RTEMS  5.1
elf_machdep.h
1 /* $NetBSD: elf_machdep.h,v 1.19 2017/11/06 03:47:45 christos Exp $ */
2
3 #ifndef _ARM_ELF_MACHDEP_H_
4 #define _ARM_ELF_MACHDEP_H_
5
6 #if defined(__ARMEB__)
7 #define ELF32_MACHDEP_ENDIANNESS ELFDATA2MSB
8 #else
9 #define ELF32_MACHDEP_ENDIANNESS ELFDATA2LSB
10 #endif
11
12 #define ELF64_MACHDEP_ENDIANNESS XXX /* break compilation */
13 #define ELF64_MACHDEP_ID_CASES \
14  /* no 64-bit ELF machine types supported */
15
16 /* Processor specific flags for the ELF header e_flags field. */
17 #define EF_ARM_RELEXEC 0x00000001
18 #define EF_ARM_HASENTRY 0x00000002
19 #define EF_ARM_INTERWORK 0x00000004 /* GNU binutils 000413 */
20 #define EF_ARM_SYMSARESORTED 0x00000004 /* ARM ELF A08 */
21 #define EF_ARM_APCS_26 0x00000008 /* GNU binutils 000413 */
22 #define EF_ARM_DYNSYMSUSESEGIDX 0x00000008 /* ARM ELF B01 */
23 #define EF_ARM_APCS_FLOAT 0x00000010 /* GNU binutils 000413 */
24 #define EF_ARM_MAPSYMSFIRST 0x00000010 /* ARM ELF B01 */
25 #define EF_ARM_PIC 0x00000020
26 #define EF_ARM_ALIGN8 0x00000040 /* 8-bit structure alignment. */
27 #define EF_ARM_NEW_ABI 0x00000080
28 #define EF_ARM_OLD_ABI 0x00000100
29 #define EF_ARM_SOFT_FLOAT 0x00000200
30 #define EF_ARM_BE8 0x00800000
31 #define EF_ARM_EABIMASK 0xff000000
32 #define EF_ARM_EABI_VER1 0x01000000
33 #define EF_ARM_EABI_VER2 0x02000000
34 #define EF_ARM_EABI_VER3 0x03000000
35 #define EF_ARM_EABI_VER4 0x04000000
36 #define EF_ARM_EABI_VER5 0x05000000
37
38 #define ELF32_MACHDEP_ID_CASES \
39  case EM_ARM: \
40  break;
41
42 #define ELF32_MACHDEP_ID EM_ARM
43
44 #define KERN_ELFSIZE 32
45 #define ARCH_ELFSIZE 32 /* MD native binary size */
46
47 /* Processor specific relocation types */
48
49 #define R_ARM_NONE 0
50 #define R_ARM_PC24 1
51 #define R_ARM_ABS32 2
52 #define R_ARM_REL32 3
53 #define R_ARM_PC13 4
54 #define R_ARM_ABS16 5
55 #define R_ARM_ABS12 6
56 #define R_ARM_THM_ABS5 7
57 #define R_ARM_ABS8 8
58 #define R_ARM_SBREL32 9
59 #define R_ARM_THM_PC22 10
60 #define R_ARM_THM_PC8 11
61 #define R_ARM_AMP_VCALL9 12
62 #define R_ARM_SWI24 13
63 #define R_ARM_THM_SWI8 14
64 #define R_ARM_XPC25 15
65 #define R_ARM_THM_XPC22 16
66
67 /* TLS relocations */
68 #define R_ARM_TLS_DTPMOD32 17 /* ID of module containing symbol */
69 #define R_ARM_TLS_DTPOFF32 18 /* Offset in TLS block */
70 #define R_ARM_TLS_TPOFF32 19 /* Offset in static TLS block */
71
72 /* 20-31 are reserved for ARM Linux. */
73 #define R_ARM_COPY 20
74 #define R_ARM_GLOB_DAT 21
75 #define R_ARM_JUMP_SLOT 22
76 #define R_ARM_RELATIVE 23
77 #define R_ARM_GOTOFF 24
78 #define R_ARM_GOTPC 25
79 #define R_ARM_GOT32 26
80 #define R_ARM_PLT32 27
