 #ifndef LIBBSP_MIPS_HURRICANE_BSP_H    19 #define LIBBSP_MIPS_HURRICANE_BSP_H    43 extern void WriteDisplay(
char *
string );
    45 extern uint32_t mips_get_timer(
void );
    47 #define BSP_FEATURE_IRQ_EXTENSION    48 #define BSP_SHARED_HANDLER_SUPPORT      1    50 #define CPU_CLOCK_RATE_MHZ     (200)    51 #define CLOCKS_PER_MICROSECOND ( CPU_CLOCK_RATE_MHZ )     64 #define rtems_bsp_delay( microseconds ) \    66      uint32_t _end_clock = \    67           mips_get_timer() + microseconds * CLOCKS_PER_MICROSECOND; \    68      _end_clock %= 0x100000000;   \    71      while ( _end_clock < mips_get_timer() );  \    73      while ( _end_clock > mips_get_timer() ); \    79 #define RAM_END   0x100000
DEFAULT_INITIAL_EXTENSION Support.
