route.h
1 /*
2  * Copyright (c) 1980, 1986, 1993
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 4. Neither the name of the University nor the names of its contributors
14  * may be used to endorse or promote products derived from this software
15  * without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * @(#)route.h 8.4 (Berkeley) 1/9/95
30  * $FreeBSD: src/sys/net/route.h,v 1.65 2006/03/15 19:39:09 andre Exp $
31  */
32
33
34 #ifndef _NET_ROUTE_H_
35 #define _NET_ROUTE_H_
36
37 #include <sys/socket.h> /* struct sockaddr */
38 /*
39  * Kernel resident routing tables.
40  *
41  * The routing tables are initialized when interface addresses
42  * are set by making entries for all directly connected interfaces.
43  */
44
45 /*
46  * A route consists of a destination address and a reference
47  * to a routing entry. These are often held by protocols
48  * in their control blocks, e.g. inpcb.
49  */
50 struct route {
51  struct rtentry *ro_rt;
52  struct sockaddr ro_dst;
53 };
54
55 /*
56  * These numbers are used by reliable protocols for determining
57  * retransmission behavior and are included in the routing structure.
58  */
59 struct rt_metrics_lite {
60  u_long rmx_mtu; /* MTU for this path */
61  u_long rmx_expire; /* lifetime for route, e.g. redirect */
62  u_long rmx_pksent; /* packets sent using this route */
63 };
64
65 struct rt_metrics {
66  u_long rmx_locks; /* Kernel must leave these values alone */
67  u_long rmx_mtu; /* MTU for this path */
68  u_long rmx_hopcount; /* max hops expected */
69  u_long rmx_expire; /* lifetime for route, e.g. redirect */
70  u_long rmx_recvpipe; /* inbound delay-bandwidth product */
71  u_long rmx_sendpipe; /* outbound delay-bandwidth product */
72  u_long rmx_ssthresh; /* outbound gateway buffer limit */
73  u_long rmx_rtt; /* estimated round trip time */
74  u_long rmx_rttvar; /* estimated rtt variance */
75  u_long rmx_pksent; /* packets sent using this route */
76  u_long rmx_filler[4]; /* will be used for T/TCP later */
77 };
78
79 /*
80  * rmx_rtt and rmx_rttvar are stored as microseconds;
81  * RTTTOPRHZ(rtt) converts to a value suitable for use
82  * by a protocol slowtimo counter.
83  */
84 #define RTM_RTTUNIT 1000000 /* units for rtt, rttvar, as units per sec */
85 #define RTTTOPRHZ(r) ((r) / (RTM_RTTUNIT / PR_SLOWHZ))
86
87 /*
88  * XXX kernel function pointer `rt_output' is visible to applications.
89  */
90 struct mbuf;
91
92 /*
93  * We distinguish between routes to hosts and routes to networks,
94  * preferring the former if available. For each route we infer
95  * the interface to use from the gateway address supplied when
96  * the route was entered. Routes that forward packets through
97  * gateways are marked so that the output routines know to address the
98  * gateway rather than the ultimate destination.
99  */
100 #ifndef RNF_NORMAL
101 #include <net/radix.h>
102 #endif
103 struct rtentry {
104  struct radix_node rt_nodes[2]; /* tree glue, and other values */
105 #define rt_key(r) ((struct sockaddr *)((r)->rt_nodes->rn_key))
106 #define rt_mask(r) ((struct sockaddr *)((r)->rt_nodes->rn_mask))
107  struct sockaddr *rt_gateway; /* value */
108  u_long rt_flags; /* up/down?, host/net */
109  struct ifnet *rt_ifp; /* the answer: interface to use */
110  struct ifaddr *rt_ifa; /* the answer: interface address to use */
111  struct rt_metrics rt_rmx; /* metrics used by rx'ing protocols */
112  long rt_refcnt; /* # held references */
113  struct sockaddr *rt_genmask; /* for generation of cloned routes */
114  caddr_t rt_llinfo; /* pointer to link level info cache */
115  struct rtentry *rt_gwroute; /* implied entry for gatewayed routes */
116  struct rtentry *rt_parent; /* cloning parent of this route */
117 };
118
119 /*
120  * Following structure necessary for 4.3 compatibility;
121  * We should eventually move it to a compat file.
