47 #ifndef LIBBSP_I386_PC386_BSP_H    48 #define LIBBSP_I386_PC386_BSP_H    62 #include <rtems/score/cpu.h>    71 #define BSP_HAS_FRAME_BUFFER 1    76 struct rtems_bsdnet_ifconfig;
    84 BSP_runtime_console_select(
int *pPrintkPort,
int *pConsolePort);
    86 extern int rtems_ne_driver_attach(
struct rtems_bsdnet_ifconfig *,
int);
    87 #define BSP_NE2000_NETWORK_DRIVER_NAME      "ne1"    88 #define BSP_NE2000_NETWORK_DRIVER_ATTACH    rtems_ne_driver_attach    90 extern int rtems_wd_driver_attach(
int);
    91 #define BSP_WD8003_NETWORK_DRIVER_NAME      "wd1"    92 #define BSP_WD8003_NETWORK_DRIVER_ATTACH    rtems_wd_driver_attach    94 extern int rtems_dec21140_driver_attach(
int);
    95 #define BSP_DEC21140_NETWORK_DRIVER_NAME    "dc1"    96 #define BSP_DEC21140_NETWORK_DRIVER_ATTACH  rtems_dec21140_driver_attach    98 extern int rtems_3c509_driver_attach(
config);
    99 #define BSP_3C509_NETWORK_DRIVER_NAME    "3c1"   100 #define BSP_3C509_NETWORK_DRIVER_ATTACH  rtems_3c509_driver_attach   102 #ifndef RTEMS_BSP_NETWORK_DRIVER_NAME   103 #define RTEMS_BSP_NETWORK_DRIVER_NAME   BSP_DEC21140_NETWORK_DRIVER_NAME   106 #ifndef RTEMS_BSP_NETWORK_DRIVER_ATTACH   107 #define RTEMS_BSP_NETWORK_DRIVER_ATTACH BSP_DEC21140_NETWORK_DRIVER_ATTACH   117 #define IO_TIMER1      0x40   119 #define TIMER_CNTR0    (IO_TIMER1 + 0)    120 #define TIMER_CNTR1    (IO_TIMER1 + 1)    121 #define TIMER_CNTR2    (IO_TIMER1 + 2)    122 #define TIMER_MODE     (IO_TIMER1 + 3)    123 #define TIMER_SEL0     0x00               124 #define TIMER_SEL1     0x40               125 #define TIMER_SEL2     0x80               126 #define TIMER_INTTC    0x00               127 #define TIMER_ONESHOT  0x02               128 #define TIMER_RATEGEN  0x04               129 #define TIMER_SQWAVE   0x06               130 #define TIMER_SWSTROBE 0x08               131 #define TIMER_HWSTROBE 0x0a               132 #define TIMER_LATCH    0x00               133 #define TIMER_LSB      0x10               134 #define TIMER_MSB      0x20               135 #define TIMER_16BIT    0x30               136 #define TIMER_BCD      0x01               137 #define TIMER_RD_BACK  0xc0           139 #define RB_NOT_COUNT    0x40              140 #define RB_NOT_STATUS   0x20              141 #define RB_COUNT_0  0x02              142 #define RB_COUNT_1  0x04              143 #define RB_COUNT_2  0x08              144 #define RB_OUTPUT   0x80              146 #define TIMER_TICK     1193182     148 #if defined( RTEMS_SMP )   158 #define    BSP_CONSOLE_VGA            0   159 #define    BSP_CONSOLE_COM1           1   160 #define    BSP_CONSOLE_COM2           2   165 #define US_TO_TICK(us) (((us)*105+44)/88)   166 #define TICK_TO_US(tk) (((tk)*88+52)/105)   172 extern segment_descriptors _Global_descriptor_table   [GDT_SIZE];
   177 void          _IBMPC_initVideo(
void);
   178 void          _IBMPC_outch    (
char);
   179 char          _IBMPC_inch     (
void);
   180 char          _IBMPC_inch_sleep (
void);
   181 int           BSP_wait_polled_input(
void);
   182 int           rtems_kbpoll(
void );
   184 void           add_to_queue(
unsigned short b );
   186 void Wait_X_ms(
unsigned int timeToWait);
   187 void Calibrate_loop_1ms(
void);
   189 void rtems_irq_mngt_init(
void);
   191 void Clock_driver_install_handler(
void);
   192 void Clock_driver_support_initialize_hardware(
void);
   195 #define BSP_IDLE_TASK_BODY bsp_idle_thread   197 void kbd_reset_setup(
char *str,
int *ints);
   198 size_t read_aux(
char * buffer,
size_t count);
   213 #define BSP_CONSOLE_PORT_CONSOLE (-1)   214 #define BSP_CONSOLE_PORT_COM1    (BSP_UART_COM1)   215 #define BSP_CONSOLE_PORT_COM2    (BSP_UART_COM2)   220 const char* bsp_cmdline(
void);
   221 const char* bsp_cmdline_arg(
const char* arg);
   227 void bsp_ide_cmdline_init(
void);
   232 #define RTEMS_BSP_HAS_IDE_DRIVER   236 void init_remote_gdb(
void );
   237 void i386_stub_glue_init(
int uart);
   238 void i386_stub_glue_init_breakin(
void);
   239 int i386_stub_glue_uart(
void);
   240 void breakpoint(
void);
   246 uint32_t BSP_irq_count_dump(FILE *f);
   252 void raw_idt_notify(
void);
   253 void C_dispatch_isr(
int vector);
   257   int imps_probe(
void);
   258   void ipi_install_irq(
void);
   259   int send_ipi(
unsigned int dst,
unsigned int v);
 Definition: deflate.c:115
DEFAULT_INITIAL_EXTENSION Support.
ISR lock control.
Definition: isrlock.h:56
Sizes of Global and Interrupt descriptor tables.
bool bsp_get_serial_mouse_device(const char **name, const char **type)
Obtain serial mouse configuration information.
Definition: serial_mouse_config.c:29
Interface to Kernel Print Methods.
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:26
unsigned v
Definition: tte.h:73
