19 #ifndef _RTEMS_POSIX_SEMAPHORE_H 20 #define _RTEMS_POSIX_SEMAPHORE_H 55 #if defined(RTEMS_USE_16_BIT_OBJECT) Constants and Structures Associated with the Object Handler.
The following defines the Object Control Block used to manage each object local to this node...
Definition: score/include/rtems/score/object.h:232
The following defines the control block used to manage each counting semaphore.
Definition: coresem.h:69
Definition: rtems/posix/semaphore.h:43
Private Support Information for POSIX Semaphores.
Data Associated with the Counting Semaphore Handler.
