RTEMS  5.1
spi.h
1
11 /*
12  * Copyright (c) 2018 Pierre-Louis Garnier <garnie_a@epita.fr>
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef LIBBSP_ARM_BEAGLE_SPI_H
20 #define LIBBSP_ARM_BEAGLE_SPI_H
21
22 #include <bsp.h>
23 #include <rtems/libi2c.h>
24 #include <rtems/irq.h>
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif /* __cplusplus */
29
30 #define BBB_SPI_TIMEOUT 1000
31
32 #define BBB_SPI_0_BUS_PATH "/dev/spi-0"
33
34 #define BBB_SPI_0_IRQ AM335X_INT_SPI0INT
35
36 typedef enum {
37  SPI0,
38  SPI1,
39  SPI_COUNT
40 } bbb_spi_id_t;
41
42
43
45  unsigned short status;
46  unsigned short length;
47  volatile void *buffer;
49
50 typedef struct beagle_spi_softc {
51  int initialized;
52  rtems_id task_id;
53  uintptr_t regs_base;
56
57 typedef struct {
58  rtems_libi2c_bus_t bus_desc;
59  beagle_spi_softc_t softc;
61
62 /*
63  * Initialize the driver
64  *
65  * Returns: o = ok or error code
66  */
67 rtems_status_code beagle_spi_init
68 (
69  rtems_libi2c_bus_t *bh /* bus specifier structure */
70 );
71
72 /*
73  * Receive some bytes from SPI device
74  *
75  * Returns: number of bytes received or (negative) error code
76  */
77 int beagle_spi_read_bytes
78 (
79  rtems_libi2c_bus_t *bh, /* bus specifier structure */
80  unsigned char *buf, /* buffer to store bytes */
81  int len /* number of bytes to receive */
82 );
83
84 /*
85  * Send some bytes to SPI device
86  *
87  * Returns: number of bytes sent or (negative) error code
88  */
89 int beagle_spi_write_bytes
90 (
91  rtems_libi2c_bus_t *bh, /* bus specifier structure */
92  unsigned char *buf, /* buffer to send */
93  int len /* number of bytes to send */
94 );
95
96 /*
97  * Set SPI to desired baudrate/clock mode/character mode
98  *
99  * Returns: rtems_status_code
100  */
101 rtems_status_code beagle_spi_set_tfr_mode
102 (
103  rtems_libi2c_bus_t *bh, /* bus specifier structure */
104  const rtems_libi2c_tfr_mode_t *tfr_mode /* transfer mode info */
105 );
106
107 /*
108  * Perform selected ioctl function for SPI
109  *
110  * Returns: rtems_status_code
111  */
112 int beagle_spi_ioctl
113 (
114  rtems_libi2c_bus_t *bh, /* bus specifier structure */
115  int cmd, /* ioctl command code */
116  void *arg /* additional argument array */
117 );
118
119 /*
120  * Register SPI bus and devices
121  *
122  * Returns: Bus number or error code
123  */
124 rtems_status_code bsp_register_spi
125 (
126  const char *bus_path,
127  uintptr_t register_base,
129 );
130
131 static inline rtems_status_code bbb_register_spi_0(void)
132 {
133  return bsp_register_spi(
134  BBB_SPI_0_BUS_PATH,
135  AM335X_SPI0_BASE,
136  BBB_SPI_0_IRQ
137  );
138 }
139
140 #ifdef __cplusplus
141 }
142 #endif /* __cplusplus */
143
144 #endif /* LIBBSP_ARM_BEAGLE_SPI_H */
#define SPI1
(SPI1 ) Base Address
Definition: same70j19.h:521
Definition: spi.h:50
Definition: libi2c.h:162
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: spi.h:44
#define SPI0
(SPI0 ) Base Address
Definition: same70j19.h:503
rtems_status_code
Classic API Status.
Definition: status.h:43
Definition: libi2c.h:462
Definition: spi.h:57
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Legacy I2C Library.
