#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#define  | BSP_FEATURE_IRQ_EXTENSION |
#define  | BSP_FDT_IS_SUPPORTED |
#define  | BSP_ARM_GIC_DIST_BASE   imx_gic_dist_base |
#define  | BSP_ARM_GIC_CPUIF_BASE   (BSP_ARM_GIC_DIST_BASE + 0x1000) |
#define  | BSP_ARM_A9MPCORE_GT_BASE   0 |
#define  | BSP_ARM_A9MPCORE_SCU_BASE   0 |
void  | arm_generic_timer_get_config (uint32_t *frequency, uint32_t *irq) |
void *  | imx_get_reg_of_node (const void *fdt, int node) |
int  | imx_iomux_configure_pins (const void *fdt, uint32_t phandle) |
rtems_vector_number  | imx_get_irq_of_node (const void *fdt, int node, size_t index) |
void  | imx_uart_console_drain (void) |
| int  | i2c_bus_register_imx (const char *bus_path, const char *alias_or_path) |
|   | Registers an IMX I2C bus driver.  More...
| int  | spi_bus_register_imx (const char *bus_path, const char *alias_or_path) |
|   | Registers an IMX ECSPI bus driver.  More...
uintptr_t  | imx_gic_dist_base |
