21 #ifndef RTEMS_SCORE_ARMV7M_H    22 #define RTEMS_SCORE_ARMV7M_H    24 #include <rtems/score/cpu.h>    30 #ifdef ARM_MULTILIB_ARCH_V7M    33 #define ARMV7M_CPACR 0xe000ed88    44 typedef void (*ARMV7M_Exception_handler)(void);
    51   uint32_t register_r12;
    54   uint32_t register_xpsr;
    55 #ifdef ARM_MULTILIB_VFP    66   uint32_t register_s10;
    67   uint32_t register_s11;
    68   uint32_t register_s12;
    69   uint32_t register_s13;
    70   uint32_t register_s14;
    71   uint32_t register_s15;
    72   uint32_t register_fpscr;
    75 } ARMV7M_Exception_frame;
    82 } ARMV7M_DWT_comparator;
    85 #define ARMV7M_DWT_CTRL_NOCYCCNT (1U << 25)    86 #define ARMV7M_DWT_CTRL_CYCCNTENA (1U << 0)    95   ARMV7M_DWT_comparator comparator[249];
    96 #define ARMV7M_DWT_LAR_UNLOCK_MAGIC 0xc5acce55U   104 #define ARMV7M_SCB_ICSR_NMIPENDSET (1U << 31)   105 #define ARMV7M_SCB_ICSR_PENDSVSET (1U << 28)   106 #define ARMV7M_SCB_ICSR_PENDSVCLR (1U << 27)   107 #define ARMV7M_SCB_ICSR_PENDSTSET (1U << 26)   108 #define ARMV7M_SCB_ICSR_PENDSTCLR (1U << 25)   109 #define ARMV7M_SCB_ICSR_ISRPREEMPT (1U << 23)   110 #define ARMV7M_SCB_ICSR_ISRPENDING (1U << 22)   111 #define ARMV7M_SCB_ICSR_VECTPENDING_GET(reg) (((reg) >> 12) & 0x1ffU)   112 #define ARMV7M_SCB_ICSR_RETTOBASE (1U << 11)   113 #define ARMV7M_SCB_ICSR_VECTACTIVE_GET(reg) ((reg) & 0x1ffU)   116   ARMV7M_Exception_handler *vtor;
   118 #define ARMV7M_SCB_AIRCR_VECTKEY (0x05fa << 16)   119 #define ARMV7M_SCB_AIRCR_ENDIANESS (1U << 15)   120 #define ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT 8   121 #define ARMV7M_SCB_AIRCR_PRIGROUP_MASK \   122   ((0x7U) << ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT)   123 #define ARMV7M_SCB_AIRCR_PRIGROUP(val) \   124   (((val) << ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT) & ARMV7M_SCB_AIRCR_PRIGROUP_MASK)   125 #define ARMV7M_SCB_AIRCR_PRIGROUP_GET(reg) \   126   (((val) & ARMV7M_SCB_AIRCR_PRIGROUP_MASK) >> ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT)   127 #define ARMV7M_SCB_AIRCR_PRIGROUP_SET(reg, val) \   128   (((reg) & ~ARMV7M_SCB_AIRCR_PRIGROUP_MASK) | ARMV7M_SCB_AIRCR_PRIGROUP(val))   129 #define ARMV7M_SCB_AIRCR_SYSRESETREQ (1U << 2)   130 #define ARMV7M_SCB_AIRCR_VECTCLRACTIVE (1U << 1)   131 #define ARMV7M_SCB_AIRCR_VECTRESET (1U << 0)   138 #define ARMV7M_SCB_SHCSR_USGFAULTENA (1U << 18)   139 #define ARMV7M_SCB_SHCSR_BUSFAULTENA (1U << 17)   140 #define ARMV7M_SCB_SHCSR_MEMFAULTENA (1U << 16)   149   uint32_t reserved_e000ed40[18];
   151   uint32_t reserved_e000ed8c[106];
