23 #ifndef LIBBSP_ARM_SHARED_ARM_PL011_REGS_H    24 #define LIBBSP_ARM_SHARED_ARM_PL011_REGS_H    30 #define PL011_UARTDR_OE BSP_BIT32(11)    31 #define PL011_UARTDR_BE BSP_BIT32(10)    32 #define PL011_UARTDR_PE BSP_BIT32(9)    33 #define PL011_UARTDR_FE BSP_BIT32(8)    34 #define PL011_UARTDR_DATA(val) BSP_FLD32(val, 0, 7)    35 #define PL011_UARTDR_DATA_GET(reg) BSP_FLD32GET(reg, 0, 7)    36 #define PL011_UARTDR_DATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)    37   uint32_t uartrsr_uartecr;
    38 #define PL011_UARTRSR_UARTECR_OE BSP_BIT32(3)    39 #define PL011_UARTRSR_UARTECR_BE BSP_BIT32(2)    40 #define PL011_UARTRSR_UARTECR_PE BSP_BIT32(1)    41 #define PL011_UARTRSR_UARTECR_FE BSP_BIT32(0)    42   uint32_t reserved_08[4];
    44 #define PL011_UARTFR_RI BSP_BIT32(8)    45 #define PL011_UARTFR_TXFE BSP_BIT32(7)    46 #define PL011_UARTFR_RXFF BSP_BIT32(6)    47 #define PL011_UARTFR_TXFF BSP_BIT32(5)    48 #define PL011_UARTFR_RXFE BSP_BIT32(4)    49 #define PL011_UARTFR_BUSY BSP_BIT32(3)    50 #define PL011_UARTFR_DCD BSP_BIT32(2)    51 #define PL011_UARTFR_DSR BSP_BIT32(1)    52 #define PL011_UARTFR_CTS BSP_BIT32(0)    55 #define PL011_UARTILPR_ILPDVSR(val) BSP_FLD32(val, 0, 7)    56 #define PL011_UARTILPR_ILPDVSR_GET(reg) BSP_FLD32GET(reg, 0, 7)    57 #define PL011_UARTILPR_ILPDVSR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)    59 #define PL011_UARTIBRD_BAUD_DIVINT(val) BSP_FLD32(val, 0, 15)    60 #define PL011_UARTIBRD_BAUD_DIVINT_GET(reg) BSP_FLD32GET(reg, 0, 15)    61 #define PL011_UARTIBRD_BAUD_DIVINT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)    63 #define PL011_UARTFBRD_BAUD_DIVFRAC(val) BSP_FLD32(val, 0, 5)    64 #define PL011_UARTFBRD_BAUD_DIVFRAC_GET(reg) BSP_FLD32GET(reg, 0, 5)    65 #define PL011_UARTFBRD_BAUD_DIVFRAC_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)    67 #define PL011_UARTLCR_H_SPS BSP_BIT32(7)    68 #define PL011_UARTLCR_H_WLEN(val) BSP_FLD32(val, 5, 6)    69 #define PL011_UARTLCR_H_WLEN_GET(reg) BSP_FLD32GET(reg, 5, 6)    70 #define PL011_UARTLCR_H_WLEN_SET(reg, val) BSP_FLD32SET(reg, val, 5, 6)    71 #define PL011_UARTLCR_H_WLEN_5 0x00U    72 #define PL011_UARTLCR_H_WLEN_6 0x01U    73 #define PL011_UARTLCR_H_WLEN_7 0x02U    74 #define PL011_UARTLCR_H_WLEN_8 0x03U    75 #define PL011_UARTLCR_H_FEN BSP_BIT32(4)    76 #define PL011_UARTLCR_H_STP2 BSP_BIT32(3)    77 #define PL011_UARTLCR_H_EPS BSP_BIT32(2)    78 #define PL011_UARTLCR_H_PEN BSP_BIT32(1)    79 #define PL011_UARTLCR_H_BRK BSP_BIT32(0)    81 #define PL011_UARTCR_CTSEN BSP_BIT32(15)    82 #define PL011_UARTCR_RTSEN BSP_BIT32(14)    83 #define PL011_UARTCR_OUT2 BSP_BIT32(13)    84 #define PL011_UARTCR_OUT1 BSP_BIT32(12)    85 #define PL011_UARTCR_RTS BSP_BIT32(11)    86 #define PL011_UARTCR_DTR BSP_BIT32(10)    87 #define PL011_UARTCR_RXE BSP_BIT32(9)    88 #define PL011_UARTCR_TXE BSP_BIT32(8)    89 #define PL011_UARTCR_LBE BSP_BIT32(7)    90 #define PL011_UARTCR_SIRLP BSP_BIT32(3)    91 #define PL011_UARTCR_SIREN BSP_BIT32(2)    92 #define PL011_UARTCR_UARTEN BSP_BIT32(1)    94 #define PL011_UARTIFLS_RXIFLSEL(val) BSP_FLD32(val, 3, 5)    95 #define PL011_UARTIFLS_RXIFLSEL_GET(reg) BSP_FLD32GET(reg, 3, 5)    96 #define PL011_UARTIFLS_RXIFLSEL_SET(reg, val) BSP_FLD32SET(reg, val, 3, 5)    97 #define PL011_UARTIFLS_TXIFLSEL(val) BSP_FLD32(val, 0, 2)    98 #define PL011_UARTIFLS_TXIFLSEL_GET(reg) BSP_FLD32GET(reg, 0, 2)    99 #define PL011_UARTIFLS_TXIFLSEL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)   104 #define PL011_UARTI_OEI BSP_BIT32(10)   105 #define PL011_UARTI_BEI BSP_BIT32(9)   106 #define PL011_UARTI_PEI BSP_BIT32(8)   107 #define PL011_UARTI_FEI BSP_BIT32(7)   108 #define PL011_UARTI_RTI BSP_BIT32(6)   109 #define PL011_UARTI_TXI BSP_BIT32(5)   110 #define PL011_UARTI_RXI BSP_BIT32(4)   111 #define PL011_UARTI_DSRMI BSP_BIT32(3)   112 #define PL011_UARTI_DCDMI BSP_BIT32(2)   113 #define PL011_UARTI_CTSMI BSP_BIT32(1)   114 #define PL011_UARTI_RIMI BSP_BIT32(0)   116 #define PL011_UARTDMACR_DMAONERR BSP_BIT32(2)   117 #define PL011_UARTDMACR_TXDMAE BSP_BIT32(1)   118 #define PL011_UARTDMACR_RXDMAE BSP_BIT32(0)   119   uint32_t reserved_4c[997];
   120   uint32_t uartperiphid0;
   121   uint32_t uartperiphid1;
   122   uint32_t uartperiphid2;
   123   uint32_t uartperiphid3;
   124   uint32_t uartpcellid0;
   125   uint32_t uartpcellid1;
   126   uint32_t uartpcellid2;
   127   uint32_t uartpcellid3;
Definition: arm-pl011-regs.h:28
