RTEMS  5.1
adc.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
49 #ifndef _ADC_
50 #define _ADC_
51
52 /*----------------------------------------------------------------------------
53  * Headers
54  *----------------------------------------------------------------------------*/
55 #include <assert.h>
56 #include <stdint.h>
57
58 /*------------------------------------------------------------------------------
59  * Definitions
60  *------------------------------------------------------------------------------*/
61
62 /* Max. ADC Clock Frequency (Hz) */
63 #define ADC_CLOCK_MAX 20000000
64
65 /* Max. normal ADC startup time (us) */
66 #define ADC_STARTUP_NORMAL_MAX 40
67 /* Max. fast ADC startup time (us) */
68 #define ADC_STARTUP_FAST_MAX 12
69
70 /* Definitions for ADC channels */
71 #define ADC_CHANNEL_0 0
72 #define ADC_CHANNEL_1 1
73 #define ADC_CHANNEL_2 2
74 #define ADC_CHANNEL_3 3
75 #define ADC_CHANNEL_4 4
76 #define ADC_CHANNEL_5 5
77 #define ADC_CHANNEL_6 6
78 #define ADC_CHANNEL_7 7
79 #define ADC_CHANNEL_8 8
80 #define ADC_CHANNEL_9 9
81 #define ADC_CHANNEL_10 10
82 #define ADC_CHANNEL_11 11
83 #define ADC_CHANNEL_12 12
84 #define ADC_CHANNEL_13 13
85 #define ADC_CHANNEL_14 14
86 #define ADC_CHANNEL_15 15
87
88 #ifdef __cplusplus
89 extern "C" {
90 #endif
91
92 /*------------------------------------------------------------------------------
93  * Macros function of register access
94  *------------------------------------------------------------------------------*/
95
96 #define ADC_GetModeReg(pAdc) ((pAdc)->ADC_MR)
97
98 #define ADC_StartConversion(pAdc) ((pAdc)->ADC_CR = ADC_CR_START)
99
100 #define ADC_SetCalibMode(pAdc) ((pAdc)->ADC_CR |= ADC_CR_AUTOCAL)
101
102 #define ADC_EnableChannel(pAdc, dwChannel) {\
103  (pAdc)->ADC_CHER = (1 << (dwChannel));\
104  }
105
106 #define ADC_DisableChannel(pAdc, dwChannel) {\
107  (pAdc)->ADC_CHDR = (1 << (dwChannel));\
108  }
109
110 #define ADC_EnableIt(pAdc, dwMode) {\
111  (pAdc)->ADC_IER = (dwMode);\
112  }
113
114 #define ADC_DisableIt(pAdc, dwMode) {\
115  (pAdc)->ADC_IDR = (dwMode);\
116  }
117
118 #define ADC_SetChannelGain(pAdc,dwMode) {\
119  (pAdc)->ADC_CGR = dwMode;\
120  }
121
122 #define ADC_SetChannelOffset(pAdc,dwMode) {\
123  (pAdc)->ADC_COR = dwMode;\
124  }
125
126 #define ADC_EnableDataReadyIt(pAdc) ((pAdc)->ADC_IER = ADC_IER_DRDY)
127
128 #define ADC_GetStatus(pAdc) ((pAdc)->ADC_ISR)
129
130 #define ADC_GetCompareMode(pAdc) (((pAdc)->ADC_EMR)& (ADC_EMR_CMPMODE_Msk))
131
132 #define ADC_GetChannelStatus(pAdc) ((pAdc)->ADC_CHSR)
133
134 #define ADC_GetInterruptMaskStatus(pAdc) ((pAdc)->ADC_IMR)
135
136 #define ADC_GetLastConvertedData(pAdc) ((pAdc)->ADC_LCDR)
137
138 /*------------------------------------------------------------------------------
139  * Exported functions
140  *------------------------------------------------------------------------------*/
141 extern void ADC_Initialize(Adc *pAdc, uint32_t dwId);
142 extern uint32_t ADC_SetClock(Adc *pAdc, uint32_t dwPres, uint32_t dwMck);
143 extern void ADC_SetTiming(Adc *pAdc, uint32_t dwStartup, uint32_t dwTracking,
144  uint32_t dwSettling);
145 extern void ADC_SetTrigger(Adc *pAdc, uint32_t dwTrgSel);
146 extern void ADC_SetTriggerMode(Adc *pAdc, uint32_t dwMode);
147 extern void ADC_SetLowResolution(Adc *pAdc, uint32_t bEnDis);
148 extern void ADC_SetSleepMode(Adc *pAdc, uint8_t bEnDis);
149 extern void ADC_SetFastWakeup(Adc *pAdc, uint8_t bEnDis);
150 extern void ADC_SetSequenceMode(Adc *pAdc, uint8_t bEnDis);
151 extern void ADC_SetSequence(Adc *pAdc, uint32_t dwSEQ1, uint32_t dwSEQ2);
152 extern void ADC_SetSequenceByList(Adc *pAdc, uint8_t ucChList[],
153  uint8_t ucNumCh);
154 extern void ADC_SetAnalogChange(Adc *pAdc, uint8_t bEnDis);
155 extern void ADC_SetTagEnable(Adc *pAdc, uint8_t bEnDis);
156 extern void ADC_SetCompareChannel(Adc *pAdc, uint32_t dwChannel);
157 extern void ADC_SetCompareMode(Adc *pAdc, uint32_t dwMode);
158 extern void ADC_SetComparisonWindow(Adc *pAdc, uint32_t dwHi_Lo);
159 extern uint8_t ADC_CheckConfiguration(Adc *pAdc, uint32_t dwMcK);
160 extern uint32_t ADC_GetConvertedData(Adc *pAdc, uint32_t dwChannel);
161 extern void ADC_SetTsAverage(Adc *pADC, uint32_t dwAvg2Conv);
162 extern uint32_t ADC_GetTsXPosition(Adc *pADC);
163 extern uint32_t ADC_GetTsYPosition(Adc *pADC);
164 extern uint32_t ADC_GetTsPressure(Adc *pADC);
165 extern void ADC_SetTsDebounce(Adc *pADC, uint32_t dwTime);
166 extern void ADC_SetTsPenDetect(Adc *pADC, uint8_t bEnDis);
167 extern void ADC_SetStartupTime(Adc *pAdc, uint32_t dwUs);
168 extern void ADC_SetTrackingTime(Adc *pAdc, uint32_t dwNs);
169 extern void ADC_SetTriggerPeriod(Adc *pAdc, uint32_t dwPeriod);
170 extern void ADC_SetTsMode(Adc *pADC, uint32_t dwMode);
171 extern void ADC_TsCalibration(Adc *pAdc);
172
173
174 #ifdef __cplusplus
175 }
176 #endif
177
178 #endif /* #ifndef _ADC_ */
179
Information for the Assert Handler.
