| enum   | ALT_GPIO_PIN_DIR_e { ALT_GPIO_PIN_INPUT,
ALT_GPIO_PIN_OUTPUT
| enum   | ALT_GPIO_PIN_TYPE_e { ALT_GPIO_PIN_LEVEL_TRIG_INT,
ALT_GPIO_PIN_EDGE_TRIG_INT
| enum   | ALT_GPIO_PIN_POL_e { ALT_GPIO_PIN_ACTIVE_LOW,
ALT_GPIO_PIN_ACTIVE_HIGH
| enum   | ALT_GPIO_PIN_DEBOUNCE_e { ALT_GPIO_PIN_NODEBOUNCE,
| enum   | ALT_GPIO_PIN_SYNC_e { ALT_GPIO_PIN_NOSYNC,
ALT_GPIO_PIN_SYNC
| enum   | ALT_GPIO_PIN_DATA_e { ALT_GPIO_PIN_DATAZERO,
ALT_GPIO_PIN_DATAONE
| enum   | ALT_GPIO_PORT_e { ALT_GPIO_PORTA,
ALT_GPIO_PORTB,
ALT_GPIO_PORTC,
ALT_GPIO_PORT_UNKNOWN
| enum   | ALT_GPIO_PORTBIT_e {
  ALT_GPIO_BIT0 = ALT_TWO_TO_POW0,
ALT_GPIO_BIT1 = ALT_TWO_TO_POW1,
ALT_GPIO_BIT2 = ALT_TWO_TO_POW2,
ALT_GPIO_BIT3 = ALT_TWO_TO_POW3,
  ALT_GPIO_BIT4 = ALT_TWO_TO_POW4,
ALT_GPIO_BIT5 = ALT_TWO_TO_POW5,
ALT_GPIO_BIT6 = ALT_TWO_TO_POW6,
ALT_GPIO_BIT7 = ALT_TWO_TO_POW7,
  ALT_GPIO_BIT8 = ALT_TWO_TO_POW8,
ALT_GPIO_BIT9 = ALT_TWO_TO_POW9,
ALT_GPIO_BIT10 = ALT_TWO_TO_POW10,
ALT_GPIO_BIT11 = ALT_TWO_TO_POW11,
  ALT_GPIO_BIT12 = ALT_TWO_TO_POW12,
ALT_GPIO_BIT13 = ALT_TWO_TO_POW13,
ALT_GPIO_BIT14 = ALT_TWO_TO_POW14,
ALT_GPIO_BIT15 = ALT_TWO_TO_POW15,
  ALT_GPIO_BIT16 = ALT_TWO_TO_POW16,
ALT_GPIO_BIT17 = ALT_TWO_TO_POW17,
ALT_GPIO_BIT18 = ALT_TWO_TO_POW18,
ALT_GPIO_BIT19 = ALT_TWO_TO_POW19,
  ALT_GPIO_BIT20 = ALT_TWO_TO_POW20,
ALT_GPIO_BIT21 = ALT_TWO_TO_POW21,
ALT_GPIO_BIT22 = ALT_TWO_TO_POW22,
ALT_GPIO_BIT23 = ALT_TWO_TO_POW23,
  ALT_GPIO_BIT24 = ALT_TWO_TO_POW24,
ALT_GPIO_BIT25 = ALT_TWO_TO_POW25,
ALT_GPIO_BIT26 = ALT_TWO_TO_POW26,
ALT_GPIO_BIT27 = ALT_TWO_TO_POW27,
  ALT_GPIO_BIT28 = ALT_TWO_TO_POW28,
ALT_GPIO_BIT29 = ALT_TWO_TO_POW29,
ALT_GPIO_BIT30 = ALT_TWO_TO_POW30,
ALT_GPIO_BIT31 = (int32_t) (1UL<<31),
  ALT_GPIO_BITNUM_MAX = (28),
ALT_GPIO_BIT_MAX = (1 << ALT_GPIO_BITNUM_MAX),
ALT_END_OF_GPIO_PORT_SIGNALS = (32)
| enum   | ALT_GPIO_1BIT_e {
  ALT_GPIO_1BIT_0,
ALT_GPIO_1BIT_1,
ALT_GPIO_1BIT_2,
ALT_GPIO_1BIT_3,
  ALT_GPIO_1BIT_4,
ALT_GPIO_1BIT_5,
ALT_GPIO_1BIT_6,
ALT_GPIO_1BIT_7,
  ALT_GPIO_1BIT_8,
ALT_GPIO_1BIT_9,
ALT_GPIO_1BIT_10,
ALT_GPIO_1BIT_11,
  ALT_GPIO_1BIT_12,
ALT_GPIO_1BIT_13,
ALT_GPIO_1BIT_14,
ALT_GPIO_1BIT_15,
  ALT_GPIO_1BIT_16,
ALT_GPIO_1BIT_17,
