RTEMS  5.1
irq.h
1
9 /*
10  * Copyright (c) 2008-2012 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Obere Lagerstr. 30
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_LPC24XX_IRQ_H
24 #define LIBBSP_ARM_LPC24XX_IRQ_H
25
26 #ifndef ASM
27  #include <rtems.h>
28  #include <rtems/irq.h>
29  #include <rtems/irq-extension.h>
30 #endif
31
38 #define BSP_INTERRUPT_VECTOR_MIN 0
39
40 #ifdef ARM_MULTILIB_ARCH_V4
41  #define LPC24XX_IRQ_WDT 0
42  #define LPC24XX_IRQ_SOFTWARE 1
43  #define LPC24XX_IRQ_ARM_CORE_0 2
44  #define LPC24XX_IRQ_ARM_CORE_1 3
45  #define LPC24XX_IRQ_TIMER_0 4
46  #define LPC24XX_IRQ_TIMER_1 5
47  #define LPC24XX_IRQ_UART_0 6
48  #define LPC24XX_IRQ_UART_1 7
49  #define LPC24XX_IRQ_PWM 8
50  #define LPC24XX_IRQ_I2C_0 9
51  #define LPC24XX_IRQ_SPI_SSP_0 10
52  #define LPC24XX_IRQ_SSP_1 11
53  #define LPC24XX_IRQ_PLL 12
54  #define LPC24XX_IRQ_RTC 13
55  #define LPC24XX_IRQ_EINT_0 14
56  #define LPC24XX_IRQ_EINT_1 15
57  #define LPC24XX_IRQ_EINT_2 16
58  #define LPC24XX_IRQ_EINT_3 17
59  #define LPC24XX_IRQ_ADC_0 18
60  #define LPC24XX_IRQ_I2C_1 19
61  #define LPC24XX_IRQ_BOD 20
62  #define LPC24XX_IRQ_ETHERNET 21
63  #define LPC24XX_IRQ_USB 22
64  #define LPC24XX_IRQ_CAN 23
65  #define LPC24XX_IRQ_SD_MMC 24
66  #define LPC24XX_IRQ_DMA 25
67  #define LPC24XX_IRQ_TIMER_2 26
68  #define LPC24XX_IRQ_TIMER_3 27
69  #define LPC24XX_IRQ_UART_2 28
70  #define LPC24XX_IRQ_UART_3 29
71  #define LPC24XX_IRQ_I2C_2 30
72  #define LPC24XX_IRQ_I2S 31
73
74  #define BSP_INTERRUPT_VECTOR_MAX 31
75 #else
76  #define LPC24XX_IRQ_WDT 0
77  #define LPC24XX_IRQ_TIMER_0 1
78  #define LPC24XX_IRQ_TIMER_1 2
79  #define LPC24XX_IRQ_TIMER_2 3
80  #define LPC24XX_IRQ_TIMER_3 4
81  #define LPC24XX_IRQ_UART_0 5
82  #define LPC24XX_IRQ_UART_1 6
83  #define LPC24XX_IRQ_UART_2 7
84  #define LPC24XX_IRQ_UART_3 8
85  #define LPC24XX_IRQ_PWM_1 9
86  #define LPC24XX_IRQ_I2C_0 10
87  #define LPC24XX_IRQ_I2C_1 11
88  #define LPC24XX_IRQ_I2C_2 12
89  #define LPC24XX_IRQ_SPI_SSP_0 14
90  #define LPC24XX_IRQ_SSP_1 15
91  #define LPC24XX_IRQ_PLL 16
92  #define LPC24XX_IRQ_RTC 17
93  #define LPC24XX_IRQ_EINT_0 18
94  #define LPC24XX_IRQ_EINT_1 19
95  #define LPC24XX_IRQ_EINT_2 20
96  #define LPC24XX_IRQ_EINT_3 21
97  #define LPC24XX_IRQ_ADC_0 22
98  #define LPC24XX_IRQ_BOD 23
99  #define LPC24XX_IRQ_USB 24
100  #define LPC24XX_IRQ_CAN 25
101  #define LPC24XX_IRQ_DMA 26
102  #define LPC24XX_IRQ_I2S 27
103  #define LPC24XX_IRQ_ETHERNET 28
104  #define LPC24XX_IRQ_SD_MMC 29
105  #define LPC24XX_IRQ_MCPWM 30
106  #define LPC24XX_IRQ_QEI 31
107  #define LPC24XX_IRQ_PLL_ALT 32
108  #define LPC24XX_IRQ_USB_ACTIVITY 33
109  #define LPC24XX_IRQ_CAN_ACTIVITY 34
110  #define LPC24XX_IRQ_UART_4 35
111  #define LPC24XX_IRQ_SSP_2 36
112  #define LPC24XX_IRQ_LCD 37
113  #define LPC24XX_IRQ_GPIO 38
114  #define LPC24XX_IRQ_PWM 39
115  #define LPC24XX_IRQ_EEPROM 40
116
117  #define BSP_INTERRUPT_VECTOR_MAX 40
118 #endif
119
120 #define LPC24XX_IRQ_PRIORITY_VALUE_MIN 0
121 #ifdef ARM_MULTILIB_ARCH_V4
122  #define LPC24XX_IRQ_PRIORITY_VALUE_MAX 15
123 #else
124  #define LPC24XX_IRQ_PRIORITY_VALUE_MAX 31
125 #endif
126 #define LPC24XX_IRQ_PRIORITY_COUNT (LPC24XX_IRQ_PRIORITY_VALUE_MAX + 1)
127 #define LPC24XX_IRQ_PRIORITY_HIGHEST LPC24XX_IRQ_PRIORITY_VALUE_MIN
128 #define LPC24XX_IRQ_PRIORITY_LOWEST LPC24XX_IRQ_PRIORITY_VALUE_MAX
129
130 #ifndef ASM
131
132 void lpc24xx_irq_set_priority(rtems_vector_number vector, unsigned priority);
133
134 unsigned lpc24xx_irq_get_priority(rtems_vector_number vector);
135
136 #endif /* ASM */
137
140 #endif /* LIBBSP_ARM_LPC24XX_IRQ_H */
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Header file for the Interrupt Manager Extension.
