RTEMS  5.1
smc.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
36 #ifndef _SMC_
37 #define _SMC_
38
39 /*----------------------------------------------------------------------------
40  * Headers
41  *----------------------------------------------------------------------------*/
42 #include "chip.h"
43
44 /*----------------------------------------------------------------------------
45  * Types
46  *----------------------------------------------------------------------------*/
47 typedef union _SmcStatus {
48  uint8_t BStatus;
49  struct _SmcStatusBits {
50  uint8_t smcSts: 1,
51  xfrDone: 1,
52  cmdDone: 1,
53  rbEdge: 1,
54  hammingReady: 1;
55  } bStatus;
56 } SmcStatus;
57
58 /*----------------------------------------------------------------------------
59  * Definitions
60  *----------------------------------------------------------------------------*/
61 /*
62  * NFC definitions
63  */
64
66 #define NFC_SRAM_BASE_ADDRESS 0x200000
67
68 #define NFC_CMD_BASE_ADDR 0x70000000
69
70
71 /* -------- NFCADDR_CMD : NFC Address Command -------- */
72 #define NFCADDR_CMD_CMD1 (0xFFu << 2)
73 /* Command Register Value for Cycle 1 */
74 #define NFCADDR_CMD_CMD2 (0xFFu << 10)
75 /* Command Register Value for Cycle 2 */
76 #define NFCADDR_CMD_VCMD2 (0x1u << 18)
77 /* Valid Cycle 2 Command */
78 #define NFCADDR_CMD_ACYCLE (0x7u << 19)
79 /* Number of Address required for the current command */
80 #define NFCADDR_CMD_ACYCLE_NONE (0x0u << 19)
81 /* No address cycle */
82 #define NFCADDR_CMD_ACYCLE_ONE (0x1u << 19)
83 /* One address cycle */
84 #define NFCADDR_CMD_ACYCLE_TWO (0x2u << 19)
85 /* Two address cycles */
86 #define NFCADDR_CMD_ACYCLE_THREE (0x3u << 19)
87 /* Three address cycles */
88 #define NFCADDR_CMD_ACYCLE_FOUR (0x4u << 19)
89 /* Four address cycles */
90 #define NFCADDR_CMD_ACYCLE_FIVE (0x5u << 19)
91 /* Five address cycles */
92 #define NFCADDR_CMD_CSID (0x7u << 22)
93 /* Chip Select Identifier */
94 #define NFCADDR_CMD_CSID_0 (0x0u << 22)
95 /* CS0 */
96 #define NFCADDR_CMD_CSID_1 (0x1u << 22)
97 /* CS1 */
98 #define NFCADDR_CMD_CSID_2 (0x2u << 22)
99 /* CS2 */
100 #define NFCADDR_CMD_CSID_3 (0x3u << 22)
101 /* CS3 */
102 #define NFCADDR_CMD_CSID_4 (0x4u << 22)
103 /* CS4 */
104 #define NFCADDR_CMD_CSID_5 (0x5u << 22)
105 /* CS5 */
106 #define NFCADDR_CMD_CSID_6 (0x6u << 22)
107 /* CS6 */
108 #define NFCADDR_CMD_CSID_7 (0x7u << 22)
109 /* CS7 */
110 #define NFCADDR_CMD_DATAEN (0x1u << 25)
111 /* NFC Data Enable */
112 #define NFCADDR_CMD_DATADIS (0x0u << 25)
113 /* NFC Data disable */
114 #define NFCADDR_CMD_NFCRD (0x0u << 26)
115 /* NFC Read Enable */
116 #define NFCADDR_CMD_NFCWR (0x1u << 26)
117 /* NFC Write Enable */
118 #define NFCADDR_CMD_NFCCMD (0x1u << 27)
119 /* NFC Command Enable */
120
121 /*
122  * ECC definitions (Hsiao Code Errors)
123  */
124
126 #define Hsiao_ERROR_SINGLEBIT 1
127
129 #define Hsiao_ERROR_ECC 2
130
132 #define Hsiao_ERROR_MULTIPLEBITS 3
133
134 /*----------------------------------------------------------------------------
135  * Exported functions
136  *----------------------------------------------------------------------------*/
137
138 /*
139  * NFC functions
140  */
141
142 extern void SMC_NFC_Configure(uint32_t mode);
143 extern void SMC_NFC_Reset(void);
144 extern void SMC_NFC_EnableNfc(void);
145 extern void SMC_NFC_EnableSpareRead(void);
146 extern void SMC_NFC_DisableSpareRead(void);
147 extern void SMC_NFC_EnableSpareWrite(void);
148 extern void SMC_NFC_DisableSpareWrite(void);
149 extern uint8_t SMC_NFC_isSpareRead(void);
150 extern uint8_t SMC_NFC_isSpareWrite(void);
151 extern uint8_t SMC_NFC_isTransferComplete(void);
152 extern uint8_t SMC_NFC_isReadyBusy(void);
153 extern uint8_t SMC_NFC_isNfcBusy(void);
154 extern uint32_t SMC_NFC_GetStatus(void);
155
156 extern void SMC_NFC_SendCommand(uint32_t cmd, uint32_t addressCycle,
157  uint32_t cycle0);
158 extern void SMC_NFC_Wait_CommandDone(void);
159 extern void SMC_NFC_Wait_XfrDone(void);
160 extern void SMC_NFC_Wait_RBbusy(void);
161 extern void SMC_NFC_Wait_HammingReady(void);
162
163 extern void SMC_ECC_Configure(uint32_t type, uint32_t pageSize);
164 extern uint32_t SMC_ECC_GetCorrectoinType(void);
165 extern uint8_t SMC_ECC_GetStatus(uint8_t eccNumber);
166
167 extern void SMC_ECC_GetValue(uint32_t *ecc);
168 extern void SMC_ECC_GetEccParity(uint32_t pageDataSize, uint8_t *code,
169  uint8_t busWidth);
170 extern uint8_t SMC_ECC_VerifyHsiao(uint8_t *data, uint32_t size,
171  const uint8_t *originalCode, const uint8_t *verifyCode, uint8_t busWidth);
172
173 #endif /* #ifndef _SMC_ */
174
uint8_t rbEdge
Definition: smc.h:50
uint8_t hammingReady
Definition: smc.h:49
Definition: smc.h:47
uint8_t xfrDone
Definition: inftrees.h:24
uint8_t cmdDone
uint8_t smcSts
unsigned size
Definition: tte.h:74
