23 #ifndef LIBBSP_ARM_SHARED_ARM_GIC_IRQ_H    24 #define LIBBSP_ARM_SHARED_ARM_GIC_IRQ_H    34 #define ARM_GIC_IRQ_SGI_0 0    35 #define ARM_GIC_IRQ_SGI_1 1    36 #define ARM_GIC_IRQ_SGI_2 2    37 #define ARM_GIC_IRQ_SGI_3 3    38 #define ARM_GIC_IRQ_SGI_5 5    39 #define ARM_GIC_IRQ_SGI_6 6    40 #define ARM_GIC_IRQ_SGI_7 7    41 #define ARM_GIC_IRQ_SGI_8 8    42 #define ARM_GIC_IRQ_SGI_9 9    43 #define ARM_GIC_IRQ_SGI_10 10     44 #define ARM_GIC_IRQ_SGI_11 11    45 #define ARM_GIC_IRQ_SGI_12 12    46 #define ARM_GIC_IRQ_SGI_13 13    47 #define ARM_GIC_IRQ_SGI_14 14    48 #define ARM_GIC_IRQ_SGI_15 15    50 #define ARM_GIC_DIST ((volatile gic_dist *) BSP_ARM_GIC_DIST_BASE)    72 void bsp_interrupt_set_affinity(
    74   const Processor_mask *affinity
    77 void bsp_interrupt_get_affinity(
    79   Processor_mask *affinity
    83   ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_IN_LIST,
    84   ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_EXCEPT_SELF,
    85   ARM_GIC_IRQ_SOFTWARE_IRQ_TO_SELF
    86 } arm_gic_irq_software_irq_target_filter;
    88 void arm_gic_trigger_sgi(
    90   arm_gic_irq_software_irq_target_filter filter,
    96   arm_gic_irq_software_irq_target_filter filter,
   102   if (vector <= ARM_GIC_IRQ_SGI_15) {
   103     arm_gic_trigger_sgi(vector, filter, targets);
   111 static inline uint32_t arm_gic_irq_processor_count(
void)
   113   volatile gic_dist *dist = ARM_GIC_DIST;
   115   return GIC_DIST_ICDICTR_CPU_NUMBER_GET(dist->icdictr) + 1;
   118 void arm_gic_irq_initialize_secondary_cpu(
void);
Definition: arm-gic-regs.h:88
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
rtems_status_code
Classic API Status.
Definition: status.h:43