   160 #define ARMV7M_SYSTICK_CSR_COUNTFLAG (1U << 16)   161 #define ARMV7M_SYSTICK_CSR_CLKSOURCE (1U << 2)   162 #define ARMV7M_SYSTICK_CSR_TICKINT (1U << 1)   163 #define ARMV7M_SYSTICK_CSR_ENABLE (1U << 0)   169 #define ARMV7M_SYSTICK_CALIB_NOREF (1U << 31)   170 #define ARMV7M_SYSTICK_CALIB_SKEW (1U << 30)   171 #define ARMV7M_SYSTICK_CALIB_TENMS_GET(reg) ((reg) & 0xffffffU)   177   uint32_t reserved_0 [24];
   179   uint32_t reserved_1 [24];
   181   uint32_t reserved_2 [24];
   183   uint32_t reserved_3 [24];
   185   uint32_t reserved_4 [56];
   187   uint32_t reserved_5 [644];
   192 #define ARMV7M_MPU_TYPE_IREGION_GET(reg) (((reg) >> 16) & 0xffU)   193 #define ARMV7M_MPU_TYPE_DREGION_GET(reg) (((reg) >> 8) & 0xffU)   194 #define ARMV7M_MPU_TYPE_SEPARATE (1U << 0)   197 #define ARMV7M_MPU_CTRL_PRIVDEFENA (1U << 2)   198 #define ARMV7M_MPU_CTRL_HFNMIENA (1U << 1)   199 #define ARMV7M_MPU_CTRL_ENABLE (1U << 0)   204 #define ARMV7M_MPU_RBAR_ADDR_SHIFT 5   205 #define ARMV7M_MPU_RBAR_ADDR_MASK \   206   ((0x7ffffffU) << ARMV7M_MPU_RBAR_ADDR_SHIFT)   207 #define ARMV7M_MPU_RBAR_ADDR(val) \   208   (((val) << ARMV7M_MPU_RBAR_ADDR_SHIFT) & ARMV7M_MPU_RBAR_ADDR_MASK)   209 #define ARMV7M_MPU_RBAR_ADDR_GET(reg) \   210   (((val) & ARMV7M_MPU_RBAR_ADDR_MASK) >> ARMV7M_MPU_RBAR_ADDR_SHIFT)   211 #define ARMV7M_MPU_RBAR_ADDR_SET(reg, val) \   212   (((reg) & ~ARMV7M_MPU_RBAR_ADDR_MASK) | ARMV7M_MPU_RBAR_ADDR(val))   213 #define ARMV7M_MPU_RBAR_VALID (1U << 4)   214 #define ARMV7M_MPU_RBAR_REGION_SHIFT 0   215 #define ARMV7M_MPU_RBAR_REGION_MASK \   216   ((0xfU) << ARMV7M_MPU_RBAR_REGION_SHIFT)   217 #define ARMV7M_MPU_RBAR_REGION(val) \   218   (((val) << ARMV7M_MPU_RBAR_REGION_SHIFT) & ARMV7M_MPU_RBAR_REGION_MASK)   219 #define ARMV7M_MPU_RBAR_REGION_GET(reg) \   220   (((val) & ARMV7M_MPU_RBAR_REGION_MASK) >> ARMV7M_MPU_RBAR_REGION_SHIFT)   221 #define ARMV7M_MPU_RBAR_REGION_SET(reg, val) \   222   (((reg) & ~ARMV7M_MPU_RBAR_REGION_MASK) | ARMV7M_MPU_RBAR_REGION(val))   225 #define ARMV7M_MPU_RASR_XN (1U << 28)   226 #define ARMV7M_MPU_RASR_AP_SHIFT 24   227 #define ARMV7M_MPU_RASR_AP_MASK \   228   ((0x7U) << ARMV7M_MPU_RASR_AP_SHIFT)   229 #define ARMV7M_MPU_RASR_AP(val) \   230   (((val) << ARMV7M_MPU_RASR_AP_SHIFT) & ARMV7M_MPU_RASR_AP_MASK)   231 #define ARMV7M_MPU_RASR_AP_GET(reg) \   232   (((val) & ARMV7M_MPU_RASR_AP_MASK) >> ARMV7M_MPU_RASR_AP_SHIFT)   233 #define ARMV7M_MPU_RASR_AP_SET(reg, val) \   234   (((reg) & ~ARMV7M_MPU_RASR_AP_MASK) | ARMV7M_MPU_RASR_AP(val))   235 #define ARMV7M_MPU_RASR_TEX_SHIFT 19   236 #define ARMV7M_MPU_RASR_TEX_MASK \   237   ((0x7U) << ARMV7M_MPU_RASR_TEX_SHIFT)   238 #define ARMV7M_MPU_RASR_TEX(val) \   239   (((val) << ARMV7M_MPU_RASR_TEX_SHIFT) & ARMV7M_MPU_RASR_TEX_MASK)   