RTEMS  5.1
utility.h
1 /* ----------------------------------------------------------------------------
2  * SAM Software Package License
3  * ----------------------------------------------------------------------------
4  * Copyright (c) 2014, Atmel Corporation
5  *
6  * All rights reserved.
7  *
8  * Redistribution and use in source and binary forms, with or without
9  * modification, are permitted provided that the following conditions are met:
10  *
11  * - Redistributions of source code must retain the above copyright notice,
12  * this list of conditions and the disclaimer below.
13  *
14  * Atmel's name may not be used to endorse or promote products derived from
15  * this software without specific prior written permission.
16  *
17  * DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR
18  * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
19  * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
20  * DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT,
21  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
22  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
23  * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
24  * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
25  * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
26  * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
27  * ----------------------------------------------------------------------------
28  */
29
30 #ifndef UTILITY_H
31 #define UTILITY_H
32
33 #include "chip.h"
34
35
36
37 #define RESET_CYCLE_COUNTER() do { \
38  CoreDebug->DEMCR = CoreDebug_DEMCR_TRCENA_Msk; \
39  __DSB(); DWT->LAR = 0xC5ACCE55; __DSB(); \
40  DWT->CTRL &= ~DWT_CTRL_CYCCNTENA_Msk; \
41  DWT->CYCCNT = 0; \
42  DWT->CTRL = DWT_CTRL_CYCCNTENA_Msk; \
43  }while(0)
44
45 #define GET_CYCLE_COUNTER(x) x=DWT->CYCCNT;
46
47 #define LockMutex(mut, timeout) get_lock(&mut, 1, &timeout)
48
49 #define ReleaseMutex(mut) free_lock(&mut)
50
51 #define GetResource(mut, max, timeout) get_lock(&mut, max, &timeout)
52
53 #define FreeResource(mut) free_lock(&mut)
54
55
56 __STATIC_INLINE uint8_t Is_LockFree(volatile uint8_t *Lock_Variable)
57 {
58  /* return Variable value*/
59  return __LDREXB(Lock_Variable);
60
61 }
62
63 __STATIC_INLINE uint8_t get_lock(volatile uint8_t *Lock_Variable, const uint8_t maxValue, volatile uint32_t *pTimeout)
64 {
65  while (*pTimeout)
66  {
67  if(__LDREXB(Lock_Variable) < maxValue)
68  {
69  /* Set the Variable */
70  while( __STREXB(((*Lock_Variable) + 1), Lock_Variable) )
71  {
72  if(!(*pTimeout)--)
73  {
74  return 1; // quit if timeout
75  }
76  }
77  /* Memory access barrier */
78  __DMB();
79  TRACE_DEBUG("Mutex locked ");
80  return 0;
81  }
82
83  ((*pTimeout)--);
84  }
85  return 1;
86 }
87
88
89
90 __STATIC_INLINE uint8_t free_lock(volatile uint8_t *Lock_Variable)
91 {
92  /* Memory access barrier Ensure memory operations completed before releasing lock */
93  __DSB();
94  if(__LDREXB(Lock_Variable))
95  {
96  __STREXB( ((*Lock_Variable) - 1), Lock_Variable);
97  TRACE_DEBUG("Mutex freed ");
98  __DSB();
99  __DMB(); // Ensure memory operations completed before
100  return 0;
101  }
102  else
103  {
104  return 1;
105  }
106
107
108 }
109
110
111 #endif /* UTILITY_H */
#define TRACE_DEBUG(...)
Definition: trace.h:183
