zlib/zutil.h
1 /* zutil.h -- internal interface and configuration of the compression library
2  * Copyright (C) 1995-2010 Jean-loup Gailly.
3  * For conditions of distribution and use, see copyright notice in zlib.h
4  */
5
6 /* WARNING: this file should *not* be used by applications. It is
7  part of the implementation of the compression library and is
8  subject to change. Applications should only use zlib.h.
9  */
10
11 #ifndef ZUTIL_H
12 #define ZUTIL_H
13
14 #if ((__GNUC__-0) * 10 + __GNUC_MINOR__-0 >= 33) && !defined(NO_VIZ)
15 # define ZLIB_INTERNAL __attribute__((visibility ("hidden")))
16 #else
17 # define ZLIB_INTERNAL
18 #endif
19
20 #include "zlib.h"
21
22 #ifdef STDC
23 # if !(defined(_WIN32_WCE) && defined(_MSC_VER))
24 # include <stddef.h>
25 # endif
26 # include <string.h>
27 # include <stdlib.h>
28 #endif
29
30 #ifndef local
31 # define local static
32 #endif
33 /* compile with -Dlocal if your debugger can't find static symbols */
34
35 typedef unsigned char uch;
36 typedef uch FAR uchf;
37 typedef unsigned short ush;
38 typedef ush FAR ushf;
39 typedef unsigned long ulg;
40
41 extern const char * const z_errmsg[10]; /* indexed by 2-zlib_error */
42 /* (size given to avoid silly warnings with Visual C++) */
43
44 #define ERR_MSG(err) z_errmsg[Z_NEED_DICT-(err)]
45
46 #define ERR_RETURN(strm,err) \
47  return (strm->msg = (char*)ERR_MSG(err), (err))
48 /* To be used only when the state is known to be valid */
49
50  /* common constants */
51
52 #ifndef DEF_WBITS
53 # define DEF_WBITS MAX_WBITS
54 #endif
55 /* default windowBits for decompression. MAX_WBITS is for compression only */
56
57 #if MAX_MEM_LEVEL >= 8
58 # define DEF_MEM_LEVEL 8
59 #else
60 # define DEF_MEM_LEVEL MAX_MEM_LEVEL
61 #endif
62 /* default memLevel */
63
64 #define STORED_BLOCK 0
65 #define STATIC_TREES 1
66 #define DYN_TREES 2
67 /* The three kinds of block type */
68
69 #define MIN_MATCH 3
70 #define MAX_MATCH 258
71 /* The minimum and maximum match lengths */
72
73 #define PRESET_DICT 0x20 /* preset dictionary flag in zlib header */
74
75  /* target dependencies */
76
77 #if defined(MSDOS) || (defined(WINDOWS) && !defined(WIN32))
78 # define OS_CODE 0x00
79 # if defined(__TURBOC__) || defined(__BORLANDC__)
80 # if (__STDC__ == 1) && (defined(__LARGE__) || defined(__COMPACT__))
81  /* Allow compilation with ANSI keywords only enabled */
82  void _Cdecl farfree( void *block );
83  void *_Cdecl farmalloc( unsigned long nbytes );
84 # else
85 # include <alloc.h>
86 # endif
87 # else /* MSC or DJGPP */
88 # include <malloc.h>
89 # endif
90 #endif
91
92 #ifdef AMIGA
93 # define OS_CODE 0x01
94 #endif
95
96 #if defined(VAXC) || defined(VMS)
97 # define OS_CODE 0x02
98 # define F_OPEN(name, mode) \
99  fopen((name), (mode), "mbc=60", "ctx=stm", "rfm=fix", "mrs=512")
100 #endif
101
102 #if defined(ATARI) || defined(atarist)
103 # define OS_CODE 0x05
104 #endif
105
106 #ifdef OS2
107 # define OS_CODE 0x06
108 # ifdef M_I86
109 # include <malloc.h>
110 # endif
111 #endif
112
113 #if defined(MACOS) || defined(TARGET_OS_MAC)
114 # define OS_CODE 0x07
115 # if defined(__MWERKS__) && __dest_os != __be_os && __dest_os != __win32_os
116 # include <unix.h> /* for fdopen */
117 # else
118 # ifndef fdopen
119 # define fdopen(fd,mode) NULL /* No fdopen() */
120 # endif
121 # endif
122 #endif
123
124 #ifdef TOPS20
125 # define OS_CODE 0x0a
126 #endif
127
128 #ifdef WIN32
129 # ifndef __CYGWIN__ /* Cygwin is Unix, not Win32 */
130 # define OS_CODE 0x0b
131 # endif
132 #endif
133
134 #ifdef __50SERIES /* Prime/PRIMOS */
135 # define OS_CODE 0x0f
136 #endif
137
138 #if defined(_BEOS_) || defined(RISCOS)
139 # define fdopen(fd,mode) NULL /* No fdopen() */
140 #endif
141
142 #if (defined(_MSC_VER) && (_MSC_VER > 600)) && !defined __INTERIX
143 # if defined(_WIN32_WCE)
144 # define fdopen(fd,mode) NULL /* No fdopen() */
145 # ifndef _PTRDIFF_T_DEFINED
