#define  | ARM_CP15_TEXT_SECTION |
#define  | ARM_CP15_CACHE_PREPARE_MVA(mva)   ((const void *) (((uint32_t) (mva)) & ~0x1fU)) |
#define  | ARM_CP15_TLB_PREPARE_MVA(mva)   ((const void *) (((uint32_t) (mva)) & ~0x3fU)) |
#define  | ARM_CORTEX_A9_ACTL_FW   (1U << 0) |
#define  | ARM_CORTEX_A9_ACTL_L2_PREFETCH_HINT_ENABLE   (1U << 1) |
#define  | ARM_CORTEX_A9_ACTL_L1_PREFETCH_ENABLE   (1U << 2) |
#define  | ARM_CORTEX_A9_ACTL_WRITE_FULL_LINE_OF_ZEROS_MODE   (1U << 3) |
#define  | ARM_CORTEX_A9_ACTL_SMP   (1U << 6) |
#define  | ARM_CORTEX_A9_ACTL_EXCL   (1U << 7) |
#define  | ARM_CORTEX_A9_ACTL_ALLOC_IN_ONE_WAY   (1U << 8) |
#define  | ARM_CORTEX_A9_ACTL_PARITY_ON   (1U << 9) |
#define  | ARM_CP15_PMCLRSET_CYCLE_COUNTER   0x80000000 |
#define  | ARM_CP15_PMCR_IMP(x)   ((x) << 24) |
#define  | ARM_CP15_PMCR_IDCODE(x)   ((x) << 16) |
#define  | ARM_CP15_PMCR_N(x)   ((x) << 11) |
#define  | ARM_CP15_PMCR_DP   (1U << 5) |
#define  | ARM_CP15_PMCR_X   (1U << 4) |
#define  | ARM_CP15_PMCR_D   (1U << 3) |
#define  | ARM_CP15_PMCR_C   (1U << 2) |
#define  | ARM_CP15_PMCR_P   (1U << 1) |
#define  | ARM_CP15_PMCR_E   (1U << 0) |
See section B3.8.2, "Short-descriptor format memory region attributes,
without TEX remap" in the "ARM Architecture Reference Manual ARMv7-A and
ARMv7-R edition".
#define  | ARM_MMU_SECT_BASE_SHIFT   20 |
#define  | ARM_MMU_SECT_BASE_MASK   (0xfffU << ARM_MMU_SECT_BASE_SHIFT) |
#define  | ARM_MMU_SECT_NS   (1U << 19) |
#define  | ARM_MMU_SECT_NG   (1U << 17) |
#define  | ARM_MMU_SECT_S   (1U << 16) |
#define  | ARM_MMU_SECT_AP_2   (1U << 15) |
#define  | ARM_MMU_SECT_TEX_2   (1U << 14) |
#define  | ARM_MMU_SECT_TEX_1   (1U << 13) |
#define  | ARM_MMU_SECT_TEX_0   (1U << 12) |
#define  | ARM_MMU_SECT_TEX_SHIFT   12 |
#define  | ARM_MMU_SECT_TEX_MASK   (0x3U << ARM_MMU_SECT_TEX_SHIFT) |
#define  | ARM_MMU_SECT_AP_1   (1U << 11) |
#define  | ARM_MMU_SECT_AP_0   (1U << 10) |
#define  | ARM_MMU_SECT_AP_SHIFT   10 |
#define  | ARM_MMU_SECT_AP_MASK   (0x23U << ARM_MMU_SECT_AP_SHIFT) |
#define  | ARM_MMU_SECT_DOMAIN_SHIFT   5 |
#define  | ARM_MMU_SECT_DOMAIN_MASK   (0xfU << ARM_MMU_SECT_DOMAIN_SHIFT) |
#define  | ARM_MMU_SECT_XN   (1U << 4) |
#define  | ARM_MMU_SECT_C   (1U << 3) |
#define  | ARM_MMU_SECT_B   (1U << 2) |
#define  | ARM_MMU_SECT_PXN   (1U << 0) |
#define  | ARM_MMU_SECT_DEFAULT   0x2U |
#define  | ARM_MMU_SECT_GET_INDEX(mva)   (((uint32_t) (mva)) >> ARM_MMU_SECT_BASE_SHIFT) |
| #define  | ARM_MMU_SECT_MVA_ALIGN_UP(mva) |
