RTEMS  5.1
i2c.h
1
9 /*
10  * Copyright (c) 2012 Claas Ziemke. All rights reserved.
11  *
12  * Claas Ziemke
13  * Kernerstrasse 11
14  * 70182 Stuttgart
15  * Germany
16  * <claas.ziemke@gmx.net>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef LIBBSP_ARM_BEAGLE_I2C_H
24 #define LIBBSP_ARM_BEAGLE_I2C_H
25
26 #include <rtems.h>
27 #include <bsp.h>
28 #include <dev/i2c/i2c.h>
29
30 #ifdef __cplusplus
31 extern "C" {
32 #endif /* __cplusplus */
33
34 #define BBB_I2C_SYSCLK 48000000
35 #define BBB_I2C_INTERNAL_CLK 12000000
36
37 #define BBB_I2C_0_BUS_PATH "/dev/i2c-0"
38 #define BBB_I2C_1_BUS_PATH "/dev/i2c-1"
39 #define BBB_I2C_2_BUS_PATH "/dev/i2c-2"
40
41 #define BBB_I2C0_IRQ 70
42 #define BBB_I2C1_IRQ 71
43 #define BBB_I2C2_IRQ 30
44
45 typedef enum {
46  I2C0,
47  I2C1,
48  I2C2,
49  I2C_COUNT
50 } bbb_i2c_id_t;
51
52 typedef struct i2c_regs {
53  uint32_t BBB_I2C_REVNB_LO;
54  uint32_t BBB_I2C_REVNB_HI;
55  uint32_t dummy1[ 2 ];
56  uint32_t BBB_I2C_SYSC;
57  uint32_t dummy2[ 4 ];
58  uint32_t BBB_I2C_IRQSTATUS_RAW;
59  uint32_t BBB_I2C_IRQSTATUS;
60  uint32_t BBB_I2C_IRQENABLE_SET;
61  uint32_t BBB_I2C_IRQENABLE_CLR;
62  uint32_t BBB_I2C_WE;
63  uint32_t BBB_I2C_DMARXENABLE_SET;
64  uint32_t BBB_I2C_DMATXENABLE_SET;
65  uint32_t BBB_I2C_DMARXENABLE_CLR;
66  uint32_t BBB_I2C_DMATXENABLE_CLR;
67  uint32_t BBB_I2C_DMARXWAKE_EN;
68  uint32_t BBB_I2C_DMATXWAKE_EN;
69  uint32_t dummy3[ 16 ];
70  uint32_t BBB_I2C_SYSS;
71  uint32_t BBB_I2C_BUF;
72  uint32_t BBB_I2C_CNT;
73  uint32_t BBB_I2C_DATA;
74  uint32_t dummy4;
75  uint32_t BBB_I2C_CON;
76  uint32_t BBB_I2C_OA;
77  uint32_t BBB_I2C_SA;
78  uint32_t BBB_I2C_PSC;
79  uint32_t BBB_I2C_SCLL;
80  uint32_t BBB_I2C_SCLH;
81  uint32_t BBB_I2C_SYSTEST;
82  uint32_t BBB_I2C_BUFSTAT;
83  uint32_t BBB_I2C_OA1;
84  uint32_t BBB_I2C_OA2;
85  uint32_t BBB_I2C_OA3;
86  uint32_t BBB_I2C_ACTOA;
87  uint32_t BBB_I2C_SBLOCK;
88 } bbb_i2c_regs;
89
90 int am335x_i2c_bus_register(
91  const char *bus_path,
92  uintptr_t register_base,
93  uint32_t input_clock, /* FIXME: Unused. Left for compatibility. */
95 );
96
97 static inline int bbb_register_i2c_1( void )
98 {
99  return am335x_i2c_bus_register(
100  BBB_I2C_1_BUS_PATH,
101  AM335X_I2C1_BASE,
103  BBB_I2C1_IRQ
104  );
105 }
106
107 static inline int bbb_register_i2c_2( void )
108 {
109  return am335x_i2c_bus_register(
110  BBB_I2C_2_BUS_PATH,
111  AM335X_I2C2_BASE,
113  BBB_I2C2_IRQ
114  );
115 }
116
117 #ifdef __cplusplus
118 }
119 #endif /* __cplusplus */
120
121 #endif /* LIBBSP_ARM_BEAGLE_I2C_H */
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Inter-Integrated Circuit (I2C) Driver API.
#define I2C_BUS_CLOCK_DEFAULT
Default I2C bus clock in Hz.
Definition: i2c.h:105
Definition: i2c.h:52
