RTEMS  5.1
spi.h
1 /*
2  * RTEMS driver for Blackfin SPI
3  *
4  * COPYRIGHT (c) 2010 Kallisti Labs, Los Gatos, CA, USA
5  * written by Allan Hessenflow <allanh@kallisti.com>
6  *
7  * The license and distribution terms for this file may be
8  * found in the file LICENSE in this distribution or at
9  * http://www.rtems.org/license/LICENSE.
10  */
11
12 #ifndef _spi_h
13 #define _spi_h
14
15 #ifdef __cplusplus
16 extern "C" {
17 #endif
18
19 typedef struct {
20  void *base;
21  /* remaining entries are for internal use */
22  rtems_id sem;
23  int bytes_per_word;
24  uint16_t idle_pattern;
25  uint8_t *rd_ptr;
26  const uint8_t *wr_ptr;
27  int len;
29
30 typedef struct {
34
35
36 void bfin_spi_isr(int v);
37
38 rtems_status_code bfin_spi_init(rtems_libi2c_bus_t *bus);
39
40 rtems_status_code bfin_spi_send_start(rtems_libi2c_bus_t *bus);
41
42 int bfin_spi_read_bytes(rtems_libi2c_bus_t *bus, unsigned char *buf, int len);
43
44 int bfin_spi_write_bytes(rtems_libi2c_bus_t *bus, unsigned char *buf, int len);
45
46 int bfin_spi_ioctl(rtems_libi2c_bus_t *bus, int cmd, void *arg);
47
48 #ifdef __cplusplus
49 }
50 #endif
51
52
53 #endif /* _spi_h */
Definition: libi2c.h:162
unsigned p
Definition: tte.h:90
Definition: spi.h:19
rtems_status_code
Classic API Status.
Definition: status.h:43
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
unsigned v
Definition: tte.h:73
Definition: spi.h:30