240 #define ARMV7M_MPU_RASR_TEX_GET(reg) \   241   (((val) & ARMV7M_MPU_RASR_TEX_MASK) >> ARMV7M_MPU_RASR_TEX_SHIFT)   242 #define ARMV7M_MPU_RASR_TEX_SET(reg, val) \   243   (((reg) & ~ARMV7M_MPU_RASR_TEX_MASK) | ARMV7M_MPU_RASR_TEX(val))   244 #define ARMV7M_MPU_RASR_S (1U << 18)   245 #define ARMV7M_MPU_RASR_C (1U << 17)   246 #define ARMV7M_MPU_RASR_B (1U << 16)   247 #define ARMV7M_MPU_RASR_SRD_SHIFT 8   248 #define ARMV7M_MPU_RASR_SRD_MASK \   249   ((0xffU) << ARMV7M_MPU_RASR_SRD_SHIFT)   250 #define ARMV7M_MPU_RASR_SRD(val) \   251   (((val) << ARMV7M_MPU_RASR_SRD_SHIFT) & ARMV7M_MPU_RASR_SRD_MASK)   252 #define ARMV7M_MPU_RASR_SRD_GET(reg) \   253   (((val) & ARMV7M_MPU_RASR_SRD_MASK) >> ARMV7M_MPU_RASR_SRD_SHIFT)   254 #define ARMV7M_MPU_RASR_SRD_SET(reg, val) \   255   (((reg) & ~ARMV7M_MPU_RASR_SRD_MASK) | ARMV7M_MPU_RASR_SRD(val))   256 #define ARMV7M_MPU_RASR_SIZE_SHIFT 1   257 #define ARMV7M_MPU_RASR_SIZE_MASK \   258   ((0x1fU) << ARMV7M_MPU_RASR_SIZE_SHIFT)   259 #define ARMV7M_MPU_RASR_SIZE(val) \   260   (((val) << ARMV7M_MPU_RASR_SIZE_SHIFT) & ARMV7M_MPU_RASR_SIZE_MASK)   261 #define ARMV7M_MPU_RASR_SIZE_GET(reg) \   262   (((val) & ARMV7M_MPU_RASR_SIZE_MASK) >> ARMV7M_MPU_RASR_SIZE_SHIFT)   263 #define ARMV7M_MPU_RASR_SIZE_SET(reg, val) \   264   (((reg) & ~ARMV7M_MPU_RASR_SIZE_MASK) | ARMV7M_MPU_RASR_SIZE(val))   265 #define ARMV7M_MPU_RASR_ENABLE (1U << 0)   277   ARMV7M_MPU_AP_PRIV_NO_USER_NO,
   278   ARMV7M_MPU_AP_PRIV_RW_USER_NO,
   279   ARMV7M_MPU_AP_PRIV_RW_USER_RO,
   280   ARMV7M_MPU_AP_PRIV_RW_USER_RW,
   281   ARMV7M_MPU_AP_PRIV_RO_USER_NO = 0x5,
   282   ARMV7M_MPU_AP_PRIV_RO_USER_RO,
   283 } ARMV7M_MPU_Access_permissions;
   286   ARMV7M_MPU_ATTR_R = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RO_USER_NO)
   287     | ARMV7M_MPU_RASR_C | ARMV7M_MPU_RASR_XN,
   288   ARMV7M_MPU_ATTR_RW = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RW_USER_NO)
   289     | ARMV7M_MPU_RASR_C | ARMV7M_MPU_RASR_XN | ARMV7M_MPU_RASR_B,
   290   ARMV7M_MPU_ATTR_RWX = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RW_USER_NO)
   291     | ARMV7M_MPU_RASR_C | ARMV7M_MPU_RASR_B,
   292   ARMV7M_MPU_ATTR_X = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_NO_USER_NO)
   294   ARMV7M_MPU_ATTR_RX = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RO_USER_NO)
   296   ARMV7M_MPU_ATTR_IO = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RW_USER_NO)
   297     | ARMV7M_MPU_RASR_XN,
   298 } ARMV7M_MPU_Attributes;
   301   ARMV7M_MPU_SIZE_32_B = 0x4,
   302   ARMV7M_MPU_SIZE_64_B,
   303   ARMV7M_MPU_SIZE_128_B,
   304   ARMV7M_MPU_SIZE_256_B,
