#define  | DBGU_CR   0x00            /* Control Register */ |
#define  | DBGU_MR   0x04            /* Mode Register */ |
#define  | DBGU_IER   0x08            /* Interrupt Enable Register */ |
#define  | DBGU_IDR   0x0C            /* Interrupt Disable Register */ |
#define  | DBGU_IMR   0x10            /* Interrupt Mask Register */ |
#define  | DBGU_SR   0x14            /* Channel Status Register */ |
#define  | DBGU_RHR   0x18            /* Receiver Holding Register */ |
#define  | DBGU_THR   0x1C            /* Transmitter Holding Register */ |
#define  | DBGU_BRGR   0x20            /* Baud Rate Generator Register */ |
#define  | DBGU_C1R   0x40            /* Chip ID1 Register */ |
#define  | DBGU_C2R   0x44            /* Chip ID2 Register */ |
#define  | DBGU_FNTR   0x48            /* Force NTRST Register */ |
#define  | DBGU_CR_RSTRX   BIT2            /* 1 = Reset and disable receiver */ |
#define  | DBGU_CR_RSTTX   BIT3            /* 1 = Reset and disable transmitter */ |
#define  | DBGU_CR_RXEN   BIT4            /* 1 = Receiver enable */ |
#define  | DBGU_CR_RXDIS   BIT5            /* 1 = Receiver disable */ |
#define  | DBGU_CR_TXEN   BIT6            /* 1 = Transmitter enable */ |
#define  | DBGU_CR_TXDIS   BIT7            /* 1 = Transmitter disable */ |
#define  | DBGU_CR_RSTSTA   BIT8            /* 1 = Reset PARE, FRAME and OVRE in DBGU_SR. */ |
#define  | DBGU_MR_PAR_EVEN   (0x0 <<  9) /* Even Parity */ |
#define  | DBGU_MR_PAR_ODD   (0x1 <<  9) /* Odd Parity */ |
#define  | DBGU_MR_PAR_SPACE   (0x2 <<  9) /* Parity forced to 0 (Space) */ |
#define  | DBGU_MR_PAR_MARK   (0x3 <<  9) /* Parity forced to 1 (Mark) */ |
#define  | DBGU_MR_PAR_NONE   (0x4 <<  9) /* No Parity */ |
#define  | DBGU_MR_PAR_MDROP   (0x6 <<  9) /* Multi-drop mode */ |
#define  | DBGU_MR_CHMODE_NORM   (0x0 << 14) /* Normal Mode */ |
#define  | DBGU_MR_CHMODE_AUTO   (0x1 << 14) /* Auto Echo: RXD drives TXD */ |
#define  | DBGU_MR_CHMODE_LOC   (0x2 << 14) /* Local Loopback: TXD drives RXD */ |
#define  | DBGU_MR_CHMODE_REM   (0x3 << 14) /* Remote Loopback: RXD pin connected to TXD pin. */ |
#define  | DBGU_INT_RXRDY   BIT0        /* RXRDY Interrupt */ |
#define  | DBGU_INT_TXRDY   BIT1        /* TXRDY Interrupt */ |
#define  | DBGU_INT_ENDRX   BIT3        /* End of Receive Transfer Interrupt */ |
#define  | DBGU_INT_ENDTX   BIT4        /* End of Transmit Interrupt */ |
#define  | DBGU_INT_OVRE   BIT5        /* Overrun Interrupt */ |
#define  | DBGU_INT_FRAME   BIT6        /* Framing Error Interrupt */ |
#define  | DBGU_INT_PARE   BIT7        /* Parity Error Interrupt */ |
#define  | DBGU_INT_TXEMPTY   BIT9        /* TXEMPTY Interrupt */ |
#define  | DBGU_INT_TXBUFE   BIT11       /* TXBUFE Interrupt */ |
#define  | DBGU_INT_RXBUFF   BIT12       /* RXBUFF Interrupt */ |
#define  | DBGU_INT_COMM_TX   BIT30       /* COMM_TX Interrupt */ |
#define  | DBGU_INT_COMM_RX   BIT31       /* COMM_RX Interrupt */ |
#define  | DBGU_INT_ALL   0xC0001AFB  /* all assigned bits */ |
#define  | DBGU_FNTR_NTRST   BIT0    /* 1 = Force NTRST low in JTAG */ |
Atmel AT91RM9200_DBGU Register definitions.
