23 #ifndef LIBBSP_ARM_SHARED_ARM_PL111_REGS_H    24 #define LIBBSP_ARM_SHARED_ARM_PL111_REGS_H    30 #define PL111_LCD_TIMING0_PPL(val) BSP_FLD32(val, 2, 7)    31 #define PL111_LCD_TIMING0_PPL_GET(reg) BSP_FLD32GET(reg, 2, 7)    32 #define PL111_LCD_TIMING0_PPL_SET(reg, val) BSP_FLD32SET(reg, val, 2, 7)    33 #define PL111_LCD_TIMING0_HSW(val) BSP_FLD32(val, 8, 15)    34 #define PL111_LCD_TIMING0_HSW_GET(reg) BSP_FLD32GET(reg, 8, 15)    35 #define PL111_LCD_TIMING0_HSW_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)    36 #define PL111_LCD_TIMING0_HFP(val) BSP_FLD32(val, 16, 23)    37 #define PL111_LCD_TIMING0_HFP_GET(reg) BSP_FLD32GET(reg, 16, 23)    38 #define PL111_LCD_TIMING0_HFP_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)    39 #define PL111_LCD_TIMING0_HBP(val) BSP_FLD32(val, 24, 31)    40 #define PL111_LCD_TIMING0_HBP_GET(reg) BSP_FLD32GET(reg, 24, 31)    41 #define PL111_LCD_TIMING0_HBP_SET(reg, val) BSP_FLD32SET(reg, val, 24, 31)    43 #define PL111_LCD_TIMING1_LPP(val) BSP_FLD32(val, 0, 9)    44 #define PL111_LCD_TIMING1_LPP_GET(reg) BSP_FLD32GET(reg, 0, 9)    45 #define PL111_LCD_TIMING1_LPP_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)    46 #define PL111_LCD_TIMING1_VSW(val) BSP_FLD32(val, 10, 15)    47 #define PL111_LCD_TIMING1_VSW_GET(reg) BSP_FLD32GET(reg, 10, 15)    48 #define PL111_LCD_TIMING1_VSW_SET(reg, val) BSP_FLD32SET(reg, val, 10, 15)    49 #define PL111_LCD_TIMING1_VFP(val) BSP_FLD32(val, 16, 23)    50 #define PL111_LCD_TIMING1_VFP_GET(reg) BSP_FLD32GET(reg, 16, 23)    51 #define PL111_LCD_TIMING1_VFP_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)    52 #define PL111_LCD_TIMING1_VBP(val) BSP_FLD32(val, 24, 31)    53 #define PL111_LCD_TIMING1_VBP_GET(reg) BSP_FLD32GET(reg, 24, 31)    54 #define PL111_LCD_TIMING1_VBP_SET(reg, val) BSP_FLD32SET(reg, val, 24, 31)    56 #define PL111_LCD_TIMING2_PCD_LO(val) BSP_FLD32(val, 0, 4)    57 #define PL111_LCD_TIMING2_PCD_LO_GET(reg) BSP_FLD32GET(reg, 0, 4)    58 #define PL111_LCD_TIMING2_PCD_LO_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)    59 #define PL111_LCD_TIMING2_CLKSEL BSP_BIT32(5)    60 #define PL111_LCD_TIMING2_ACB(val) BSP_FLD32(val, 6, 10)    61 #define PL111_LCD_TIMING2_ACB_GET(reg) BSP_FLD32GET(reg, 6, 10)    62 #define PL111_LCD_TIMING2_ACB_SET(reg, val) BSP_FLD32SET(reg, val, 6, 10)    63 #define PL111_LCD_TIMING2_IVS BSP_BIT32(11)    64 #define PL111_LCD_TIMING2_IHS BSP_BIT32(12)    65 #define PL111_LCD_TIMING2_IPC BSP_BIT32(13)    66 #define PL111_LCD_TIMING2_IOE BSP_BIT32(14)    67 #define PL111_LCD_TIMING2_CPL(val) BSP_FLD32(val, 16, 25)    68 #define PL111_LCD_TIMING2_CPL_GET(reg) BSP_FLD32GET(reg, 16, 25)    69 #define PL111_LCD_TIMING2_CPL_SET(reg, val) BSP_FLD32SET(reg, val, 16, 25)    70 #define PL111_LCD_TIMING2_BCD BSP_BIT32(26)    71 #define PL111_LCD_TIMING2_PCD_HI(val) BSP_FLD32(val, 27, 31)    72 #define PL111_LCD_TIMING2_PCD_HI_GET(reg) BSP_FLD32GET(reg, 27, 31)    73 #define PL111_LCD_TIMING2_PCD_HI_SET(reg, val) BSP_FLD32SET(reg, val, 27, 31)    75 #define PL111_LCD_TIMING3_LED(val) BSP_FLD32(val, 0, 6)    76 #define PL111_LCD_TIMING3_LED_GET(reg) BSP_FLD32GET(reg, 0, 6)    77 #define PL111_LCD_TIMING3_LED_SET(reg, val) BSP_FLD32SET(reg, val, 0, 6)    78 #define PL111_LCD_TIMING3_LEE BSP_BIT32(16)    82 #define PL111_LCD_CONTROL_LCD_EN BSP_BIT32(0)    83 #define PL111_LCD_CONTROL_LCD_BPP(val) BSP_FLD32(val, 1, 3)    84 #define PL111_LCD_CONTROL_LCD_BPP_GET(reg) BSP_FLD32GET(reg, 1, 3)    85 #define PL111_LCD_CONTROL_LCD_BPP_SET(reg, val) BSP_FLD32SET(reg, val, 1, 3)    86 #define PL111_LCD_CONTROL_LCD_BPP_1 0x00U    87 #define PL111_LCD_CONTROL_LCD_BPP_2 0x01U    88 #define PL111_LCD_CONTROL_LCD_BPP_4 0x02U    89 #define PL111_LCD_CONTROL_LCD_BPP_8 0x03U    90 #define PL111_LCD_CONTROL_LCD_BPP_16 0x04U    91 #define PL111_LCD_CONTROL_LCD_BPP_24 0x05U    92 #define PL111_LCD_CONTROL_LCD_BPP_16_5_6_5 0x06U    93 #define PL111_LCD_CONTROL_LCD_BPP_12 0x07U    94 #define PL111_LCD_CONTROL_LCD_BW BSP_BIT32(4)    95 #define PL111_LCD_CONTROL_LCD_TFT BSP_BIT32(5)    96 #define PL111_LCD_CONTROL_LCD_MONO8 BSP_BIT32(6)    97 #define PL111_LCD_CONTROL_LCD_DUAL BSP_BIT32(7)    98 #define PL111_LCD_CONTROL_BGR BSP_BIT32(8)    99 #define PL111_LCD_CONTROL_BEBO BSP_BIT32(9)   100 #define PL111_LCD_CONTROL_BEPO BSP_BIT32(10)   101 #define PL111_LCD_CONTROL_LCD_PWR BSP_BIT32(11)   102 #define PL111_LCD_CONTROL_LCD_V_COMP(val) BSP_FLD32(val, 12, 13)   103 #define PL111_LCD_CONTROL_LCD_V_COMP_GET(reg) BSP_FLD32GET(reg, 12, 13)   104 #define PL111_LCD_CONTROL_LCD_V_COMP_SET(reg, val) BSP_FLD32SET(reg, val, 12, 13)   105 #define PL111_LCD_CONTROL_WATERMARK BSP_BIT32(16)   110 #define PL111_LCD_I_FUF BSP_BIT32(1)   111 #define PL111_LCD_I_LNBU BSP_BIT32(2)   112 #define PL111_LCD_I_VCOMP BSP_BIT32(3)   113 #define PL111_LCD_I_MBERROR BSP_BIT32(4)   116     uint32_t reserved_34[115];
   118 #define PL111_LCD_PAL_R(val) BSP_FLD16(val, 0, 4)   119 #define PL111_LCD_PAL_R_GET(reg) BSP_FLD16GET(reg, 0, 4)   120 #define PL111_LCD_PAL_R_SET(reg, val) BSP_FLD16SET(reg, val, 0, 4)   121 #define PL111_LCD_PAL_G(val) BSP_FLD16(val, 5, 9)   122 #define PL111_LCD_PAL_G_GET(reg) BSP_FLD16GET(reg, 5, 9)   123 #define PL111_LCD_PAL_G_SET(reg, val) BSP_FLD16SET(reg, val, 5, 9)   124 #define PL111_LCD_PAL_B(val) BSP_FLD16(val, 10, 14)   125 #define PL111_LCD_PAL_B_GET(reg) BSP_FLD16GET(reg, 