122  */
123 struct ortentry {
124  u_long rt_hash; /* to speed lookups */
125  struct sockaddr rt_dst; /* key */
126  struct sockaddr rt_gateway; /* value */
127  short rt_flags; /* up/down?, host/net */
128  short rt_refcnt; /* # held references */
129  u_long rt_use; /* raw # packets forwarded */
130  struct ifnet *rt_ifp; /* the answer: interface to use */
131 };
132
133 #define rt_use rt_rmx.rmx_pksent
134
135 #define RTF_UP 0x1 /* route usable */
136 #define RTF_GATEWAY 0x2 /* destination is a gateway */
137 #define RTF_HOST 0x4 /* host entry (net otherwise) */
138 #define RTF_REJECT 0x8 /* host or net unreachable */
139 #define RTF_DYNAMIC 0x10 /* created dynamically (by redirect) */
140 #define RTF_MODIFIED 0x20 /* modified dynamically (by redirect) */
141 #define RTF_DONE 0x40 /* message confirmed */
142 /* 0x80 unused, was RTF_DELCLONE */
143 #define RTF_CLONING 0x100 /* generate new routes on use */
144 #define RTF_XRESOLVE 0x200 /* external daemon resolves name */
145 #define RTF_LLINFO 0x400 /* generated by link layer (e.g. ARP) */
146 #define RTF_STATIC 0x800 /* manually added */
147 #define RTF_BLACKHOLE 0x1000 /* just discard pkts (during updates) */
148 #define RTF_PROTO2 0x4000 /* protocol specific routing flag */
149 #define RTF_PROTO1 0x8000 /* protocol specific routing flag */
150
151 #define RTF_PRCLONING 0x10000 /* protocol requires cloning */
152 #define RTF_WASCLONED 0x20000 /* route generated through cloning */
153 #define RTF_PROTO3 0x40000 /* protocol specific routing flag */
154 /* 0x80000 unused */
155 #define RTF_PINNED 0x100000 /* future use */
156 #define RTF_LOCAL 0x200000 /* route represents a local address */
157 #define RTF_BROADCAST 0x400000 /* route represents a bcast address */
158 #define RTF_MULTICAST 0x800000 /* route represents a mcast address */
159  /* 0x1000000 and up unassigned */
160
161 /*
162  * Routing statistics.
163  */
164 struct rtstat {
165  short rts_badredirect; /* bogus redirect calls */
166  short rts_dynamic; /* routes created by redirects */
167  short rts_newgateway; /* routes modified by redirects */
168  short rts_unreach; /* lookups which failed */
169  short rts_wildcard; /* lookups satisfied by a wildcard */
170 };
171 /*
172  * Structures for routing messages.
173  */
174 struct rt_msghdr {
175  u_short rtm_msglen; /* to skip over non-understood messages */
176  u_char rtm_version; /* future binary compatibility */
177  u_char rtm_type; /* message type */
178  u_short rtm_index; /* index for associated ifp */
179  int rtm_flags; /* flags, incl. kern & message, e.g. DONE */
180  int rtm_addrs; /* bitmask identifying sockaddrs in msg */
181  pid_t rtm_pid; /* identify sender */
182  int rtm_seq; /* for sender to identify action */
183  int rtm_errno; /* why failed */
184  int rtm_use; /* from rtentry */
185  u_long rtm_inits; /* which metrics we are initializing */
186  struct rt_metrics rtm_rmx; /* metrics themselves */
187 };
188
189 #define RTM_VERSION 5 /* Up the ante and ignore older versions */
190
191 /*
192  * Message types.
