37 #ifndef __ALT_DMA_PROGRAM_H__    38 #define __ALT_DMA_PROGRAM_H__    78 #define ALT_DMA_PROGRAM_CACHE_LINE_SIZE     (32)    86 #define ALT_DMA_PROGRAM_CACHE_LINE_COUNT    (16)   101 #ifndef ALT_DMA_PROGRAM_PROVISION_BUFFER_SIZE   102 #define ALT_DMA_PROGRAM_PROVISION_BUFFER_SIZE   (ALT_DMA_PROGRAM_CACHE_LINE_SIZE * ALT_DMA_PROGRAM_CACHE_LINE_COUNT)   114     uint16_t buffer_start;
   286                                              uint32_t current, uint32_t * progress);
   491                                       uint32_t iterations);
   765 #define ALT_DMA_CCR_OPT_SAF         (0 << 0)   767 #define ALT_DMA_CCR_OPT_SAI         (1 << 0)   769 #define ALT_DMA_CCR_OPT_SA_DEFAULT  ALT_DMA_CCR_OPT_SAI   775 #define ALT_DMA_CCR_OPT_SS8         (0 << 1)   777 #define ALT_DMA_CCR_OPT_SS16        (1 << 1)   779 #define ALT_DMA_CCR_OPT_SS32        (2 << 1)   781 #define ALT_DMA_CCR_OPT_SS64        (3 << 1)   783 #define ALT_DMA_CCR_OPT_SS128       (4 << 1)   785 #define ALT_DMA_CCR_OPT_SS_DEFAULT  ALT_DMA_CCR_OPT_SS8   791 #define ALT_DMA_CCR_OPT_SB1         (0x0 << 4)   793 #define ALT_DMA_CCR_OPT_SB2         (0x1 << 4)   795 #define ALT_DMA_CCR_OPT_SB3         (0x2 << 4)   797 #define ALT_DMA_CCR_OPT_SB4         (0x3 << 4)   799 #define ALT_DMA_CCR_OPT_SB5         (0x4 << 4)   801 #define ALT_DMA_CCR_OPT_SB6         (0x5 << 4)   803 #define ALT_DMA_CCR_OPT_SB7         (0x6 << 4)   805 #define ALT_DMA_CCR_OPT_SB8         (0x7 << 4)   807 #define ALT_DMA_CCR_OPT_SB9         (0x8 << 4)   809 #define ALT_DMA_CCR_OPT_SB10        (0x9 << 4)   811 #define ALT_DMA_CCR_OPT_SB11        (0xa << 4)   813 #define ALT_DMA_CCR_OPT_SB12        (0xb << 4)   815 #define ALT_DMA_CCR_OPT_SB13        (0xc << 4)   817 #define ALT_DMA_CCR_OPT_SB14        (0xd << 4)   819 #define ALT_DMA_CCR_OPT_SB15        (0xe << 4)   821 #define ALT_DMA_CCR_OPT_SB16        (0xf << 4)   823 #define ALT_DMA_CCR_OPT_SB_DEFAULT  ALT_DMA_CCR_OPT_SB1   829 #define ALT_DMA_CCR_OPT_SP(imm3)    ((imm3) << 8)   831 #define ALT_DMA_CCR_OPT_SP_DEFAULT  ALT_DMA_CCR_OPT_SP(0)   837 #define ALT_DMA_CCR_OPT_SC(imm4)    ((imm4) << 11)   839 #define ALT_DMA_CCR_OPT_SC_DEFAULT  ALT_DMA_CCR_OPT_SC(0)   845 #define ALT_DMA_CCR_OPT_DAF         (0 << 14)   847 #define ALT_DMA_CCR_OPT_DAI         (1 << 14)   849 #define ALT_DMA_CCR_OPT_DA_DEFAULT  ALT_DMA_CCR_OPT_DAI   855 #define ALT_DMA_CCR_OPT_DS8         (0 << 15)   857 #define ALT_DMA_CCR_OPT_DS16        (1 << 15)   859 #define ALT_DMA_CCR_OPT_DS32        (2 << 15)   861 #define ALT_DMA_CCR_OPT_DS64        (3 << 15)   863 #define ALT_DMA_CCR_OPT_DS128       (4 << 15)   865 #define ALT_DMA_CCR_OPT_DS_DEFAULT  ALT_DMA_CCR_OPT_DS8   871 #define ALT_DMA_CCR_OPT_DB1         (0x0 << 18)   873 #define ALT_DMA_CCR_OPT_DB2         (0x1 << 18)   875 #define ALT_DMA_CCR_OPT_DB3         (0x2 << 18)   877 #define ALT_DMA_CCR_OPT_DB4         (0x3 << 18)   879 #define