146  typedef int ptrdiff_t;
147 # define _PTRDIFF_T_DEFINED
148 # endif
149 # else
150 # define fdopen(fd,type) _fdopen(fd,type)
151 # endif
152 #endif
153
154 #if defined(__BORLANDC__)
155  #pragma warn -8004
156  #pragma warn -8008
157  #pragma warn -8066
158 #endif
159
160 /* provide prototypes for these when building zlib without LFS */
161 #if !defined(_LARGEFILE64_SOURCE) || _LFS64_LARGEFILE-0 == 0
162  ZEXTERN uLong ZEXPORT adler32_combine64 OF((uLong, uLong, z_off_t));
163  ZEXTERN uLong ZEXPORT crc32_combine64 OF((uLong, uLong, z_off_t));
164 #endif
165
166  /* common defaults */
167
168 #ifndef OS_CODE
169 # define OS_CODE 0x03 /* assume Unix */
170 #endif
171
172 #ifndef F_OPEN
173 # define F_OPEN(name, mode) fopen((name), (mode))
174 #endif
175
176  /* functions */
177
178 #if defined(STDC99) || (defined(__TURBOC__) && __TURBOC__ >= 0x550)
179 # ifndef HAVE_VSNPRINTF
180 # define HAVE_VSNPRINTF
181 # endif
182 #endif
183 #if defined(__CYGWIN__)
184 # ifndef HAVE_VSNPRINTF
185 # define HAVE_VSNPRINTF
186 # endif
187 #endif
188 #ifndef HAVE_VSNPRINTF
189 # ifdef MSDOS
190  /* vsnprintf may exist on some MS-DOS compilers (DJGPP?),
191  but for now we just assume it doesn't. */
192 # define NO_vsnprintf
193 # endif
194 # ifdef __TURBOC__
195 # define NO_vsnprintf
196 # endif
197 # ifdef WIN32
198  /* In Win32, vsnprintf is available as the "non-ANSI" _vsnprintf. */
199 # if !defined(vsnprintf) && !defined(NO_vsnprintf)
200 # if !defined(_MSC_VER) || ( defined(_MSC_VER) && _MSC_VER < 1500 )
201 # define vsnprintf _vsnprintf
202 # endif
203 # endif
204 # endif
205 # ifdef __SASC
206 # define NO_vsnprintf
207 # endif
208 #endif
209 #ifdef VMS
210 # define NO_vsnprintf
211 #endif
212
213 #if defined(pyr)
214 # define NO_MEMCPY
215 #endif
216 #if defined(SMALL_MEDIUM) && !defined(_MSC_VER) && !defined(__SC__)
217  /* Use our own functions for small and medium model with MSC <= 5.0.
218  * You may have to use the same strategy for Borland C (untested).
219  * The __SC__ check is for Symantec.
220  */
221 # define NO_MEMCPY
222 #endif
223 #if defined(STDC) && !defined(HAVE_MEMCPY) && !defined(NO_MEMCPY)
224 # define HAVE_MEMCPY
225 #endif
226 #ifdef HAVE_MEMCPY
227 # ifdef SMALL_MEDIUM /* MSDOS small or medium model */
228 # define zmemcpy _fmemcpy
229 # define zmemcmp _fmemcmp
230 # define zmemzero(dest, len) _fmemset(dest, 0, len)
231 # else
232 # define zmemcpy memcpy
233 # define zmemcmp memcmp
234 # define zmemzero(dest, len) memset(dest, 0, len)
235 # endif
236 #else
237  void ZLIB_INTERNAL zmemcpy OF((Bytef* dest, const Bytef* source, uInt len));
238  int ZLIB_INTERNAL zmemcmp OF((const Bytef* s1, const Bytef* s2, uInt len));
239  void ZLIB_INTERNAL zmemzero OF((Bytef* dest, uInt len));
240 #endif
241
242 /* Diagnostic functions */
243 #ifdef DEBUG
244 # include <stdio.h>
245  extern int ZLIB_INTERNAL z_verbose;
246  extern void ZLIB_INTERNAL z_error OF((char *m));
247 # define Assert(cond,msg) {if(!(cond)) z_error(msg);}
248 # define Trace(x) {if (z_verbose>=0) fprintf x ;}
249 # define Tracev(x) {if (z_verbose>0) fprintf x ;}
250 # define Tracevv(x) {if (z_verbose>1) fprintf x ;}
251 # define Tracec(c,x) {if (z_verbose>0 && (c)) fprintf x ;}
252 # define Tracecv(c,x) {if (z_verbose>1 && (c)) fprintf x ;}
253 #else
254 # define Assert(cond,msg)
255 # define Trace(x)
256 # define Tracev(x)
257 # define Tracevv(x)
258 # define Tracec(c,x)
259 # define Tracecv(c,x)
260 #endif
261
262
263 voidpf ZLIB_INTERNAL zcalloc OF((voidpf opaque, unsigned items,
264  unsigned size));
265 void ZLIB_INTERNAL zcfree OF((voidpf opaque, voidpf ptr));
266
267 #define ZALLOC(strm, items, size) \
268  (*((strm)->zalloc))((strm)->opaque, (items), (size))
269 #define ZFREE(strm, addr) (*((strm)->zfree))((strm)->opaque, (voidpf)(addr))
270 #define TRY_FREE(s, p) {if (p) ZFREE(s, p);}
271
272 #endif /* ZUTIL_H */