   305   ARMV7M_MPU_SIZE_512_B,
   306   ARMV7M_MPU_SIZE_1_KB,
   307   ARMV7M_MPU_SIZE_2_KB,
   308   ARMV7M_MPU_SIZE_4_KB,
   309   ARMV7M_MPU_SIZE_8_KB,
   310   ARMV7M_MPU_SIZE_16_KB,
   311   ARMV7M_MPU_SIZE_32_KB,
   312   ARMV7M_MPU_SIZE_64_KB,
   313   ARMV7M_MPU_SIZE_128_KB,
   314   ARMV7M_MPU_SIZE_256_KB,
   315   ARMV7M_MPU_SIZE_512_KB,
   316   ARMV7M_MPU_SIZE_1_MB,
   317   ARMV7M_MPU_SIZE_2_MB,
   318   ARMV7M_MPU_SIZE_4_MB,
   319   ARMV7M_MPU_SIZE_8_MB,
   320   ARMV7M_MPU_SIZE_16_MB,
   321   ARMV7M_MPU_SIZE_32_MB,
   322   ARMV7M_MPU_SIZE_64_MB,
   323   ARMV7M_MPU_SIZE_128_MB,
   324   ARMV7M_MPU_SIZE_256_MB,
   325   ARMV7M_MPU_SIZE_512_MB,
   326   ARMV7M_MPU_SIZE_1_GB,
   327   ARMV7M_MPU_SIZE_2_GB,
   336 #define ARMV7M_MPU_REGION_INITIALIZER(idx, addr, size, attr) \   338     ((addr) & ARMV7M_MPU_RBAR_ADDR_MASK) \   339       | ARMV7M_MPU_RBAR_VALID \   340       | ARMV7M_MPU_RBAR_REGION(idx), \   341     ARMV7M_MPU_RASR_SIZE(size) | (attr) | ARMV7M_MPU_RASR_ENABLE \   344 #define ARMV7M_MPU_REGION_DISABLED_INITIALIZER(idx) \   346     ARMV7M_MPU_RBAR_VALID | ARMV7M_MPU_RBAR_REGION(idx), \   354 #define ARMV7M_DEBUG_DEMCR_VC_CORERESET (1U << 0)   355 #define ARMV7M_DEBUG_DEMCR_VC_MMERR (1U << 4)   356 #define ARMV7M_DEBUG_DEMCR_VC_NOCPERR (1U << 5)   357 #define ARMV7M_DEBUG_DEMCR_VC_CHKERR (1U << 6)   358 #define ARMV7M_DEBUG_DEMCR_VC_STATERR (1U << 7)   359 #define ARMV7M_DEBUG_DEMCR_VC_BUSERR (1U << 8)   360 #define ARMV7M_DEBUG_DEMCR_VC_INTERR (1U << 9)   361 #define ARMV7M_DEBUG_DEMCR_VC_HARDERR (1U << 10)   362 #define ARMV7M_DEBUG_DEMCR_MON_EN (1U << 16)   363 #define ARMV7M_DEBUG_DEMCR_MON_PEND (1U << 17)   364 #define ARMV7M_DEBUG_DEMCR_MON_STEP (1U << 18)   365 #define ARMV7M_DEBUG_DEMCR_MON_REQ (1U << 19)   366 #define ARMV7M_DEBUG_DEMCR_TRCENA (1U << 24)   370 #define ARMV7M_DWT_BASE 0xe0001000   371 #define ARMV7M_SCS_BASE 0xe000e000   372 #define ARMV7M_ICTAC_BASE (ARMV7M_SCS_BASE + 0x0)   373 #define ARMV7M_SYSTICK_BASE (ARMV7M_SCS_BASE + 0x10)   374 #define ARMV7M_NVIC_BASE (ARMV7M_SCS_BASE + 0x100)   375 #define ARMV7M_SCB_BASE (ARMV7M_SCS_BASE + 0xd00)   376 #define ARMV7M_MPU_BASE (ARMV7M_SCS_BASE + 0xd90)   377 #define ARMV7M_DEBUG_BASE (ARMV7M_SCS_BASE + 0xdf0)   379 #define _ARMV7M_DWT \   380   ((volatile ARMV7M_DWT *) ARMV7M_DWT_BASE)   381 #define _ARMV7M_ICTAC \   382   ((volatile ARMV7M_ICTAC *) ARMV7M_ICTAC_BASE)   383 #define _ARMV7M_SCB \   384   ((volatile ARMV7M_SCB *) ARMV7M_SCB_BASE)   385 #define _ARMV7M_Systick \   386   ((volatile ARMV7M_Systick *) ARMV7M_SYSTICK_BASE)   387 #define _ARMV7M_NVIC \   388   ((volatile ARMV7M_NVIC *) ARMV7M_NVIC_BASE)   389 #define _ARMV7M_MPU \   390   ((volatile ARMV7M_MPU *) ARMV7M_MPU_BASE)   391 #define _ARMV7M_DEBUG \   392   ((volatile ARMV7M_DEBUG *) ARMV7M_DEBUG_BASE)   394 #define ARMV7M_VECTOR_MSP 0   395 #define ARMV7M_VECTOR_RESET 1   396 #define ARMV7M_VECTOR_NMI 2   397 #define ARMV7M_VECTOR_HARD_FAULT 3   398 #define ARMV7M_VECTOR_MEM_MANAGE 4   399 #define ARMV7M_VECTOR_BUS_FAULT 5   400 #define ARMV7M_VECTOR_USAGE_FAULT 6   401 #define ARMV7M_VECTOR_SVC 11   402 #define ARMV7M_VECTOR_DEBUG_MONITOR 12   403 #define ARMV7M_VECTOR_PENDSV 14   404 #define ARMV7M_VECTOR_SYSTICK 15   405 #define ARMV7M_VECTOR_IRQ(n) ((n) + 16)   406 #define ARMV7M_IRQ_OF_VECTOR(n) ((n) - 16)   408 #define ARMV7M_EXCEPTION_PRIORITY_LOWEST 255   410 static inline bool _ARMV7M_Is_vector_an_irq(
int vector )
   413   return vector > ARMV7M_VECTOR_SYSTICK;
   416 static inline uint32_t _ARMV7M_Get_basepri(
void)
   419   __asm__ volatile (
"mrs %[val], basepri\n" : [val]
"=&r" (val));
   423 static inline void _ARMV7M_Set_basepri(uint32_t val)
   425   __asm__ volatile (
"msr basepri, %[val]\n" : : [val]
"r" (val));
   428 static inline uint32_t _ARMV7M_Get_primask(
void)
   431   __asm__ volatile (
"mrs %[val], primask\n" : [val]
"=&r" (val));
   435 static inline void _ARMV7M_Set_primask(uint32_t val)
   437   __asm__ volatile (
"msr primask, %[val]\n" : : [val]
"r" (val));
   440 static inline uint32_t _ARMV7M_Get_faultmask(
void)
   443   __asm__ volatile (
"mrs %[val], faultmask\n" : [val]
"=&r" (val));
   447 static inline void _ARMV7M_Set_faultmask(uint32_t val)
   449   __asm__ volatile (
"msr faultmask, %[val]\n" : : [val]
"r" (val));
   452 static inline uint32_t _ARMV7M_Get_control(
void)
   455   __asm__ volatile (
"mrs %[val], control\n" : [val]
"=&r" (val));
   459 static inline void _ARMV7M_Set_control(uint32_t val)
   461   __asm__ volatile (
"msr control, %[val]\n" : : [val]
"r" (val));
   464 static inline uint32_t _ARMV7M_Get_MSP(
void)
   467   __asm__ volatile (
"mrs %[val], msp\n" : [val]
"=&r" (val));
   471 static inline void _ARMV7M_Set_MSP(uint32_t val)
   473   __asm__ volatile (
"msr msp, %[val]\n" : : [val]
"r" (val));
   476 static inline uint32_t _ARMV7M_Get_PSP(
void)
   479   __asm__ volatile (
"mrs %[val], psp\n" : [val]
"=&r" (val));
   483 static inline void _ARMV7M_Set_PSP(uint32_t val)
   485   __asm__ volatile (
"msr psp, %[val]\n" : : [val]
"r" (val));
   488 static inline uint32_t _ARMV7M_Get_XPSR(
void)
   491   __asm__ volatile (
"mrs %[val], xpsr\n" : [val]
"=&r" (val));
   495 static inline bool _ARMV7M_NVIC_Is_enabled(
int irq )
   497   int index = irq >> 5;
   498   uint32_t bit = 1U << (irq & 0x1f);
