RTEMS  5.1
uart.h
1 /* ---------------------------------------------------------------------------- */
2 /* Atmel Microcontroller Software Support */
3 /* SAM Software Package License */
4 /* ---------------------------------------------------------------------------- */
5 /* Copyright (c) 2015, Atmel Corporation */
6 /* */
7 /* All rights reserved. */
8 /* */
9 /* Redistribution and use in source and binary forms, with or without */
10 /* modification, are permitted provided that the following condition is met: */
11 /* */
12 /* - Redistributions of source code must retain the above copyright notice, */
13 /* this list of conditions and the disclaimer below. */
14 /* */
15 /* Atmel's name may not be used to endorse or promote products derived from */
16 /* this software without specific prior written permission. */
17 /* */
18 /* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19 /* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20 /* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21 /* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22 /* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23 /* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24 /* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25 /* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26 /* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27 /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28 /* ---------------------------------------------------------------------------- */
29
30 #ifndef UART_H
31 #define UART_H
32
33
34 //------------------------------------------------------------------------------
35 // Global functions
36 //------------------------------------------------------------------------------
37
38 void UART_Configure(Uart *uart, uint32_t mode, uint32_t baudrate,
39  uint32_t masterClock);
40
41 void UART_SetTransmitterEnabled(Uart *uart, uint8_t enabled);
42
43 void UART_SetReceiverEnabled(Uart *uart, uint8_t enabled);
44
45 void UART_PutChar(Uart *uart, uint8_t c);
46
47 uint32_t UART_IsRxReady(Uart *uart);
48
49 uint8_t UART_GetChar(Uart *uart);
50
51 uint32_t UART_GetStatus(Uart *uart);
52
53 void UART_EnableIt(Uart *uart, uint32_t mode);
54
55 void UART_DisableIt(Uart *uart, uint32_t mode);
56
57 uint32_t UART_GetItMask(Uart *uart);
58
59 void UART_SendBuffer(Uart *uart, uint8_t *pBuffer, uint32_t BuffLen);
60
61 void UART_ReceiveBuffer(Uart *uart, uint8_t *pBuffer, uint32_t BuffLen);
62
63 void UART_CompareConfig(Uart *uart, uint8_t Val1, uint8_t Val2);
64
65 uint32_t UART_IsTxReady(Uart *uart);
66
67 #endif //#ifndef UART_H
68
Sends one packet of data through the specified UART peripheral. This function operates synchronously,...
Definition: uart.c:158
Uart hardware registers.
Definition: component_uart.h:41
Return 1 if a character can be read in UART.
Definition: uart.c:113
void UART_Configure(Uart *uart, uint32_t mode, uint32_t baudrate, uint32_t masterClock)
Configures an UART peripheral with the specified parameters.
Definition: uart.c:58
Get present status.
Definition: uart.c:174
Enable interrupt.
Definition: uart.c:184
Return 1 if a character can be send to UART.
Definition: uart.c:136
Enables or disables the receiver of an UART peripheral.
Definition: uart.c:101
Return interrupt mask.
Definition: uart.c:203
Enables or disables the transmitter of an UART peripheral.
Definition: uart.c:86
Disable interrupt.
Definition: uart.c:194
Reads and returns a character from the UART.
Definition: uart.c:125
