#define  | PMC_SCER   0x00    /* System Clock Enable Register */ |
#define  | PMC_SCDR   0x04    /* System Clock Disable Register */ |
#define  | PMC_SCSR   0x08    /* System Clock Status Register */ |
#define  | PMC_PCER   0x10    /* Peripheral Clock Enable Register */ |
#define  | PMC_PCDR   0x14    /* Peripheral Clock Disable Register */ |
#define  | PMC_PCSR   0x18    /* Peripheral Clock Status Register */ |
#define  | PMC_MOR   0x20    /* Main Oscillator Register */ |
#define  | PMC_MCFR   0x24    /* Main Clock  Frequency Register */ |
#define  | PMC_PLLAR   0x28    /* PLL A Register */ |
#define  | PMC_PLLBR   0x2C    /* PLL B Register */ |
#define  | PMC_MCKR   0x30    /* Master Clock Register */ |
#define  | PMC_PCKR0   0x40    /* Programmable Clock Register 0 */ |
#define  | PMC_PCKR1   0x44    /* Programmable Clock Register 1 */ |
#define  | PMC_PCKR2   0x48    /* Programmable Clock Register 2 */ |
#define  | PMC_PCKR3   0x4C    /* Programmable Clock Register 3 */ |
#define  | PMC_PCKR4   0x50    /* Programmable Clock Register 4 */ |
#define  | PMC_PCKR5   0x54    /* Programmable Clock Register 5 */ |
#define  | PMC_PCKR6   0x58    /* Programmable Clock Register 6 */ |
#define  | PMC_PCKR7   0x5C    /* Programmable Clock Register 7 */ |
#define  | PMC_IER   0x60    /* Interrupt Enable Register */ |
#define  | PMC_IDR   0x64    /* Interrupt Disable Register */ |
#define  | PMC_SR   0x68    /* Status Register */ |
#define  | PMC_IMR   0x6C    /* Interrupt Mask Register */ |
#define  | PMC_SCR_PCK7   BIT15 |
#define  | PMC_SCR_PCK6   BIT14 |
#define  | PMC_SCR_PCK5   BIT13 |
#define  | PMC_SCR_PCK4   BIT12 |
#define  | PMC_SCR_PCK3   BIT11 |
#define  | PMC_SCR_PCK2   BIT10 |
#define  | PMC_SCR_PCK1   BIT9 |
#define  | PMC_SCR_PCK0   BIT8 |
#define  | PMC_SCR_UHP   BIT4 |
#define  | PMC_SCR_MCKUDP   BIT2 |
#define  | PMC_SCR_UDP   BIT1 |
#define  | PMC_SCR_PCK   BIT0 |
#define  | PMC_PCR_PID_EMAC   BIT24     /* Ethernet Peripheral Clock */ |
#define  | PMC_PCR_PID_UHP   BIT23     /* USB Host Ports Peripheral Clock */ |
#define  | PMC_PCR_PID_TC5   BIT22     /* Timer/Counter 5 Peripheral Clock */ |
#define  | PMC_PCR_PID_TC4   BIT21     /* Timer/Counter 4 Peripheral Clock */ |
#define  | PMC_PCR_PID_TC3   BIT20     /* Timer/Counter 3 Peripheral Clock */ |
#define  | PMC_PCR_PID_TC2   BIT19     /* Timer/Counter 2 Peripheral Clock */ |
#define  | PMC_PCR_PID_TC1   BIT18     /* Timer/Counter 1 Peripheral Clock */ |
#define  | PMC_PCR_PID_TC0   BIT17     /* Timer/Counter 0 Peripheral Clock */ |
#define  | PMC_PCR_PID_SSC2   BIT16     /* Synchronous Serial 2 Peripheral Clock */ |
#define  | PMC_PCR_PID_SSC1   BIT15     /* Synchronous Serial 1 Peripheral Clock */ |
#define  | PMC_PCR_PID_SSC0   BIT14     /* Synchronous Serial 0 Peripheral Clock */ |
#define  | PMC_PCR_PID_SPI   BIT13     /* Serial Peripheral Interface Peripheral Clock */ |
#define  | PMC_PCR_PID_TWI   BIT12     /* Two-Wire Interface Peripheral Clock */ |
#define  | PMC_PCR_PID_UDP   BIT11     /* USB Device Port Peripheral Clock */ |
#define  | PMC_PCR_PID_MCI   BIT10     /* MMC/SD Card Peripheral Clock */ |
#define  | PMC_PCR_PID_US3   BIT9      /* USART 3 Peripheral Clock */ |
#define  | PMC_PCR_PID_US2   BIT8      /* USART 2 Peripheral Clock */ |
#define  | PMC_PCR_PID_US1   BIT7      /* USART 1 Peripheral Clock */ |
#define  | PMC_PCR_PID_US0   BIT6      /* USART 0 Peripheral Clock */ |
#define  | PMC_PCR_PID_PIOD   BIT5      /* Parallel I/O D Peripheral Clock */ |
#define  | PMC_PCR_PID_PIOC   BIT4      /* Parallel I/O C Peripheral Clock */ |
#define  | PMC_PCR_PID_PIOB   BIT3      /* Parallel I/O B Peripheral Clock */ |
#define  | PMC_PCR_PID_PIOA   BIT2      /* Parallel I/O A Peripheral Clock */ |
#define  | PMC_MOR_MOSCEN   BIT0 |
#define  | PMC_MCFR_MAINRDY   BIT16 |
