76 #ifndef ALT_DMA_PERIPH_PROVISION_16550_SUPPORT    77 #define ALT_DMA_PERIPH_PROVISION_16550_SUPPORT (1)    80 #ifndef ALT_DMA_PERIPH_PROVISION_QSPI_SUPPORT    81 #define ALT_DMA_PERIPH_PROVISION_QSPI_SUPPORT (1)   790                                            const void * src_buf,
   792                                            uint32_t register_width_bits,
   838                                            const void * src_reg,
   840                                            uint32_t register_width_bits,
 Definition: alt_dma.h:240
enum ALT_DMA_CHANNEL_STATE_e ALT_DMA_CHANNEL_STATE_t
Definition: alt_dma.h:288
ALT_STATUS_CODE alt_dma_register_to_memory(ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, void *dst_buf, const void *src_reg, size_t count, uint32_t register_width_bits, bool send_evt, ALT_DMA_EVENT_t evt)
Definition: alt_dma.c:1780
ALT_STATUS_CODE alt_dma_send_event(ALT_DMA_EVENT_t evt_num)
Definition: alt_dma.c:619
ALT_STATUS_CODE alt_dma_event_int_status_get_raw(ALT_DMA_EVENT_t evt_num)
Definition: alt_dma.c:772
enum ALT_DMA_CHANNEL_FAULT_e ALT_DMA_CHANNEL_FAULT_t
ALT_STATUS_CODE alt_dma_channel_alloc_any(ALT_DMA_CHANNEL_t *allocated)
Definition: alt_dma.c:355
ALT_STATUS_CODE alt_dma_zero_to_memory(ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, void *buf, size_t size, bool send_evt, ALT_DMA_EVENT_t evt)
Definition: alt_dma.c:1269
Definition: alt_dma.h:245
ALT_STATUS_CODE alt_dma_memory_to_memory(ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, void *dest, const void *src, size_t size, bool send_evt, ALT_DMA_EVENT_t evt)
Definition: alt_dma.c:866
ALT_DMA_PERIPH_MUX_t periph_mux[4]
Definition: alt_dma.h:324
Definition: alt_dma.h:278
enum ALT_DMA_EVENT_e ALT_DMA_EVENT_t
Definition: alt_dma.h:118
ALT_STATUS_CODE alt_dma_int_clear(ALT_DMA_EVENT_t irq_num)
Definition: alt_dma.c:838
enum ALT_DMA_PERIPH_MUX_e ALT_DMA_PERIPH_MUX_t
ALT_STATUS_CODE alt_dma_event_int_select(ALT_DMA_EVENT_t evt_num, ALT_DMA_EVENT_SELECT_t opt)
Definition: alt_dma.c:735
ALT_DMA_SECURITY_t irq_sec[8]
Definition: alt_dma.h:309
Definition: alt_dma.h:142
enum ALT_DMA_MANAGER_FAULT_e ALT_DMA_MANAGER_FAULT_t
ALT_STATUS_CODE alt_dma_channel_fault_status_get(ALT_DMA_CHANNEL_t channel, ALT_DMA_CHANNEL_FAULT_t *fault)
Definition: alt_dma.c:709
Definition: alt_dma.h:165
ALT_DMA_SECURITY_t manager_sec
Definition: alt_dma.h:302
Definition: alt_dma.h:107
ALT_DMA_EVENT_SELECT_e
Definition: alt_dma.h:253
Definition: alt_dma.h:283
enum ALT_DMA_PERIPH_e ALT_DMA_PERIPH_t
ALT_STATUS_CODE alt_dma_memory_to_periph(ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, ALT_DMA_PERIPH_t dest, const void *src, size_t size, void *periph_info, bool send_evt, ALT_DMA_EVENT_t evt)
Definition: alt_dma.c:3508
Definition: alt_dma.h:178
