admin
rtems-admin.git
doxygen
builder
latest
rtems.git
libnetworking
vm
vm_param.h
1
2
* Copyright (c) 1991, 1993
3
* The Regents of the University of California. All rights reserved.
4
5
* This code is derived from software contributed to Berkeley by
6
* The Mach Operating System project at Carnegie-Mellon University.
7
8
9
* modification, are permitted provided that the following conditions
10
* are met:
11
* 1. Redistributions of source code must retain the above copyright
12
* notice, this list of conditions and the following disclaimer.
13
* 2. Redistributions in binary form must reproduce the above copyright
14
* notice, this list of conditions and the following disclaimer in the
15
* documentation and/or other materials provided with the distribution.
16
* 4. Neither the name of the University nor the names of its contributors
17
* may be used to endorse or promote products derived from this software
18
* without specific prior written permission.
19
20
* THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
21
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23
* ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
24
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
25
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
26
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
27
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
28
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
29
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
30
* SUCH DAMAGE.
31
32
33
34
35
* Copyright (c) 1987, 1990 Carnegie-Mellon University.
36
* All rights reserved.
37
38
* Authors: Avadis Tevanian, Jr., Michael Wayne Young
39
40
* Permission to use, copy, modify and distribute this software and
41
* its documentation is hereby granted, provided that both the copyright
42
* notice and this permission notice appear in all copies of the
43
* software, derivative works or modified versions, and any portions
44
* thereof, and that both notices appear in supporting documentation.
45
46
* CARNEGIE MELLON ALLOWS FREE USE OF THIS SOFTWARE IN ITS "AS IS"
47
* CONDITION. CARNEGIE MELLON DISCLAIMS ANY LIABILITY OF ANY KIND
48
* FOR ANY DAMAGES WHATSOEVER RESULTING FROM THE USE OF THIS SOFTWARE.
49
50
* Carnegie Mellon requests users of this software to return to
51
52
* Software Distribution Coordinator or Software.Distribution@CS.CMU.EDU
53
* School of Computer Science
54
* Carnegie Mellon University
55
* Pittsburgh PA 15213-3890
56
57
* any improvements or extensions that they make and grant Carnegie the
58
* rights to redistribute these changes.
59
60
* $FreeBSD: src/sys/vm/vm_param.h,v 1.21 2005/01/07 02:29:27 imp Exp $
61
62
63
64
65
* Machine independent virtual memory parameters.
66
67
68
#ifndef _VM_PARAM_
69
#define _VM_PARAM_
70
71
machine/vmparam.h
72
73
74
* CTL_VM identifiers
75
76
#define VM_TOTAL 1
/* struct vmtotal */
77
#define VM_METER VM_TOTAL
/* deprecated, use VM_TOTAL */
78
#define VM_LOADAVG 2
/* struct loadavg */
79
#define VM_V_FREE_MIN 3
/* cnt.v_free_min */
80
#define VM_V_FREE_TARGET 4
/* cnt.v_free_target */
81
#define VM_V_FREE_RESERVED 5
/* cnt.v_free_reserved */
82
#define VM_V_INACTIVE_TARGET 6
/* cnt.v_inactive_target */
83
#define VM_V_CACHE_MIN 7
/* cnt.v_cache_max */
84
#define VM_V_CACHE_MAX 8
/* cnt.v_cache_min */
85
#define VM_V_PAGEOUT_FREE_MIN 9
/* cnt.v_pageout_free_min */
86
#define VM_PAGEOUT_ALGORITHM 10
/* pageout algorithm */
87
#define VM_SWAPPING_ENABLED 11
/* swapping enabled */
88
#define VM_MAXID 12
/* number of valid vm ids */
89
90
#define CTL_VM_NAMES { \
91
{ 0, 0 }, \
92
{ "vmtotal", CTLTYPE_STRUCT }, \
93
{ "loadavg", CTLTYPE_STRUCT }, \
94
{ "v_free_min", CTLTYPE_INT }, \
95
{ "v_free_target", CTLTYPE_INT }, \
96
{ "v_free_reserved", CTLTYPE_INT }, \
97
{ "v_inactive_target", CTLTYPE_INT }, \
98
{ "v_cache_min", CTLTYPE_INT }, \
99
{ "v_cache_max", CTLTYPE_INT }, \
100
{ "v_pageout_free_min", CTLTYPE_INT}, \
101
{ "pageout_algorithm", CTLTYPE_INT}, \
102
{ "swapping_enabled", CTLTYPE_INT},\
103
104
105
106
* Return values from the VM routines.
107
108
#define KERN_SUCCESS 0
109
#define KERN_INVALID_ADDRESS 1
110
#define KERN_PROTECTION_FAILURE 2
111
#define KERN_NO_SPACE 3
112
#define KERN_INVALID_ARGUMENT 4
113
#define KERN_FAILURE 5
114
#define KERN_RESOURCE_SHORTAGE 6
115
#define KERN_NOT_RECEIVER 7
116
#define KERN_NO_ACCESS 8
117
118
#ifndef ASSEMBLER
119
#ifdef _KERNEL
120
#define num_pages(x) \
121
((vm_offset_t)((((vm_offset_t)(x)) + PAGE_MASK) >> PAGE_SHIFT))
122
extern
unsigned
long
maxtsiz;
123
extern
unsigned
long
dfldsiz;
124
extern
unsigned
long
maxdsiz;
125
extern
unsigned
long
dflssiz;
126
extern
unsigned
long
maxssiz;
127
extern
unsigned
long
sgrowsiz;
128
#endif
/* _KERNEL */
129
#endif
/* ASSEMBLER */
130
#endif
/* _VM_PARAM_ */
vmparam.h
