#include "deflate.h"
struct | static_tree_desc_s |
local void tr_static_init | OF ((void)) |
local void init_block | OF ((deflate_state *s)) |
local void pqdownheap | OF ((deflate_state *s, ct_data *tree, int k)) |
local void gen_bitlen | OF ((deflate_state *s, tree_desc *desc)) |
local void gen_codes | OF ((ct_data *tree, int max_code, ushf *bl_count)) |
local void scan_tree | OF ((deflate_state *s, ct_data *tree, int max_code)) |
local void send_all_trees | OF ((deflate_state *s, int lcodes, int dcodes, int blcodes)) |
local void compress_block | OF ((deflate_state *s, ct_data *ltree, ct_data *dtree)) |
local unsigned bi_reverse | OF ((unsigned value, int length)) |
local void copy_block | OF ((deflate_state *s, charf *buf, unsigned len, int header)) |
local void | tr_static_init () |
void ZLIB_INTERNAL | _tr_init (deflate_state *s) |
local void | init_block (deflate_state *s) |
local void | pqdownheap (deflate_state *s, ct_data *tree, int k) |
local void | gen_bitlen (deflate_state *s, tree_desc *desc) |
local void | gen_codes (ct_data *tree, int max_code, ushf *bl_count) |
local void | build_tree (deflate_state *s, tree_desc *desc) |
local void | scan_tree (deflate_state *s, ct_data *tree, int max_code) |
local void | send_tree (deflate_state *s, ct_data *tree, int max_code) |
local int | build_bl_tree (deflate_state *s) |
local void | send_all_trees (deflate_state *s, int lcodes, int dcodes, int blcodes) |
void ZLIB_INTERNAL | _tr_stored_block (deflate_state *s, charf *buf, ulg stored_len, int last) |
void ZLIB_INTERNAL | _tr_align (deflate_state *s) |
void ZLIB_INTERNAL | _tr_flush_block (deflate_state *s, charf *buf, ulg stored_len, int last) |
int ZLIB_INTERNAL | _tr_tally (deflate_state *s, unsigned dist, unsigned lc) |
local void | compress_block (deflate_state *s, ct_data *ltree, ct_data *dtree) |
local int | detect_data_type (deflate_state *s) |
local unsigned | bi_reverse (unsigned code, int len) |
local void | bi_flush (deflate_state *s) |
local void | bi_windup (deflate_state *s) |
local void | copy_block (deflate_state *s, charf *buf, unsigned len, int header) |
local const int | extra_lbits [LENGTH_CODES] = {0,0,0,0,0,0,0,0,1,1,1,1,2,2,2,2,3,3,3,3,4,4,4,4,5,5,5,5,0} |
local const int | extra_dbits [D_CODES] = {0,0,0,0,1,1,2,2,3,3,4,4,5,5,6,6,7,7,8,8,9,9,10,10,11,11,12,12,13,13} |
local const int | extra_blbits [BL_CODES] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,3,7} |
local const uch | bl_order [BL_CODES] = {16,17,18,0,8,7,9,6,10,5,11,4,12,3,13,2,14,1,15} |
local ct_data | static_ltree [L_CODES+2] |
local ct_data | static_dtree [D_CODES] |
uch | _dist_code [DIST_CODE_LEN] |
uch | _length_code [MAX_MATCH-MIN_MATCH+1] |
local int | base_length [LENGTH_CODES] |
local int | base_dist [D_CODES] |
local static_tree_desc | static_l_desc |
local static_tree_desc | static_d_desc |
local static_tree_desc | static_bl_desc |
#define pqremove | ( | s, | |
tree, | |||
top | |||
#define put_short | ( | s, | |
w | |||
#define send_bits | ( | s, | |
value, | |||
length | |||
#define smaller | ( | tree, | |
n, | |||
m, | |||
depth | |||
local static_tree_desc static_bl_desc |
local static_tree_desc static_d_desc |
local static_tree_desc static_l_desc |