ALT_DMA_CCR_OPT_DB5         (0x4 << 18)   881 #define ALT_DMA_CCR_OPT_DB6         (0x5 << 18)   883 #define ALT_DMA_CCR_OPT_DB7         (0x6 << 18)   885 #define ALT_DMA_CCR_OPT_DB8         (0x7 << 18)   887 #define ALT_DMA_CCR_OPT_DB9         (0x8 << 18)   889 #define ALT_DMA_CCR_OPT_DB10        (0x9 << 18)   891 #define ALT_DMA_CCR_OPT_DB11        (0xa << 18)   893 #define ALT_DMA_CCR_OPT_DB12        (0xb << 18)   895 #define ALT_DMA_CCR_OPT_DB13        (0xc << 18)   897 #define ALT_DMA_CCR_OPT_DB14        (0xd << 18)   899 #define ALT_DMA_CCR_OPT_DB15        (0xe << 18)   901 #define ALT_DMA_CCR_OPT_DB16        (0xf << 18)   903 #define ALT_DMA_CCR_OPT_DB_DEFAULT  ALT_DMA_CCR_OPT_DB1   909 #define ALT_DMA_CCR_OPT_DP(imm3)    ((imm3) << 22)   911 #define ALT_DMA_CCR_OPT_DP_DEFAULT  ALT_DMA_CCR_OPT_DP(0)   917 #define ALT_DMA_CCR_OPT_DC(imm4)    ((imm4) << 25)   919 #define ALT_DMA_CCR_OPT_DC_DEFAULT  ALT_DMA_CCR_OPT_DC(0)   925 #define ALT_DMA_CCR_OPT_ES8         (0 << 28)   927 #define ALT_DMA_CCR_OPT_ES16        (1 << 28)   929 #define ALT_DMA_CCR_OPT_ES32        (2 << 28)   931 #define ALT_DMA_CCR_OPT_ES64        (3 << 28)   933 #define ALT_DMA_CCR_OPT_ES128       (4 << 28)   935 #define ALT_DMA_CCR_OPT_ES_DEFAULT  ALT_DMA_CCR_OPT_ES8   938 #define ALT_DMA_CCR_OPT_DEFAULT \   939     (ALT_DMA_CCR_OPT_SB1 | ALT_DMA_CCR_OPT_SS8 | ALT_DMA_CCR_OPT_SAI | \   940      ALT_DMA_CCR_OPT_SP(0) | ALT_DMA_CCR_OPT_SC(0) | \   941      ALT_DMA_CCR_OPT_DB1 | ALT_DMA_CCR_OPT_DS8 | ALT_DMA_CCR_OPT_DAI | \   942      ALT_DMA_CCR_OPT_DP(0) | ALT_DMA_CCR_OPT_DC(0) | \ ALT_STATUS_CODE alt_dma_program_DMAWFP(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PERIPH_t periph, ALT_DMA_PROGRAM_INST_MOD_t mod)
Definition: alt_dma_program.c:1003
ALT_STATUS_CODE alt_dma_program_update_reg(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t reg, uint32_t val)
Definition: alt_dma_program.c:187
ALT_STATUS_CODE alt_dma_program_DMAST(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
Definition: alt_dma_program.c:849
ALT_STATUS_CODE alt_dma_program_DMANOP(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:764
enum ALT_DMA_EVENT_e ALT_DMA_EVENT_t
ALT_STATUS_CODE alt_dma_program_DMAGO(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_CHANNEL_t channel, uint32_t val, ALT_DMA_SECURITY_t sec)
Definition: alt_dma_program.c:355
ALT_STATUS_CODE alt_dma_program_progress_reg(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t reg, uint32_t current, uint32_t *progress)
Definition: alt_dma_program.c:147
ALT_STATUS_CODE alt_dma_program_uninit(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:98
Definition: alt_dma_program.h:176
ALT_STATUS_CODE alt_dma_program_DMARMB(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:786
ALT_STATUS_CODE alt_dma_program_DMAWFE(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_EVENT_t evt, bool invalid)
Definition: alt_dma_program.c:955
