Data Structures | Macros
ttycom.h File Reference
#include <sys/ioccom.h>
Include dependency graph for ttycom.h:
struct  winsize
#define TIOCMODG   _IOR('t', 3, int) /* get modem control state */
#define TIOCMODS   _IOW('t', 4, int) /* set modem control state */
#define TIOCM_LE   0001 /* line enable */
#define TIOCM_DTR   0002 /* data terminal ready */
#define TIOCM_RTS   0004 /* request to send */
#define TIOCM_ST   0010 /* secondary transmit */
#define TIOCM_SR   0020 /* secondary receive */
#define TIOCM_CTS   0040 /* clear to send */
#define TIOCM_CAR   0100 /* carrier detect */
#define TIOCM_CD   TIOCM_CAR
#define TIOCM_RNG   0200 /* ring */
#define TIOCM_RI   TIOCM_RNG
#define TIOCM_DSR   0400 /* data set ready */
#define TIOCEXCL   _IO('t', 13) /* set exclusive use of tty */
#define TIOCNXCL   _IO('t', 14) /* reset exclusive use of tty */
#define TIOCFLUSH   _IOW('t', 16, int) /* flush buffers */
#define TIOCGETA   _IOR('t', 19, struct termios) /* get termios struct */
#define TIOCSETA   _IOW('t', 20, struct termios) /* set termios struct */
#define TIOCSETAW   _IOW('t', 21, struct termios) /* drain output, set */
#define TIOCSETAF   _IOW('t', 22, struct termios) /* drn out, fls in, set */
#define TIOCGETD   _IOR('t', 26, int) /* get line discipline */
#define TIOCSETD   _IOW('t', 27, int) /* set line discipline */
#define TIOCSBRK   _IO('t', 123) /* set break bit */
#define TIOCCBRK   _IO('t', 122) /* clear break bit */
#define TIOCSDTR   _IO('t', 121) /* set data terminal ready */
#define TIOCCDTR   _IO('t', 120) /* clear data terminal ready */
#define TIOCGPGRP   _IOR('t', 119, int) /* get pgrp of tty */
#define TIOCSPGRP   _IOW('t', 118, int) /* set pgrp of tty */
#define TIOCOUTQ   _IOR('t', 115, int) /* output queue size */
#define TIOCSTI   _IOW('t', 114, char) /* simulate terminal input */
#define TIOCNOTTY   _IO('t', 113) /* void tty association */
#define TIOCPKT   _IOW('t', 112, int) /* pty: set/clear packet mode */
#define TIOCPKT_DATA   0x00 /* data packet */
#define TIOCPKT_FLUSHREAD   0x01 /* flush packet */
#define TIOCPKT_FLUSHWRITE   0x02 /* flush packet */
#define TIOCPKT_STOP   0x04 /* stop output */
#define TIOCPKT_START   0x08 /* start output */
#define TIOCPKT_NOSTOP   0x10 /* no more ^S, ^Q */
#define TIOCPKT_DOSTOP   0x20 /* now do ^S ^Q */
#define TIOCPKT_IOCTL   0x40 /* state change of pty driver */
#define TIOCSTOP   _IO('t', 111) /* stop output, like ^S */
#define TIOCSTART   _IO('t', 110) /* start output, like ^Q */
#define TIOCMSET   _IOW('t', 109, int) /* set all modem bits */
#define TIOCMBIS   _IOW('t', 108, int) /* bis modem bits */
#define TIOCMBIC   _IOW('t', 107, int) /* bic modem bits */
#define TIOCMGET   _IOR('t', 106, int) /* get all modem bits */
#define TIOCREMOTE   _IOW('t', 105, int) /* remote input editing */
#define TIOCGWINSZ   _IOR('t', 104, struct winsize) /* get window size */
#define TIOCSWINSZ   _IOW('t', 103, struct winsize) /* set window size */
#define TIOCUCNTL   _IOW('t', 102, int) /* pty: set/clr usr cntl mode */
#define TIOCSTAT   _IO('t', 101) /* simulate ^T status message */
#define UIOCCMD(n)   _IO('u', n) /* usr cntl op "n" */
#define TIOCCONS   _IOW('t', 98, int) /* become virtual console */
#define TIOCSCTTY   _IO('t', 97) /* become controlling tty */
#define TIOCEXT   _IOW('t', 96, int) /* pty: external processing */
#define TIOCSIG   _IO('t', 95) /* pty: generate signal */
#define TIOCDRAIN   _IO('t', 94) /* wait till output drained */
#define TIOCMSDTRWAIT   _IOW('t', 91, int) /* modem: set wait on close */
#define TIOCMGDTRWAIT   _IOR('t', 90, int) /* modem: get wait on close */
#define TIOCTIMESTAMP
#define TIOCDCDTIMESTAMP
#define TIOCSDRAINWAIT   _IOW('t', 87, int) /* set ttywait timeout */
#define TIOCGDRAINWAIT   _IOR('t', 86, int) /* get ttywait timeout */
#define TIOCDSIMICROCODE
#define TTYDISC   0 /* termios tty line discipline */
#define TABLDISC   3 /* tablet discipline */
#define SLIPDISC   4 /* serial IP discipline */
#define PPPDISC   5 /* PPP discipline */
◆ TIOCDCDTIMESTAMP
Value:
_IOR('t', 88, struct timeval) /* enable/get timestamp
* of last DCd rise */
◆ TIOCDSIMICROCODE
Value:
_IO('t', 85) /* download microcode to
* DSI Softmodem */
◆ TIOCTIMESTAMP
Value:
_IOR('t', 89, struct timeval) /* enable/get timestamp
* of last input event */