ALT_GPIO_1BIT_18,
ALT_GPIO_1BIT_19,
  ALT_GPIO_1BIT_20,
ALT_GPIO_1BIT_21,
ALT_GPIO_1BIT_22,
ALT_GPIO_1BIT_23,
  ALT_GPIO_1BIT_24,
ALT_GPIO_1BIT_25,
ALT_GPIO_1BIT_26,
ALT_GPIO_1BIT_27,
  ALT_GPIO_1BIT_28,
ALT_GPIO_1BIT_29,
ALT_GPIO_1BIT_30,
ALT_GPIO_1BIT_31,
  ALT_GPIO_1BIT_32,
ALT_GPIO_1BIT_33,
ALT_GPIO_1BIT_34,
ALT_GPIO_1BIT_35,
  ALT_GPIO_1BIT_36,
ALT_GPIO_1BIT_37,
ALT_GPIO_1BIT_38,
ALT_GPIO_1BIT_39,
  ALT_GPIO_1BIT_40,
ALT_GPIO_1BIT_41,
ALT_GPIO_1BIT_42,
ALT_GPIO_1BIT_43,
  ALT_GPIO_1BIT_44,
ALT_GPIO_1BIT_45,
ALT_GPIO_1BIT_46,
ALT_GPIO_1BIT_47,
  ALT_GPIO_1BIT_48,
ALT_GPIO_1BIT_49,
ALT_GPIO_1BIT_50,
ALT_GPIO_1BIT_51,
  ALT_GPIO_1BIT_52,
ALT_GPIO_1BIT_53,
ALT_GPIO_1BIT_54,
ALT_GPIO_1BIT_55,
  ALT_GPIO_1BIT_56,
ALT_GPIO_1BIT_57,
ALT_GPIO_1BIT_58,
ALT_GPIO_1BIT_59,
  ALT_GPIO_1BIT_60,
ALT_GPIO_1BIT_61,
ALT_GPIO_1BIT_62,
ALT_GPIO_1BIT_63,
  ALT_GPIO_1BIT_64,
ALT_GPIO_1BIT_65,
ALT_GPIO_1BIT_66,
ALT_GPIO_1BIT_67,
  ALT_GPIO_1BIT_68,
ALT_GPIO_1BIT_69,
ALT_GPIO_1BIT_70,
ALT_HLGPI_0,
  ALT_HLGPI_1,
ALT_HLGPI_2,
ALT_HLGPI_3,
ALT_HLGPI_4,
  ALT_HLGPI_5,
ALT_HLGPI_6,
ALT_HLGPI_7,
ALT_HLGPI_8,
  ALT_HLGPI_9,
ALT_HLGPI_10,
ALT_HLGPI_11,
ALT_HLGPI_12,
  ALT_HLGPI_13,
ALT_HLGPI_14,
ALT_HLGPI_15,
ALT_GPIO_INVALID,
  ALT_END_OF_GPIO_SIGNALS = -1,
ALT_LAST_VALID_GPIO_BIT = ALT_HLGPI_15
| ALT_STATUS_CODE  | alt_gpio_init (void) |
| ALT_STATUS_CODE  | alt_gpio_uninit (void) |
| ALT_STATUS_CODE  | alt_gpio_port_datadir_set (ALT_GPIO_PORT_t gpio_pid, uint32_t mask, uint32_t config) |
| uint32_t  | alt_gpio_port_datadir_get (ALT_GPIO_PORT_t gpio_pid, uint32_t mask) |
| ALT_STATUS_CODE  | alt_gpio_port_data_write (ALT_GPIO_PORT_t gpio_pid, uint32_t mask, uint32_t val) |
| uint32_t  | alt_gpio_port_data_read (ALT_GPIO_PORT_t gpio_pid, uint32_t mask) |
| ALT_STATUS_CODE  | alt_gpio_port_int_type_set (ALT_GPIO_PORT_t gpio_pid, uint32_t mask, uint32_t config) |
| uint32_t  | alt_gpio_port_int_type_get (ALT_GPIO_PORT_t gpio_pid, uint32_t mask) |
| ALT_STATUS_CODE  | alt_gpio_port_int_pol_set (ALT_GPIO_PORT_t gpio_pid, uint32_t mask, uint32_t config) |
| uint32_t  | alt_gpio_port_int_pol_get (ALT_GPIO_PORT_t gpio_pid, uint32_t mask) |