enum ALT_DMA_PROGRAM_INST_MOD_e ALT_DMA_PROGRAM_INST_MOD_t
ALT_STATUS_CODE alt_dma_program_DMASTZ(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:933
Definition: alt_dma_program.h:78
enum ALT_DMA_PERIPH_e ALT_DMA_PERIPH_t
Definition: alt_dma_program.h:196
ALT_STATUS_CODE alt_dma_program_DMAWMB(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:1050
Definition: alt_dma_program.h:170
ALT_STATUS_CODE alt_dma_program_DMAADDH(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t addr_reg, uint16_t val)
Definition: alt_dma_program.c:222
ALT_STATUS_CODE alt_dma_program_DMAADNH(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t addr_reg, uint16_t val)
Definition: alt_dma_program.c:261
Definition: alt_dma_program.h:190
ALT_STATUS_CODE alt_dma_program_DMALP(ALT_DMA_PROGRAM_t *pgm, uint32_t iterations)
Definition: alt_dma_program.c:521
enum ALT_DMA_CHANNEL_e ALT_DMA_CHANNEL_t
ALT_DMA_PROGRAM_REG_e
Definition: alt_dma_program.h:137
enum ALT_DMA_SECURITY_e ALT_DMA_SECURITY_t
ALT_STATUS_CODE alt_dma_program_DMAKILL(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:415
ALT_STATUS_CODE alt_dma_program_DMALD(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
Definition: alt_dma_program.c:437
Definition: alt_dma_program.h:183
ALT_STATUS_CODE alt_dma_program_DMASEV(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_EVENT_t evt)
Definition: alt_dma_program.c:808
ALT_STATUS_CODE alt_dma_program_DMAFLUSHP(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PERIPH_t periph)
Definition: alt_dma_program.c:325
ALT_STATUS_CODE alt_dma_program_DMAMOV(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_REG_t chan_reg, uint32_t val)
Definition: alt_dma_program.c:703
ALT_STATUS_CODE alt_dma_program_init(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.h:146
ALT_STATUS_CODE alt_dma_program_DMASTP(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod, ALT_DMA_PERIPH_t periph)
Definition: alt_dma_program.c:889
Definition: alt_dma_program.h:102
ALT_STATUS_CODE alt_dma_program_clear(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:103
ALT_STATUS_CODE alt_dma_program_DMALPEND(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod)
Definition: alt_dma_program.c:574
struct ALT_DMA_PROGRAM_s ALT_DMA_PROGRAM_t
int32_t ALT_STATUS_CODE
Definition: hwlib.h:60
Definition: alt_dma_program.h:110
enum ALT_DMA_PROGRAM_REG_e ALT_DMA_PROGRAM_REG_t
Definition: alt_dma_program.h:143
ALT_STATUS_CODE alt_dma_program_validate(const ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:117
ALT_STATUS_CODE alt_dma_program_DMAEND(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:300
ALT_STATUS_CODE alt_dma_program_DMALPFE(ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma_program.c:672
Definition: alt_dma_program.h:140
ALT_STATUS_CODE alt_dma_program_DMALDP(ALT_DMA_PROGRAM_t *pgm, ALT_DMA_PROGRAM_INST_MOD_t mod, ALT_DMA_PERIPH_t periph)
Definition: alt_dma_program.c:477