ALT_STATUS_CODE alt_dma_memory_to_register(ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, void *dst_reg, const void *src_buf, size_t count, uint32_t register_width_bits, bool send_evt, ALT_DMA_EVENT_t evt)
Definition: alt_dma.c:1504
ALT_STATUS_CODE alt_dma_uninit(void)
Definition: alt_dma.c:304
ALT_STATUS_CODE alt_dma_manager_fault_status_get(ALT_DMA_MANAGER_FAULT_t *fault)
Definition: alt_dma.c:700
Definition: alt_dma.h:128
enum ALT_DMA_MANAGER_STATE_e ALT_DMA_MANAGER_STATE_t
Definition: alt_dma.h:108
ALT_STATUS_CODE alt_dma_init(const ALT_DMA_CFG_t *dma_cfg)
Definition: alt_dma.c:213
Definition: alt_dma.h:194
enum ALT_DMA_CHANNEL_e ALT_DMA_CHANNEL_t
Definition: alt_dma.h:265
ALT_STATUS_CODE alt_dma_channel_alloc(ALT_DMA_CHANNEL_t channel)
Definition: alt_dma.c:323
Definition: alt_dma.h:221
Definition: alt_dma.h:116
enum ALT_DMA_SECURITY_e ALT_DMA_SECURITY_t
Definition: alt_dma.h:126
ALT_STATUS_CODE alt_dma_periph_to_memory(ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *program, void *dest, ALT_DMA_PERIPH_t src, size_t size, void *periph_info, bool send_evt, ALT_DMA_EVENT_t evt)
Definition: alt_dma.c:3601
Definition: alt_dma.h:136
Definition: alt_dma.h:297
Definition: alt_dma.h:259
Definition: alt_dma.h:122
Definition: alt_dma.h:170
Definition: alt_dma.h:125
ALT_STATUS_CODE alt_dma_manager_state_get(ALT_DMA_MANAGER_STATE_t *state)
Definition: alt_dma.c:661
ALT_DMA_SECURITY_t periph_sec[32]
Definition: alt_dma.h:316
Definition: alt_dma.h:234
ALT_STATUS_CODE alt_dma_int_status_get(ALT_DMA_EVENT_t irq_num)
Definition: alt_dma.c:805
Definition: alt_dma.h:104
ALT_STATUS_CODE alt_dma_channel_free(ALT_DMA_CHANNEL_t channel)
Definition: alt_dma.c:379
ALT_STATUS_CODE alt_dma_channel_state_get(ALT_DMA_CHANNEL_t channel, ALT_DMA_CHANNEL_STATE_t *state)
Definition: alt_dma.c:672
Definition: alt_dma.h:124
Definition: alt_dma.h:120
Definition: alt_dma.h:273
Definition: alt_dma.h:147
ALT_STATUS_CODE alt_dma_channel_kill(ALT_DMA_CHANNEL_t channel)
Definition: alt_dma.c:501
Definition: alt_dma.h:227
Definition: alt_dma.h:209
Definition: alt_dma.h:199
int32_t ALT_STATUS_CODE
Definition: hwlib.h:60
Definition: alt_dma.h:189
Definition: alt_dma_program.h:110
struct ALT_DMA_CFG_s ALT_DMA_CFG_t
ALT_STATUS_CODE alt_dma_channel_exec(ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_t *pgm)
Definition: alt_dma.c:424
ALT_STATUS_CODE alt_dma_channel_reg_get(ALT_DMA_CHANNEL_t channel, ALT_DMA_PROGRAM_REG_t reg, uint32_t *val)
Definition: alt_dma.c:578
Definition: alt_dma.h:127
Definition: alt_dma.h:183
Definition: alt_dma.h:101
Definition: alt_dma.h:103
enum ALT_DMA_PROGRAM_REG_e ALT_DMA_PROGRAM_REG_t
Definition: alt_dma.h:204
Definition: alt_dma.h:215
unsigned size
Definition: tte.h:74
Definition: alt_dma.h:153
enum ALT_DMA_EVENT_SELECT_e ALT_DMA_EVENT_SELECT_t
Definition: alt_dma.h:119
Definition: alt_dma.h:121
Definition: alt_dma.h:123
Definition: alt_dma.h:106
Definition: alt_dma.h:105
Definition: alt_dma.h:159
