RTEMS
5.1
Cortex-R performace counters. More...
| uint32_t | _CPU_Counter_frequency (void) |
| Returns the current CPU counter frequency in Hz. More... | |
| CPU_Counter_ticks | _CPU_Counter_read (void) |
| Returns the current CPU counter value. More... | |
| RTEMS_SYSINIT_ITEM (tms570_cpu_counter_initialize, RTEMS_SYSINIT_CPU_COUNTER, RTEMS_SYSINIT_ORDER_FIRST) | |
The counters setup functions are these which has been suggested on StackOverflow
Code is probably for use on Cortex-A without modifications as well.
1.8.15
