RTEMS  5.1
irq.h
1
9 /*
10  * Copyright (c) 2014 Premysl Houdek <kom541000@gmail.com>
11  *
12  * Google Summer of Code 2014 at
13  * Czech Technical University in Prague
14  * Zikova 1903/4
15  * 166 36 Praha 6
16  * Czech Republic
17  *
18  * Based on LPC24xx and LPC1768 BSP
19  * by embedded brains GmbH and others
20  *
21  * The license and distribution terms for this file may be
22  * found in the file LICENSE in this distribution or at
23  * http://www.rtems.org/license/LICENSE.
24  */
25
26 #ifndef LIBBSP_ARM_TMS570_IRQ_H
27 #define LIBBSP_ARM_TMS570_IRQ_H
28
29 #ifndef ASM
30 #include <rtems.h>
31 #include <rtems/irq.h>
32 #include <rtems/irq-extension.h>
33 #endif
34
35 #define BSP_INTERRUPT_VECTOR_MIN 0U
36 #define TMS570_IRQ_ESM_HIGH 0
37 #define TMS570_IRQ_RESERVED 1
38 #define TMS570_IRQ_TIMER_0 2
39 #define TMS570_IRQ_TIMER_1 3
40 #define TMS570_IRQ_TIMER_2 4
41 #define TMS570_IRQ_TIMER_3 5
42 #define TMS570_IRQ_RTI_OVERFLOW_0 6
43 #define TMS570_IRQ_RTI_OVERFLOW_1 7
44 #define TMS570_IRQ_RTI_TIMEBASE 8
45 #define TMS570_IRQ_GIO_HIGH 9
46 #define TMS570_IRQ_HET_HIGH 10
47 #define TMS570_IRQ_HET_TU_HIGH 11
48 #define TMS570_IRQ_MIBSPI1_HIGH 12
49 #define TMS570_IRQ_SCI_LEVEL_0 13
50 #define TMS570_IRQ_ADC1_EVENT 14
51 #define TMS570_IRQ_ADC1_GROUP_1 15
52 #define TMS570_IRQ_CAN1_HIGH 16
53 #define TMS570_IRQ_RESERVED 17
54 #define TMS570_IRQ_FLEXRAY_HIGH 18
55 #define TMS570_IRQ_CRC_1 19
56 #define TMS570_IRQ_ESM_LOW 20
57 #define TMS570_IRQ_SSI 21
58 #define TMS570_IRQ_PMU 22
59 #define TMS570_IRQ_GIO_LOW 23
60 #define TMS570_IRQ_HET_LOW 24
61 #define TMS570_IRQ_HET_TU_LOW 25
62 #define TMS570_IRQ_MIBSPI1_LOW 26
63 #define TMS570_IRQ_SCI_LEVEL_1 27
64 #define TMS570_IRQ_ADC1_GROUP_2 28
65 #define TMS570_IRQ_CAN1_LOW 29
66 #define TMS570_IRQ_RESERVED
67 #define TMS570_IRQ_ADC1_MAG 31
68 #define TMS570_IRQ_FLEXRAY_LOW 32
69 #define TMS570_IRQ_DMA_FTCA 33
70 #define TMS570_IRQ_DMA_LFSA 34
71 #define TMS570_IRQ_CAN2_HIGH 35
72 #define TMS570_IRQ_DMM_HIGH 36
73 #define TMS570_IRQ_MIBSPI3_HIGH 37
74 #define TMS570_IRQ_MIBSPI3_LOW 38
75 #define TMS570_IRQ_DMA_HBCA 39
76 #define TMS570_IRQ_DMA_BTCA 40
77 #define TMS570_IRQ_DMA_BERA 41
78 #define TMS570_IRQ_CAN2_LOW 42
79 #define TMS570_IRQ_DMM_LOW 43
80 #define TMS570_IRQ_CAN1_IF3 44
81 #define TMS570_IRQ_CAN3_HIGH 45
82 #define TMS570_IRQ_CAN2_IF3 46
83 #define TMS570_IRQ_FPU 47
84 #define TMS570_IRQ_FLEXRAY_TU 48
85 #define TMS570_IRQ_SPI4_HIGH 49
86 #define TMS570_IRQ_ADC2_EVENT 50
87 #define TMS570_IRQ_ADC2_GROUP_1 51
88 #define TMS570_IRQ_FLEXRAY_T0C 52
89 #define TMS570_IRQ_MIBSPIP5_HIGH 53
90 #define TMS570_IRQ_SPI4_LOW 54
91 #define TMS570_IRQ_CAN3_LOW 55
92 #define TMS570_IRQ_MIBSPIP5_LOW 56
93 #define TMS570_IRQ_ADC2_GROUP_2 57
94 #define TMS570_IRQ_FLEXRAY_TU_ERROR 58
95 #define TMS570_IRQ_ADC2_MAG 59
96 #define TMS570_IRQ_CAN3_IF3 60
97 #define TMS570_IRQ_FSM_DONE 61
98 #define TMS570_IRQ_FLEXRAY_T1C 62
99 #define TMS570_IRQ_HET2_LEVEL_0 63
100 #define TMS570_IRQ_SCI2_LEVEL_0 64
101 #define TMS570_IRQ_HET_TU2_LEVEL_0 65
102 #define TMS570_IRQ_IC2_INTERRUPT 66
103 #define TMS570_IRQ_HET2_LEVEL_1 73
104 #define TMS570_IRQ_SCI2_LEVEL_1 74
105 #define TMS570_IRQ_HET_TU2_LEVEL_1 75
106 #define TMS570_IRQ_EMAC_MISC 76
107 #define TMS570_IRQ_EMAC_TX 77
108 #define TMS570_IRQ_EMAC_THRESH 78
109 #define TMS570_IRQ_EMAC_RX 79
110 #define TMS570_IRQ_HWA_INT_REQ_H 80
111 #define TMS570_IRQ_HWA_INT_REQ_H 81
112 #define TMS570_IRQ_DCC_DONE_INTERRUPT 82
113 #define TMS570_IRQ_DCC2_DONE_INTERRUPT 83
114 #define TMS570_IRQ_HWAG1_INT_REQ_L 88
115 #define TMS570_IRQ_HWAG2_INT_REQ_L 89
116 #define BSP_INTERRUPT_VECTOR_MAX 94
117
118 #define TMS570_IRQ_PRIORITY_VALUE_MIN 0U
119 #define TMS570_IRQ_PRIORITY_VALUE_MAX 0U
120
121 #define TMS570_IRQ_PRIORITY_COUNT ( TMS570_IRQ_PRIORITY_VALUE_MAX + 1U )
122 #define TMS570_IRQ_PRIORITY_HIGHEST TMS570_IRQ_PRIORITY_VALUE_MIN
123 #define TMS570_IRQ_PRIORITY_LOWEST TMS570_IRQ_PRIORITY_VALUE_MAX
124
125 #ifndef ASM
126
139  rtems_vector_number vector,
140  unsigned priority
141 );
142
155
156 #endif /* ASM */
157
160 #endif /* LIBBSP_ARM_TMS570_IRQ_H */
void tms570_irq_set_priority(rtems_vector_number vector, unsigned priority)
Set priority of the interrupt vector.
Definition: irq.c:44
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Header file for the Interrupt Manager Extension.
unsigned tms570_irq_get_priority(rtems_vector_number vector)
Gets priority of the interrupt vector.
Definition: irq.c:65