   500   return (_ARMV7M_NVIC->iser [index] & bit) != 0;
   503 static inline void _ARMV7M_NVIC_Set_enable(
int irq )
   505   int index = irq >> 5;
   506   uint32_t bit = 1U << (irq & 0x1f);
   508   _ARMV7M_NVIC->iser [index] = bit;
   511 static inline void _ARMV7M_NVIC_Clear_enable(
int irq )
   513   int index = irq >> 5;
   514   uint32_t bit = 1U << (irq & 0x1f);
   516   _ARMV7M_NVIC->icer [index] = bit;
   519 static inline bool _ARMV7M_NVIC_Is_pending(
int irq )
   521   int index = irq >> 5;
   522   uint32_t bit = 1U << (irq & 0x1f);
   524   return (_ARMV7M_NVIC->ispr [index] & bit) != 0;
   527 static inline void _ARMV7M_NVIC_Set_pending(
int irq )
   529   int index = irq >> 5;
   530   uint32_t bit = 1U << (irq & 0x1f);
   532   _ARMV7M_NVIC->ispr [index] = bit;
   535 static inline void _ARMV7M_NVIC_Clear_pending(
int irq )
   537   int index = irq >> 5;
   538   uint32_t bit = 1U << (irq & 0x1f);
   540   _ARMV7M_NVIC->icpr [index] = bit;
   543 static inline bool _ARMV7M_NVIC_Is_active(
int irq )
   545   int index = irq >> 5;
   546   uint32_t bit = 1U << (irq & 0x1f);
   548   return (_ARMV7M_NVIC->iabr [index] & bit) != 0;
   551 static inline void _ARMV7M_NVIC_Set_priority(
int irq,
int priority )
   553   _ARMV7M_NVIC->ipr [irq] = (uint8_t) priority;
   556 static inline int _ARMV7M_NVIC_Get_priority(
int irq )
   558   return _ARMV7M_NVIC->ipr [irq];
   561 static inline bool _ARMV7M_DWT_Enable_CYCCNT(
void )
   566   demcr = _ARMV7M_DEBUG->demcr;
   567   _ARMV7M_DEBUG->demcr = demcr | ARMV7M_DEBUG_DEMCR_TRCENA;
   568   _ARM_Data_synchronization_barrier();
   570   dwt_ctrl = _ARMV7M_DWT->ctrl;
   571   if ((dwt_ctrl & ARMV7M_DWT_CTRL_NOCYCCNT) == 0) {
   572     _ARMV7M_DWT->lar = ARMV7M_DWT_LAR_UNLOCK_MAGIC;
   573     _ARM_Data_synchronization_barrier();
   574     _ARMV7M_DWT->ctrl = dwt_ctrl | ARMV7M_DWT_CTRL_CYCCNTENA;
   577     _ARMV7M_DEBUG->demcr = demcr;
   582 int _ARMV7M_Get_exception_priority(
int vector );
   584 void _ARMV7M_Set_exception_priority(
int vector,
int priority );
   586 ARMV7M_Exception_handler _ARMV7M_Get_exception_handler(
int index );
   588 void _ARMV7M_Set_exception_handler(
   590   ARMV7M_Exception_handler handler
   596 void _ARMV7M_Set_exception_priority_and_handler(
   599   ARMV7M_Exception_handler handler
   602 void _ARMV7M_Exception_default(
void );
   604 void _ARMV7M_Interrupt_service_enter(
void );
   606 void _ARMV7M_Interrupt_service_leave(
void );
   608 void _ARMV7M_Pendable_service_call(
void );
   610 void _ARMV7M_Supervisor_call(
void );
   612 void _ARMV7M_Clock_handler(
void );
 register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
