RTEMS  5.1
sc16is752.h
1 /*
2  * Copyright (c) 2016 embedded brains GmbH. All rights reserved.
3  *
4  * embedded brains GmbH
5  * Dornierstr. 4
6  * 82178 Puchheim
7  * Germany
8  * <info@embedded-brains.de>
9  *
10  * The license and distribution terms for this file may be
11  * found in the file LICENSE in this distribution or at
12  * http://www.rtems.org/license/LICENSE.
13  */
14
15 #ifndef LIBBSP_ARM_ATSAM_SC16IS752_H
16 #define LIBBSP_ARM_ATSAM_SC16IS752_H
17
18 #include <rtems/irq-extension.h>
19 #include <libchip/chip.h>
20
21 #include <dev/serial/sc16is752.h>
22
23 #ifdef __cplusplus
24 extern "C" {
25 #endif /* __cplusplus */
26
32 typedef struct {
34  Pin irq_pin;
37  uint32_t irqs_index;
39
45 typedef struct {
49  const char *device_path;
50
54  sc16is752_mode mode;
55
60  uint32_t input_frequency;
61
65  const char *spi_path;
66
71  uint8_t spi_chip_select;
72
76  uint32_t spi_speed_hz;
77
82  const Pin irq_pin;
83
88  uint32_t server_index;
90
103 int atsam_sc16is752_spi_create(
106 );
107
108 #ifdef __cplusplus
109 }
110 #endif /* __cplusplus */
111
112 #endif /* LIBBSP_ARM_ATSAM_SC16IS752_H */
const Pin irq_pin
The interrupt pin, e.g. { PIO_PD28, PIOD, ID_PIOD, PIO_INPUT, PIO_IT_LOW_LEVEL }.
Definition: sc16is752.h:82
The index to identify the interrupt server used for interrupt processing.
Definition: sc16is752.h:88
Definition: deflate.c:115
An interrupt server entry.
Definition: irq-extension.h:337
Definition: pio.h:172
SC16IS752 SPI context.
Definition: sc16is752.h:181
const char * device_path
The device file path for the new device.
Definition: sc16is752.h:49
Header file for the Interrupt Manager Extension.
The SPI chip select (starts with 0, the SPI driver uses SPI_ChipSelect(1 << spi_chip_select)).
Definition: sc16is752.h:71
sc16is752_mode mode
The SC16IS752 mode.
Definition: sc16is752.h:54
The input frequency in Hertz of the SC16IS752 chip. See XTAL1 and XTAL2 pins.
Definition: sc16is752.h:60
The SC16IS752 device configuration.
Definition: sc16is752.h:45
The SC16IS752 device context.
Definition: sc16is752.h:32
const char * spi_path
The SPI bus device path.
Definition: sc16is752.h:65
An interrupt server action.
Definition: irq-extension.h:245
The SPI bus speed in Hertz.
Definition: sc16is752.h:76