| ALT_STATUS_CODE  | alt_gpio_port_debounce_set (ALT_GPIO_PORT_t gpio_pid, uint32_t mask, uint32_t config) |
| uint32_t  | alt_gpio_port_debounce_get (ALT_GPIO_PORT_t gpio_pid, uint32_t mask) |
| ALT_STATUS_CODE  | alt_gpio_port_sync_set (ALT_GPIO_PORT_t gpio_pid, uint32_t config) |
| ALT_STATUS_CODE  | alt_gpio_port_sync_get (ALT_GPIO_PORT_t gpio_pid) |
| ALT_STATUS_CODE  | alt_gpio_port_config (ALT_GPIO_PORT_t gpio_pid, uint32_t mask, ALT_GPIO_PIN_DIR_t dir, ALT_GPIO_PIN_TYPE_t type, ALT_GPIO_PIN_POL_t pol, ALT_GPIO_PIN_DEBOUNCE_t debounc, uint32_t data) |
| ALT_STATUS_CODE  | alt_gpio_port_int_enable (ALT_GPIO_PORT_t gpio_pid, uint32_t config) |
| ALT_STATUS_CODE  | alt_gpio_port_int_disable (ALT_GPIO_PORT_t gpio_pid, uint32_t config) |
| uint32_t  | alt_gpio_port_int_enable_get (ALT_GPIO_PORT_t gpio_pid) |
| ALT_STATUS_CODE  | alt_gpio_port_int_mask_set (ALT_GPIO_PORT_t gpio_pid, uint32_t mask, uint32_t val) |
| uint32_t  | alt_gpio_port_int_mask_get (ALT_GPIO_PORT_t gpio_pid) |
| uint32_t  | alt_gpio_port_int_status_get (ALT_GPIO_PORT_t gpio_pid) |
| ALT_STATUS_CODE  | alt_gpio_port_int_status_clear (ALT_GPIO_PORT_t gpio_pid, uint32_t clrmask) |
| ALT_STATUS_CODE  | alt_gpio_bit_config (ALT_GPIO_1BIT_t signal_num, ALT_GPIO_PIN_DIR_t dir, ALT_GPIO_PIN_TYPE_t type, ALT_GPIO_PIN_POL_t pol, ALT_GPIO_PIN_DEBOUNCE_t debounce, ALT_GPIO_PIN_DATA_t data) |
| ALT_STATUS_CODE  | alt_gpio_bitconfig_get (ALT_GPIO_1BIT_t signal_num, ALT_GPIO_CONFIG_RECORD_t *config) |
| ALT_STATUS_CODE  | alt_gpio_group_config (ALT_GPIO_CONFIG_RECORD_t *config_array, uint32_t len) |
| ALT_STATUS_CODE  | alt_gpio_group_config_get (ALT_GPIO_CONFIG_RECORD_t *config_array, uint32_t len) |
| ALT_STATUS_CODE  | alt_gpio_group_config_get2 (ALT_GPIO_1BIT_t *pinid_array, ALT_GPIO_CONFIG_RECORD_t *config_array, uint32_t len) |
| uint32_t  | alt_gpio_port_idcode_get (ALT_GPIO_PORT_t gpio_pid) |
| uint32_t  | alt_gpio_port_ver_get (ALT_GPIO_PORT_t gpio_pid) |
| ALT_GPIO_PORT_t  | alt_gpio_bit_to_pid (ALT_GPIO_1BIT_t pin_num) |
| ALT_GPIO_PORTBIT_t  | alt_gpio_bit_to_port_pin (ALT_GPIO_1BIT_t pin_num) |
| ALT_GPIO_1BIT_t  | alt_gpio_port_pin_to_bit (ALT_GPIO_PORT_t pid, uint32_t bitmask) |
