admin
rtems-admin.git
doxygen
builder
latest
rtems.git
libcsupport
include
sys
termios.h
1
11
12
* COPYRIGHT (c) 1989-2011.
13
* On-Line Applications Research Corporation (OAR).
14
15
* The license and distribution terms for this file may be
16
* found in the file LICENSE in this distribution or at
17
* http://www.rtems.org/license/LICENSE.
18
19
20
#ifndef TERMIOS_H
21
#define TERMIOS_H
22
23
#include <sys/types.h>
24
25
#ifdef __cplusplus
26
extern
"C"
27
#endif
28
37
typedef
unsigned
char
cc_t
38
typedef
unsigned
int
speed_t;
39
typedef
unsigned
int
tcflag_t;
40
41
#define NCCS 19
42
struct
termios
43
tcflag_t c_iflag;
/* input mode flags */
44
tcflag_t c_oflag;
/* output mode flags */
45
tcflag_t c_cflag;
/* control mode flags */
46
tcflag_t c_lflag;
/* local mode flags */
47
cc_t c_line;
/* line discipline */
48
cc_t c_cc[NCCS];
/* control characters */
49
50
55
#define _POSIX_VDISABLE 0
56
57
/* c_cc characters */
58
#define VINTR 0
59
#define VQUIT 1
60
#define VERASE 2
61
#define VKILL 3
62
#define VEOF 4
63
#define VTIME 5
64
#define VMIN 6
65
#define VSWTC 7
66
#define VSTART 8
67
#define VSTOP 9
68
#define VSUSP 10
69
#define VEOL 11
70
#define VREPRINT 12
71
#define VDISCARD 13
72
#define VWERASE 14
73
#define VLNEXT 15
74
#define VEOL2 16
75
76
/* c_iflag bits */
77
#define IGNBRK 0000001
78
#define BRKINT 0000002
79
#define IGNPAR 0000004
80
#define PARMRK 0000010
81
#define INPCK 0000020
82
#define ISTRIP 0000040
83
#define INLCR 0000100
84
#define IGNCR 0000200
85
#define ICRNL 0000400
86
#define IUCLC 0001000
87
#define IXON 0002000
88
#define IXANY 0004000
89
#define IXOFF 0010000
90
#define IMAXBEL 0020000
91
92
/* c_oflag bits */
93
#define OPOST 0000001
94
#define OLCUC 0000002
95
#define ONLCR 0000004
96
#define OCRNL 0000010
97
#define ONOCR 0000020
98
#define ONLRET 0000040
99
#define OFILL 0000100
100
#define OFDEL 0000200
101
#define NLDLY 0000400
102
#define NL0 0000000
103
#define NL1 0000400
104
#define CRDLY 0003000
105
#define CR0 0000000
106
#define CR1 0001000
107
#define CR2 0002000
108
#define CR3 0003000
109
#define TABDLY 0014000
110
#define TAB0 0000000
111
#define TAB1 0004000
112
#define TAB2 0010000
113
#define TAB3 0014000
114
#define XTABS 0014000
115
#define BSDLY 0020000
116
#define BS0 0000000
117
#define BS1 0020000
118
#define VTDLY 0040000
119
#define VT0 0000000
120
#define VT1 0040000
121
#define FFDLY 0100000
122
#define FF0 0000000
123
#define FF1 0100000
124
125
/* c_cflag bit meaning */
126
#define CBAUD 0010017
127
#define B0 0000000
/* hang up */
128
#define B50 0000001
129
#define B75 0000002
130
#define B110 0000003
131
#define B134 0000004
132
#define B150 0000005
133
#define B200 0000006
134
#define B300 0000007
135
#define B600 0000010
136
#define B1200 0000011
137
#define B1800 0000012
138
#define B2400 0000013
139
#define B4800 0000014
140
#define B9600 0000015
141
#define B19200 0000016
142
#define B38400 0000017
143
#define EXTA B19200
144
#define EXTB B38400
145
#define CSIZE 0000060
146
#define CS5 0000000
147
#define CS6 0000020
148
#define CS7 0000040
149
#define CS8 0000060
150
#define CSTOPB 0000100
151
#define CREAD 0000200
152
#define PARENB 0000400
153
#define PARODD 0001000
154
#define HUPCL 0002000
155
#define CLOCAL 0004000
156
#define CBAUDEX 0010000
157
#define B57600 0010001
158
#define B115200 0010002
159
#define B230400 0010003
160
#define B460800 0010004
161
#define CIBAUD 002003600000
/* input baud rate (not used) */
162
#define CRTSCTS 020000000000
/* flow control */
163
164
#define RTEMS_TERMIOS_NUMBER_BAUD_RATES 20
165
166
/* c_lflag bits */
167
#define ISIG 0000001
168
#define ICANON 0000002
169
#define XCASE 0000004
170
#define ECHO 0000010
171
#define ECHOE 0000020
172
#define ECHOK 0000040
173
#define ECHONL 0000100
174
#define NOFLSH 0000200
175
#define TOSTOP 0000400
176
#define ECHOCTL 0001000
177
#define ECHOPRT 0002000
178
#define ECHOKE 0004000
179
#define FLUSHO 0010000
180
#define PENDIN 0040000
181
#define IEXTEN 0100000
182
183
/* tcflow() and TCXONC use these */
184
#define TCOOFF 0
185
#define TCOON 1
186
#define TCIOFF 2
187
#define TCION 3
188
189
/* tcflush() and TCFLSH use these */
190
#define TCIFLUSH 0
191
#define TCOFLUSH 1
192
#define TCIOFLUSH 2
193
194
/* tcsetattr uses these */
195
#define TCSANOW 0
196
#define TCSADRAIN 1
197
#define TCSAFLUSH 2
198
199
int
tcdrain(
int
200
int
tcflow(
int
int
201
int
tcflush(
int
int
202
int
tcgetattr(
int
struct
termios
203
int
tcsetattr(
int
int
struct
termios
204
int
tcdrain(
int
205
pid_t tcgetprgrp(
int
206
int
tcsetprgrp(
int
, pid_t);
207
int
tcsendbreak(
int
int
208
speed_t cfgetospeed(
const
struct
termios
*tp);
209
int
cfsetospeed(
struct
termios
*tp, speed_t speed);
210
speed_t cfgetispeed(
const
struct
termios
*tp);
211
int
cfsetispeed(
struct
termios
212
void
cfmakeraw(
struct
termios
*tp);
213
int
cfsetspeed(
struct
termios
214
217
#ifdef __cplusplus
218
219
#endif
220
221
#endif
/* TERMIOS_H */
termios
Definition:
termios.h:42
cc_t
unsigned char cc_t
POSIX Termios Implementation.
Definition:
termios.h:37