#define  | ARM_MMU_PAGE_TABLE_BASE_SHIFT   10 |
#define  | ARM_MMU_PAGE_TABLE_BASE_MASK   (0x3fffffU << ARM_MMU_PAGE_TABLE_BASE_SHIFT) |
#define  | ARM_MMU_PAGE_TABLE_DOMAIN_SHIFT   5 |
#define  | ARM_MMU_PAGE_TABLE_DOMAIN_MASK   (0xfU << ARM_MMU_PAGE_TABLE_DOMAIN_SHIFT) |
#define  | ARM_MMU_PAGE_TABLE_NS   (1U << 3) |
#define  | ARM_MMU_PAGE_TABLE_PXN   (1U << 2) |
#define  | ARM_MMU_PAGE_TABLE_DEFAULT   0x1U |
#define  | ARM_MMU_SMALL_PAGE_BASE_SHIFT   12 |
#define  | ARM_MMU_SMALL_PAGE_BASE_MASK   (0xfffffU << ARM_MMU_SMALL_PAGE_BASE_SHIFT) |
#define  | ARM_MMU_SMALL_PAGE_NG   (1U << 11) |
#define  | ARM_MMU_SMALL_PAGE_S   (1U << 10) |
#define  | ARM_MMU_SMALL_PAGE_AP_2   (1U << 9) |
#define  | ARM_MMU_SMALL_PAGE_TEX_2   (1U << 8) |
#define  | ARM_MMU_SMALL_PAGE_TEX_1   (1U << 7) |
#define  | ARM_MMU_SMALL_PAGE_TEX_0   (1U << 6) |
#define  | ARM_MMU_SMALL_PAGE_TEX_SHIFT   6 |
#define  | ARM_MMU_SMALL_PAGE_TEX_MASK   (0x3U << ARM_MMU_SMALL_PAGE_TEX_SHIFT) |
#define  | ARM_MMU_SMALL_PAGE_AP_1   (1U << 5) |
#define  | ARM_MMU_SMALL_PAGE_AP_0   (1U << 4) |
#define  | ARM_MMU_SMALL_PAGE_AP_SHIFT   4 |
#define  | ARM_MMU_SMALL_PAGE_AP_MASK   (0x23U << ARM_MMU_SMALL_PAGE_AP_SHIFT) |
#define  | ARM_MMU_SMALL_PAGE_C   (1U << 3) |
#define  | ARM_MMU_SMALL_PAGE_B   (1U << 2) |
#define  | ARM_MMU_SMALL_PAGE_XN   (1U << 0) |
#define  | ARM_MMU_SMALL_PAGE_DEFAULT   0x2U |
#define  | ARM_MMU_SMALL_PAGE_GET_INDEX(mva)   (((uint32_t) (mva)) >> ARM_MMU_SMALL_PAGE_BASE_SHIFT) |
| #define  | ARM_MMU_SMALL_PAGE_MVA_ALIGN_UP(mva) |
| #define  | ARM_MMU_SECT_FLAGS_TO_PAGE_TABLE(flags) |
| #define  | ARM_MMU_PAGE_TABLE_FLAGS_TO_SECT(flags) |
| #define  | ARM_MMU_SECT_FLAGS_TO_SMALL_PAGE(flags) |
| #define  | ARM_MMU_SMALL_PAGE_FLAGS_TO_SECT(flags) |
#define  | ARM_MMU_TRANSLATION_TABLE_ENTRY_SIZE   4U |
#define  | ARM_MMU_TRANSLATION_TABLE_ENTRY_COUNT   4096U |
#define  | ARM_MMU_SMALL_PAGE_TABLE_ENTRY_SIZE   4U |
#define  | ARM_MMU_SMALL_PAGE_TABLE_ENTRY_COUNT   256U |
#define  | ARM_MMU_DEFAULT_CLIENT_DOMAIN   15U |
| #define  | ARMV7_MMU_READ_ONLY |
#define  | ARMV7_MMU_READ_ONLY_CACHED   (ARMV7_MMU_READ_ONLY | ARM_MMU_SECT_TEX_0 | ARM_MMU_SECT_C | ARM_MMU_SECT_B) |
| #define  | ARMV7_MMU_READ_WRITE |
| #define  | ARMV7_MMU_READ_WRITE_CACHED |
#define  | ARMV7_MMU_DATA_READ_ONLY   (ARMV7_MMU_READ_ONLY | ARM_MMU_SECT_TEX_0) |
#define  | ARMV7_MMU_DATA_READ_ONLY_CACHED   ARMV7_MMU_READ_ONLY_CACHED |
#define  | ARMV7_MMU_DATA_READ_WRITE   (ARMV7_MMU_READ_WRITE | ARM_MMU_SECT_TEX_0) |
