RTEMS  5.1
spi.h
1
9 /*
10  * Copyright (c) 2014-2015 Andre Marques <andre.lousa.marques at gmail.com>
11  *
12  * The license and distribution terms for this file may be
13  * found in the file LICENSE in this distribution or at
14  * http://www.rtems.org/license/LICENSE.
15  */
16
17 #ifndef LIBBSP_ARM_RASPBERRYPI_SPI_H
18 #define LIBBSP_ARM_RASPBERRYPI_SPI_H
19
20 #include <rtems/libi2c.h>
21
22 #ifdef __cplusplus
23 extern "C" {
24 #endif /* __cplusplus */
25
39 /* TODO: It would be nice if this value could be probed at startup, probably
40  * using the Mailbox interface since the usual way of setting this on
41  * the hardware is through a "config.txt" text file on the SD card.
42  * Having this setup on the configure.ac script would require changing
43  * the same setting on two different places. */
44 #define GPU_CORE_CLOCK_RATE 250000000
45
69 extern int rpi_spi_init(bool bidirectional_mode);
70
73 #ifdef __cplusplus
74 }
75 #endif /* __cplusplus */
76
77 #endif /* LIBBSP_ARM_RASPBERRYPI_SPI_H */
Legacy I2C Library.
Setups the Raspberry Pi SPI bus (located on the GPIO header) on the "/dev/spi" device file,...
Definition: spi.c:640
