RTEMS  5.1
spi.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
37 #ifndef _SPI_
38 #define _SPI_
39
40 /*----------------------------------------------------------------------------
41  * Headers
42  *----------------------------------------------------------------------------*/
43
44 #include "chip.h"
45
46 /*----------------------------------------------------------------------------
47  * Macros
48  *----------------------------------------------------------------------------*/
49
63 #define SPI_PCS(npcs) SPI_MR_PCS((~(1 << npcs) & 0xF))
64
66 #define SPI_SCBR(baudrate, masterClock) \
67  SPI_CSR_SCBR((uint32_t)(masterClock / baudrate))
68
70 #define SPI_DLYBS(delay, masterClock) \
71  SPI_CSR_DLYBS((uint32_t) (((masterClock / 1000000) * delay) / 1000)+1)
72
74 #define SPI_DLYBCT(delay, masterClock) \
75  SPI_CSR_DLYBCT ((uint32_t) (((masterClock / 1000000) * delay) / 32000)+1)
76
77 /*------------------------------------------------------------------------------ */
78
79 #ifdef __cplusplus
80 extern "C" {
81 #endif
82
83 /*----------------------------------------------------------------------------
84  * Exported functions
85  *----------------------------------------------------------------------------*/
86
87 extern void SPI_Enable(Spi *spi);
88 extern void SPI_Disable(Spi *spi);
89
90 extern void SPI_EnableIt(Spi *spi, uint32_t dwSources);
91 extern void SPI_DisableIt(Spi *spi, uint32_t dwSources);
92
93 extern void SPI_Configure(Spi *spi, uint32_t dwId, uint32_t dwConfiguration);
94 extern void SPI_SetMode(Spi *spi, uint32_t dwConfiguration);
95
96 extern void SPI_ChipSelect(Spi *spi, uint8_t cS);
97 extern void SPI_ReleaseCS(Spi *spi);
98
99 extern void SPI_ConfigureNPCS(Spi *spi, uint32_t dwNpcs,
100  uint32_t dwConfiguration);
101 extern void SPI_ConfigureCSMode(Spi *spi, uint32_t dwNpcs,
102  uint32_t bReleaseOnLast);
103
104 extern uint32_t SPI_Read(Spi *spi);
105 extern void SPI_Write(Spi *spi, uint32_t dwNpcs, uint16_t wData);
106 extern void SPI_WriteLast(Spi *spi, uint32_t dwNpcs, uint16_t wData);
107
108 extern uint32_t SPI_GetStatus(Spi *spi);
109 extern uint32_t SPI_IsFinished(Spi *pSpi);
110
111 #ifdef __cplusplus
112 }
113 #endif
114
115 #endif /* #ifndef _SPI_ */
116
Configures SPI chip select.
Definition: spi.c:146
void SPI_ConfigureNPCS(Spi *spi, uint32_t dwNpcs, uint32_t dwConfiguration)
Configures a chip select of a SPI peripheral. The chip select configuration is computed using several...
Definition: spi.c:184
Disables one or more interrupt sources of a SPI peripheral.
Definition: spi.c:115
Spi hardware registers.
Definition: component_spi.h:41
Get the current status register of the given SPI peripheral.
Definition: spi.c:212
Sends data through a SPI peripheral. If the SPI is configured to use a fixed peripheral select,...
Definition: spi.c:241
Check if SPI transfer finish.
Definition: spi.c:278
Configures SPI Mode Register.
Definition: spi.c:158
Configures SPI to release last used CS line.
Definition: spi.c:169
void SPI_ConfigureCSMode(Spi *spi, uint32_t dwNpcs, uint32_t bReleaseOnLast)
Configures a chip select active mode of a SPI peripheral.
Definition: spi.c:197
Reads and returns the last word of data received by a SPI peripheral. This method must be called afte...
Definition: spi.c:225
Configures a SPI peripheral as specified. The configuration can be computed using several macros (see...
Definition: spi.c:128
Sends last data through a SPI peripheral. If the SPI is configured to use a fixed peripheral select,...
Definition: spi.c:260
Enables one or more interrupt sources of a SPI peripheral.
Definition: spi.c:104
Enables a SPI peripheral.
Definition: spi.c:83
Disables a SPI peripheral.
Definition: spi.c:93