81 #define R_ARM_CALL 28
82 #define R_ARM_JUMP24 29
83 #define R_ARM_THM_JUMP24 30
84 #define R_ARM_BASE_ABS 31
85 #define R_ARM_ALU_PCREL_7_0 32
86 #define R_ARM_ALU_PCREL_15_8 33
87 #define R_ARM_ALU_PCREL_23_15 34
88 #define R_ARM_ALU_SBREL_11_0 35
89 #define R_ARM_ALU_SBREL_19_12 36
90 #define R_ARM_ALU_SBREL_27_20 37 // depcreated
91 #define R_ARM_TARGET1 38
92 #define R_ARM_SBREL31 39 // deprecated
93 #define R_ARM_V4BX 40
94 #define R_ARM_TARGET2 41
95 #define R_ARM_PREL31 42
96 #define R_ARM_MOVW_ABS_NC 43
97 #define R_ARM_MOVT_ABS 44
98 #define R_ARM_MOVW_PREL_NC 45
99 #define R_ARM_MOVT_PREL 46
100 #define R_ARM_THM_MOVW_ABS_NC 47
101 #define R_ARM_THM_MOVT_ABS 48
102 #define R_ARM_THM_MOVW_PREL_NC 49
103 #define R_ARM_THM_MOVT_PREL 50
104 #define R_ARM_THM_JUMP19 51
105
106 /* 96-111 are reserved to G++. */
107 #define R_ARM_GNU_VTENTRY 100
108 #define R_ARM_GNU_VTINHERIT 101
109 #define R_ARM_THM_PC11 102
110 #define R_ARM_THM_PC9 103
111
112 /* More TLS relocations */
113 #define R_ARM_TLS_GD32 104 /* PC-rel 32 bit for global dynamic */
114 #define R_ARM_TLS_LDM32 105 /* PC-rel 32 bit for local dynamic */
115 #define R_ARM_TLS_LDO32 106 /* 32 bit offset relative to TLS */
116 #define R_ARM_TLS_IE32 107 /* PC-rel 32 bit for GOT entry of */
117 #define R_ARM_TLS_LE32 108
118 #define R_ARM_TLS_LDO12 109
119 #define R_ARM_TLS_LE12 110
120 #define R_ARM_TLS_IE12GP 111
121
122 /* 112-127 are reserved for private experiments. */
123
124 #define R_ARM_IRELATIVE 160
125
126 #define R_ARM_RXPC25 249
127 #define R_ARM_RSBREL32 250
128 #define R_ARM_THM_RPC22 251
129 #define R_ARM_RREL32 252
130 #define R_ARM_RABS32 253
131 #define R_ARM_RPC24 254
132 #define R_ARM_RBASE 255
133
134 #define R_TYPE(name) __CONCAT(R_ARM_,name)
135
136 /* Processor specific program header flags */
137 #define PF_ARM_SB 0x10000000
138 #define PF_ARM_PI 0x20000000
139 #define PF_ARM_ENTRY 0x80000000
140
141 /* Processor specific program header types */
142 #define PT_ARM_EXIDX (PT_LOPROC + 1)
143
144 /* Processor specific section header flags */
145 #define SHF_ENTRYSECT 0x10000000
146 #define SHF_COMDEF 0x80000000
147
148 /* Processor specific symbol types */
149 #define STT_ARM_TFUNC STT_LOPROC
150
151 #ifdef _KERNEL
152 #ifdef ELFSIZE
153 #define ELF_MD_PROBE_FUNC ELFNAME2(arm_netbsd,probe)
154 #define ELF_MD_COREDUMP_SETUP ELFNAME2(arm_netbsd,coredump_setup)
155 #endif
156
157 struct exec_package;
158
159 int arm_netbsd_elf32_probe(struct lwp *, struct exec_package *, void *, char *,
160  vaddr_t *);
161 void arm_netbsd_elf32_coredump_setup(struct lwp *, void *);
162 #endif
163
164 #endif /* _ARM_ELF_MACHDEP_H_ */
