RTEMS  5.1
bsp.h
1
9 /*
10  * SPDX-License-Identifier: BSD-2-Clause
11  *
12  * Copyright (C) 2019 DornerWorks
13  * Written by Jeff Kubascik <jeff.kubascik@dornerworks.com>
14  *
15  * Redistribution and use in source and binary forms, with or without
16  * modification, are permitted provided that the following conditions
17  * are met:
18  * 1. Redistributions of source code must retain the above copyright
19  * notice, this list of conditions and the following disclaimer.
20  * 2. Redistributions in binary form must reproduce the above copyright
21  * notice, this list of conditions and the following disclaimer in the
22  * documentation and/or other materials provided with the distribution.
23  *
24  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34  * POSSIBILITY OF SUCH DAMAGE.
35  */
36
37 #ifndef LIBBSP_ARM_XEN_BSP_H
38 #define LIBBSP_ARM_XEN_BSP_H
39
46 #include <bspopts.h>
47
48 #define BSP_FEATURE_IRQ_EXTENSION
49
50 #ifndef ASM
51
53 #include <bsp/start.h>
54
55 #include <rtems.h>
56
57 #ifdef __cplusplus
58 extern "C" {
59 #endif /* __cplusplus */
60
61 #define BSP_ARM_GIC_CPUIF_BASE 0x03002000
62 #define BSP_ARM_GIC_CPUIF_LENGTH 0x1000
63
64 #define BSP_ARM_GIC_DIST_BASE 0x03001000
65 #define BSP_ARM_GIC_DIST_LENGTH 0x1000
66
67 #define BSP_ARM_A9MPCORE_SCU_BASE 0
68
69 #define BSP_ARM_A9MPCORE_GT_BASE 0
70
71 #define BSP_XEN_VPL011_BASE 0x22000000
72 #define BSP_XEN_VPL011_LENGTH 0x1000
73
74 void arm_generic_timer_get_config(uint32_t *frequency, uint32_t *irq);
75
76 BSP_START_TEXT_SECTION void bsp_xen_setup_mmu_and_cache(void);
77
78 #ifdef __cplusplus
79 }
80 #endif /* __cplusplus */
81
82 #endif /* ASM */
83
86 #endif /* LIBBSP_ARM_XEN_BSP_H */
DEFAULT_INITIAL_EXTENSION Support.
