RTEMS  5.1
bsp.h
1
7 /*
8  * SPDX-License-Identifier: BSD-2-Clause
9  *
10  * Copyright (C) 2013, 2014 embedded brains GmbH
11  *
12  * Redistribution and use in source and binary forms, with or without
13  * modification, are permitted provided that the following conditions
14  * are met:
15  * 1. Redistributions of source code must retain the above copyright
16  * notice, this list of conditions and the following disclaimer.
17  * 2. Redistributions in binary form must reproduce the above copyright
18  * notice, this list of conditions and the following disclaimer in the
19  * documentation and/or other materials provided with the distribution.
20  *
21  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31  * POSSIBILITY OF SUCH DAMAGE.
32  */
33
34 #ifndef LIBBSP_ARM_XILINX_ZYNQ_BSP_H
35 #define LIBBSP_ARM_XILINX_ZYNQ_BSP_H
36
47 #include <bspopts.h>
48
49 #define BSP_FEATURE_IRQ_EXTENSION
50
51 #ifndef ASM
52
53 #include <rtems.h>
54
56 #include <bsp/start.h>
57 #include <bsp/zynq-uart.h>
58
59 #ifdef __cplusplus
60 extern "C" {
61 #endif /* __cplusplus */
62
63 #define BSP_ARM_A9MPCORE_SCU_BASE 0xf8f00000
64
65 #define BSP_ARM_GIC_CPUIF_BASE 0xf8f00100
66
67 #define BSP_ARM_A9MPCORE_GT_BASE 0xf8f00200
68
69 #define BSP_ARM_A9MPCORE_PT_BASE 0xf8f00600
70
71 #define BSP_ARM_GIC_DIST_BASE 0xf8f01000
72
73 #define BSP_ARM_L2C_310_BASE 0xf8f02000
74
75 #define BSP_ARM_L2C_310_ID 0x410000c8
76
77 extern zynq_uart_context zynq_uart_instances[2];
78
87 BSP_START_TEXT_SECTION void zynq_setup_mmu_and_cache(void);
88
89 uint32_t zynq_clock_cpu_1x(void);
90
91 #ifdef __cplusplus
92 }
93 #endif /* __cplusplus */
94
95 #endif /* ASM */
96
99 #endif /* LIBBSP_ARM_XILINX_ZYNQ_BSP_H */
Zynq specific set up of the MMU.
Definition: bspstartmmu.c:59
UART support.
DEFAULT_INITIAL_EXTENSION Support.
Definition: zynq-uart.h:49
