RTEMS  5.1
i2c.h
1
7 /*
8  * SPDX-License-Identifier: BSD-2-Clause
9  *
10  * Copyright (C) 2009, 2019 embedded brains GmbH
11  *
12  * Redistribution and use in source and binary forms, with or without
13  * modification, are permitted provided that the following conditions
14  * are met:
15  * 1. Redistributions of source code must retain the above copyright
16  * notice, this list of conditions and the following disclaimer.
17  * 2. Redistributions in binary form must reproduce the above copyright
18  * notice, this list of conditions and the following disclaimer in the
19  * documentation and/or other materials provided with the distribution.
20  *
21  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24  * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25  * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26  * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27  * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28  * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29  * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30  * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31  * POSSIBILITY OF SUCH DAMAGE.
32  */
33
34 #ifndef LIBBSP_ARM_LPC24XX_I2C_H
35 #define LIBBSP_ARM_LPC24XX_I2C_H
36
37 #ifdef __cplusplus
38 extern "C" {
39 #endif /* __cplusplus */
40
49 #define LPC24XX_I2C_0_BUS_PATH "/dev/i2c-0"
50
51 #define LPC24XX_I2C_1_BUS_PATH "/dev/i2c-1"
52
53 #define LPC24XX_I2C_2_BUS_PATH "/dev/i2c-2"
54
55 int lpc24xx_register_i2c_0(void);
56
57 int lpc24xx_register_i2c_1(void);
58
59 int lpc24xx_register_i2c_2(void);
60
63 #ifdef __cplusplus
64 }
65 #endif /* __cplusplus */
66
67 #endif /* LIBBSP_ARM_LPC24XX_I2C_H */