#define  | ARMV7_MMU_DATA_READ_WRITE_CACHED   ARMV7_MMU_READ_WRITE_CACHED |
#define  | ARMV7_MMU_CODE   (ARMV7_MMU_READ_ONLY | ARM_MMU_SECT_TEX_0) |
#define  | ARMV7_MMU_CODE_CACHED   ARMV7_MMU_READ_ONLY_CACHED |
#define  | ARMV7_MMU_DEVICE   (ARMV7_MMU_READ_WRITE | ARM_MMU_SECT_B) |
#define  | ARM_CP15_CTRL_TE   (1U << 30) |
#define  | ARM_CP15_CTRL_AFE   (1U << 29) |
#define  | ARM_CP15_CTRL_TRE   (1U << 28) |
#define  | ARM_CP15_CTRL_NMFI   (1U << 27) |
#define  | ARM_CP15_CTRL_EE   (1U << 25) |
#define  | ARM_CP15_CTRL_VE   (1U << 24) |
#define  | ARM_CP15_CTRL_XP   (1U << 23) |
#define  | ARM_CP15_CTRL_U   (1U << 22) |
#define  | ARM_CP15_CTRL_FI   (1U << 21) |
#define  | ARM_CP15_CTRL_UWXN   (1U << 20) |
#define  | ARM_CP15_CTRL_WXN   (1U << 19) |
#define  | ARM_CP15_CTRL_HA   (1U << 17) |
#define  | ARM_CP15_CTRL_L4   (1U << 15) |
#define  | ARM_CP15_CTRL_RR   (1U << 14) |
#define  | ARM_CP15_CTRL_V   (1U << 13) |
#define  | ARM_CP15_CTRL_I   (1U << 12) |
#define  | ARM_CP15_CTRL_Z   (1U << 11) |
#define  | ARM_CP15_CTRL_SW   (1U << 10) |
#define  | ARM_CP15_CTRL_R   (1U << 9) |
#define  | ARM_CP15_CTRL_S   (1U << 8) |
#define  | ARM_CP15_CTRL_B   (1U << 7) |
#define  | ARM_CP15_CTRL_CP15BEN   (1U << 5) |
#define  | ARM_CP15_CTRL_C   (1U << 2) |
#define  | ARM_CP15_CTRL_A   (1U << 1) |
#define  | ARM_CP15_CTRL_M   (1U << 0) |
#define  | ARM_CP15_DAC_NO_ACCESS   0x0U |
#define  | ARM_CP15_DAC_CLIENT   0x1U |
#define  | ARM_CP15_DAC_MANAGER   0x3U |
#define  | ARM_CP15_DAC_DOMAIN(index,  val)   ((val) << (2 * index)) |
#define  | ARM_CP15_FAULT_STATUS_MASK   0x040F |
#define  | ARM_CP15_FSR_ALIGNMENT_FAULT   0x00000001 |
#define  | ARM_CP15_FSR_BACKGROUND_FAULT   0x0000 |
#define  | ARM_CP15_FSR_ACCESS_PERMISSION_FAULT   0x000D |
#define  | ARM_CP15_FSR_PRECISE_EXTERNAL_ABORT_FAULT   0x0008 |
#define  | ARM_CP15_FSR_IMPRECISE_EXTERNAL_ABORT_FAULT   0x0406 |
#define  | ARM_CP15_FSR_PRECISE_PARITY_ERROR_EXCEPTION   0x0006 |
#define  | ARM_CP15_FSR_IMPRECISE_PARITY_ERROR_EXCEPTION   0x0408 |
#define  | ARM_CP15_FSR_DEBUG_EVENT   0x0002 |
The format can be obtained from CP15 by call arm_cp15_cache_type_get_format(arm_cp15_get_cache_type());
#define  | ARM_CP15_CACHE_TYPE_FORMAT_ARMV6   0 |
#define  | ARM_CP15_CACHE_TYPE_FORMAT_ARMV7   4 |
#define  | ARM_CP15_CACHE_CSS_ID_DATA   0 |
#define  | ARM_CP15_CACHE_CSS_ID_INSTRUCTION   1 |
#define  | ARM_CP15_CACHE_CSS_LEVEL(level)   ((level) << 1) |
ARM co-processor 15 (CP15) API.