10, 14)   126 #define PL111_LCD_PAL_B_SET(reg, val) BSP_FLD16SET(reg, val, 10, 14)   127 #define PL111_LCD_PAL_I BSP_BIT16(15)   133 #define PL111_CRSR_CTRL_ON BSP_BIT32(0)   134 #define PL111_CRSR_CTRL_NUMBER(val) BSP_FLD32(val, 4, 5)   135 #define PL111_CRSR_CTRL_NUMBER_GET(reg) BSP_FLD32GET(reg, 4, 5)   136 #define PL111_CRSR_CTRL_NUMBER_SET(reg, val) BSP_FLD32SET(reg, val, 4, 5)   138 #define PL111_CRSR_CONFIG_SIZE BSP_BIT32(0)   139 #define PL111_CRSR_CONFIG_FRAME_SYNC BSP_BIT32(1)   142 #define PL111_CRSR_PALETTE_RED(val) BSP_FLD32(val, 0, 7)   143 #define PL111_CRSR_PALETTE_RED_GET(reg) BSP_FLD32GET(reg, 0, 7)   144 #define PL111_CRSR_PALETTE_RED_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)   145 #define PL111_CRSR_PALETTE_GREEN(val) BSP_FLD32(val, 8, 15)   146 #define PL111_CRSR_PALETTE_GREEN_GET(reg) BSP_FLD32GET(reg, 8, 15)   147 #define PL111_CRSR_PALETTE_GREEN_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)   148 #define PL111_CRSR_PALETTE_BLUE(val) BSP_FLD32(val, 16, 23)   149 #define PL111_CRSR_PALETTE_BLUE_GET(reg) BSP_FLD32GET(reg, 16, 23)   150 #define PL111_CRSR_PALETTE_BLUE_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)   152 #define PL111_CRSR_XY_X(val) BSP_FLD32(val, 0, 9)   153 #define PL111_CRSR_XY_X_GET(reg) BSP_FLD32GET(reg, 0, 9)   154 #define PL111_CRSR_XY_X_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)   155 #define PL111_CRSR_XY_X_EXP(val) BSP_FLD32(val, 10, 11)   156 #define PL111_CRSR_XY_X_EXP_GET(reg) BSP_FLD32GET(reg, 10, 11)   157 #define PL111_CRSR_XY_X_EXP_SET(reg, val) BSP_FLD32SET(reg, val, 10, 11)   158 #define PL111_CRSR_XY_Y(val) BSP_FLD32(val, 16, 25)   159 #define PL111_CRSR_XY_Y_GET(reg) BSP_FLD32GET(reg, 16, 25)   160 #define PL111_CRSR_XY_Y_SET(reg, val) BSP_FLD32SET(reg, val, 16, 25)   161 #define PL111_CRSR_XY_Y_EXP(val) BSP_FLD32(val, 25, 27)   162 #define PL111_CRSR_XY_Y_EXP_GET(reg) BSP_FLD32GET(reg, 25, 27)   163 #define PL111_CRSR_XY_Y_EXP_SET(reg, val) BSP_FLD32SET(reg, val, 25, 27)   165 #define PL111_CRSR_CLIP_X(val) BSP_FLD32(val, 0, 5)   166 #define PL111_CRSR_CLIP_X_GET(reg) BSP_FLD32GET(reg, 0, 5)   167 #define PL111_CRSR_CLIP_X_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)   168 #define PL111_CRSR_CLIP_Y(val) BSP_FLD32(val, 8, 13)   169 #define PL111_CRSR_CLIP_Y_GET(reg) BSP_FLD32GET(reg, 8, 13)   170 #define PL111_CRSR_CLIP_Y_SET(reg, val) BSP_FLD32SET(reg, val, 8, 13)   175 #define PL111_CRSR_I_CRSR BSP_BIT32(0)   180     uint32_t reserved_400[256];
 Definition: deflate.c:115
Definition: arm-pl111-regs.h:130
Definition: arm-pl111-regs.h:28
Definition: intercom.c:74
Definition: 8xx_immap.h:201
Definition: arm-pl111-regs.h:178