#define  | PMC_PLLAR_MUST_SET   BIT29           /* This bit must be set according to the docs */ |
#define  | PMC_PLLAR_MUL(_x_)   ((_x_ & 0x7ff) << 16)   /* Multiplier    */ |
#define  | PMC_PLLAR_MUL_MASK   (0x7ff << 16)   /* Multiplier mask */ |
#define  | PMC_PLLAR_OUT_80_160   (0 << 14)             /* select when PLL frequency is 80-160 Mhz */ |
#define  | PMC_PLLAR_OUT_150_240   (2 << 14)             /* select when PLL frequency is 150-240 Mhz */ |
#define  | PMC_PLLAR_DIV(_x_)   ((_x_ & 0xff) << 0)       /* Divider */ |
#define  | PMC_PLLAR_DIV_MASK   (0xff)    /* Divider mask */ |
#define  | PMC_PLLBR_USB_96M   BIT28           /* Set when PLL is 96Mhz to divide it by 2 for USB */ |
#define  | PMC_PLLBR_MUL(_x_)   ((_x_ & 0x7ff) << 16)   /* Multiplier    */ |
#define  | PMC_PLLBR_MUL_MASK   (0x7ff << 16)   /* Multiplier mask */ |
#define  | PMC_PLLBR_OUT_80_160   (0 << 14)         /* select when PLL frequency is 80-160 Mhz */ |
#define  | PMC_PLLBR_OUT_150_240   (2 << 14)        /* select when PLL frequency is 150-240 Mhz */ |
#define  | PMC_PLLBR_DIV(_x_)   ((_x_ & 0xff) << 0)       /* Divider */ |
#define  | PMC_PLLBR_DIV_MASK   (0xff)    /* Divider mask */ |
#define  | PMC_MCKR_MDIV_MASK   (3 << 8)        /* for masking out the MDIV field */ |
#define  | PMC_MCKR_MDIV_1   (0 << 8)        /* MCK = Core/1 */ |
#define  | PMC_MCKR_MDIV_2   (1 << 8)        /* MCK = Core/2 */ |
#define  | PMC_MCKR_MDIV_3   (2 << 8)        /* MCK = Core/3 */ |
#define  | PMC_MCKR_MDIV_4   (3 << 8)        /* MCK = Core/4 */ |
#define  | PMC_MCKR_PRES_MASK   (7 << 2)        /* for masking out the PRES field */ |
#define  | PMC_MCKR_PRES_1   (0 << 2)        /* Core = CSS/1 */ |
#define  | PMC_MCKR_PRES_2   (1 << 2)        /* Core = CSS/2 */ |
#define  | PMC_MCKR_PRES_4   (2 << 2)        /* Core = CSS/4 */ |
#define  | PMC_MCKR_PRES_8   (3 << 2)        /* Core = CSS/8 */ |
#define  | PMC_MCKR_PRES_16   (4 << 2)        /* Core = CSS/16 */ |
#define  | PMC_MCKR_PRES_32   (5 << 2)        /* Core = CSS/32 */ |
#define  | PMC_MCKR_PRES_64   (6 << 2)        /* Core = CSS/64 */ |
#define  | PMC_MCKR_CSS_MASK   (3 << 0)        /* for masking out the CSS field */ |
#define  | PMC_MCKR_CSS_SLOW   (0 << 0)        /* Core Source = Slow Clock */ |
#define  | PMC_MCKR_CSS_MAIN   (1 << 0)        /* Core Source = Main Oscillator */ |
#define  | PMC_MCKR_CSS_PLLA   (2 << 0)        /* Core Source = PLL A */ |
#define  | PMC_MCKR_CSS_PLLB   (3 << 0)        /* Core Source = PLL B */ |
#define  | PMC_PCKR_PRES_1   (0 << 2)        /* Peripheral Clock = CSS/1 */ |
#define  | PMC_PCKR_PRES_2   (1 << 2)        /* Peripheral Clock = CSS/2 */ |
#define  | PMC_PCKR_PRES_4   (2 << 2)        /* Peripheral Clock = CSS/4 */ |
#define  | PMC_PCKR_PRES_8   (3 << 2)        /* Peripheral Clock = CSS/8 */ |
#define  | PMC_PCKR_PRES_16   (4 << 2)        /* Peripheral Clock = CSS/16 */ |
#define  | PMC_PCKR_PRES_32   (5 << 2)        /* Peripheral Clock = CSS/32 */ |
#define  | PMC_PCKR_PRES_64   (6 << 2)        /* Peripheral Clock = CSS/64 */ |
#define  | PMC_PCKR_CSS_SLOW   (0 << 0)        /* Peripheral Clock Source = Slow Clock */ |
#define  | PMC_PCKR_CSS_MAIN   (1 << 0)        /* Peripheral Clock Source = Main Oscillator */ |
#define  | PMC_PCKR_CSS_PLLA   (2 << 0)        /* Peripheral Clock Source = PLL A */ |
#define  | PMC_PCKR_CSS_PLLB   (3 << 0)        /* Peripheral Clock Source = PLL B */ |
#define  | PMC_INT_PCK7_RDY   BIT15 |
#define  | PMC_INT_PCK6_RDY   BIT14 |
#define  | PMC_INT_PCK5_RDY   BIT13 |
#define  | PMC_INT_PCK4_RDY   BIT12 |
#define  | PMC_INT_PCK3_RDY   BIT11 |
#define  | PMC_INT_PCK2_RDY   BIT10 |
#define  | PMC_INT_PCK1_RDY   BIT9 |
#define  | PMC_INT_PCK0_RDY   BIT8 |
#define  | PMC_INT_MCK_RDY   BIT3 |
#define  | PMC_INT_LOCKB   BIT2 |
#define  | PMC_INT_LCKA   BIT1 |
#define  | PMC_INT_MOSCS   BIT0 |
AT91RM9200 Power Management and Clock definitions.
