sh/rtems/asm.h
1
17 /*
18  * Authors: Ralf Corsepius (corsepiu@faw.uni-ulm.de) and
19  * Bernd Becker (becker@faw.uni-ulm.de)
20  *
21  * COPYRIGHT:
22  *
23  * This file is based on similar code found in newlib available
24  * from ftp.cygnus.com. The file which was used had no copyright
25  * notice. This file is freely distributable as long as the source
26  * of the file is noted. This file is:
27  *
28  *
29  * COPYRIGHT (c) 1997-1998, FAW Ulm, Germany
30  *
31  * This program is distributed in the hope that it will be useful,
32  * but WITHOUT ANY WARRANTY; without even the implied warranty of
33  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
34  *
35  *
36  * COPYRIGHT (c) 1998-2001.
37  * On-Line Applications Research Corporation (OAR).
38  *
39  * The license and distribution terms for this file may be
40  * found in the file LICENSE in this distribution or at
41  * http://www.rtems.org/license/LICENSE.
42  */
43
44 #ifndef _RTEMS_ASM_H
45 #define _RTEMS_ASM_H
46
47 /*
48  * Indicate we are in an assembly file and get the basic CPU definitions.
49  */
50
51 #ifndef ASM
52 #define ASM
53 #endif
54
55 #include <rtems/score/cpuopts.h>
56 #include <rtems/score/sh.h>
57
58 /*
59  * Recent versions of GNU cpp define variables which indicate the
60  * need for underscores and percents. If not using GNU cpp or
61  * the version does not support this, then you will obviously
62  * have to define these as appropriate.
63  */
64
65 #ifndef __USER_LABEL_PREFIX__
66 #define __USER_LABEL_PREFIX__ _
67 #endif
68
69 #ifndef __REGISTER_PREFIX__
70 #define __REGISTER_PREFIX__
71 #endif
72
73 #include <rtems/concat.h>
74
75 /* Use the right prefix for global labels. */
76
77 #define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
78
79 /* Use the right prefix for registers. */
80
81 #define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
82
83 /*
84  * define macros for all of the registers on this CPU
85  *
86  * EXAMPLE: #define d0 REG (d0)
87  */
88 #define r0 REG (r0)
89 #define r1 REG (r1)
90 #define r2 REG (r2)
91 #define r3 REG (r3)
92 #define r4 REG (r4)
93 #define r5 REG (r5)
94 #define r6 REG (r6)
95 #define r7 REG (r7)
96 #define r8 REG (r8)
97 #define r9 REG (r9)
98 #define r10 REG (r10)
99 #define r11 REG (r11)
100 #define r12 REG (r12)
101 #define r13 REG (r13)
102 #define r14 REG (r14)
103 #define r15 REG (r15)
104 #define vbr REG (vbr)
105 #define gbr REG (gbr)
106 #define pr REG (pr)
107 #define mach REG (mach)
108 #define macl REG (macl)
109 #define sr REG (sr)
110 #define pc REG (pc)
111
112 /*
113  * Define macros to handle section beginning and ends.
114  */
115
116
117 #define BEGIN_CODE_DCL .text
118 #define END_CODE_DCL
119 #define BEGIN_DATA_DCL .data
120 #define END_DATA_DCL
121 #define BEGIN_CODE .text
122 #define END_CODE
123 #define BEGIN_DATA
124 #define END_DATA
125 #define BEGIN_BSS
126 #define END_BSS
127 #define END
128
129 /*
130  * Following must be tailor for a particular flavor of the C compiler.
131  * They may need to put underscores in front of the symbols.
132  */
133
134 #define PUBLIC(sym) .global SYM (sym)
135 #define EXTERN(sym) .global SYM (sym)
136
137 #endif
Hitachi SH CPU Department Source.
This include file defines ANSI concatenation macros.