193  */
194 #define RTM_ADD 0x1 /* Add Route */
195 #define RTM_DELETE 0x2 /* Delete Route */
196 #define RTM_CHANGE 0x3 /* Change Metrics or flags */
197 #define RTM_GET 0x4 /* Report Metrics */
198 #define RTM_LOSING 0x5 /* Kernel Suspects Partitioning */
199 #define RTM_REDIRECT 0x6 /* Told to use different route */
200 #define RTM_MISS 0x7 /* Lookup failed on this address */
201 #define RTM_LOCK 0x8 /* fix specified metrics */
202 #define RTM_OLDADD 0x9 /* caused by SIOCADDRT */
203 #define RTM_OLDDEL 0xa /* caused by SIOCDELRT */
204 #define RTM_RESOLVE 0xb /* req to resolve dst to LL addr */
205 #define RTM_NEWADDR 0xc /* address being added to iface */
206 #define RTM_DELADDR 0xd /* address being removed from iface */
207 #define RTM_IFINFO 0xe /* iface going up/down etc. */
208 #define RTM_NEWMADDR 0xf /* mcast group membership being added to if */
209 #define RTM_DELMADDR 0x10 /* mcast group membership being deleted */
210 #define RTM_IFANNOUNCE 0x11 /* iface arrival/departure */
211 #define RTM_IEEE80211 0x12 /* IEEE80211 wireless event */
212
213 /*
214  * Bitmask values for rtm_inits and rmx_locks.
215  */
216 #define RTV_MTU 0x1 /* init or lock _mtu */
217 #define RTV_HOPCOUNT 0x2 /* init or lock _hopcount */
218 #define RTV_EXPIRE 0x4 /* init or lock _expire */
219 #define RTV_RPIPE 0x8 /* init or lock _recvpipe */
220 #define RTV_SPIPE 0x10 /* init or lock _sendpipe */
221 #define RTV_SSTHRESH 0x20 /* init or lock _ssthresh */
222 #define RTV_RTT 0x40 /* init or lock _rtt */
223 #define RTV_RTTVAR 0x80 /* init or lock _rttvar */
224
225 /*
226  * Bitmask values for rtm_addrs.
227  */
228 #define RTA_DST 0x1 /* destination sockaddr present */
229 #define RTA_GATEWAY 0x2 /* gateway sockaddr present */
230 #define RTA_NETMASK 0x4 /* netmask sockaddr present */
231 #define RTA_GENMASK 0x8 /* cloning mask sockaddr present */
232 #define RTA_IFP 0x10 /* interface name sockaddr present */
233 #define RTA_IFA 0x20 /* interface addr sockaddr present */
234 #define RTA_AUTHOR 0x40 /* sockaddr for author of redirect */
235 #define RTA_BRD 0x80 /* for NEWADDR, broadcast or p-p dest addr */
236
237 /*
238  * Index offsets for sockaddr array for alternate internal encoding.
239  */
240 #define RTAX_DST 0 /* destination sockaddr present */
241 #define RTAX_GATEWAY 1 /* gateway sockaddr present */
242 #define RTAX_NETMASK 2 /* netmask sockaddr present */
243 #define RTAX_GENMASK 3 /* cloning mask sockaddr present */
244 #define RTAX_IFP 4 /* interface name sockaddr present */
245 #define RTAX_IFA 5 /* interface addr sockaddr present */
246 #define RTAX_AUTHOR 6 /* sockaddr for author of redirect */
247 #define RTAX_BRD 7 /* for NEWADDR, broadcast or p-p dest addr */
248 #define RTAX_MAX 8 /* size of array to allocate */
249
250 struct rt_addrinfo {
251  int rti_addrs;
252  struct sockaddr *rti_info[RTAX_MAX];
253 };
254
255 struct route_cb {
256  int ip_count;
257  int ipx_count;
258  int ns_count;
259  int iso_count;
260  int any_count;
261 };
262
263 #ifdef _KERNEL
264 #define RTFREE(rt) \
265  do { \
266  if ((rt)->rt_refcnt <= 1) \
267  rtfree(rt); \
268  else \
269  (rt)->rt_refcnt--; \
270  } while (0)
271
272 extern struct route_cb route_cb;
273 extern struct radix_node_head *rt_tables[AF_MAX+1];
274
275 void route_init(void);
276 void rt_ifmsg(struct ifnet *);
277 void rt_missmsg(int, struct rt_addrinfo *, int, int);
278 void rt_newaddrmsg(int, struct ifaddr *, int, struct rtentry *);
279 int rt_setgate(struct rtentry *, struct sockaddr *, struct sockaddr *);
280 void rtalloc_ign(struct route *, unsigned long);
281 void rtalloc(struct route *ro); /* XXX deprecated, use rtalloc_ign(ro, 0) */
282 struct rtentry *
283  rtalloc1(struct sockaddr *, int, unsigned long);
284 void rtfree(struct rtentry *);
285 int rtinit(struct ifaddr *, int, int);
286 int rtioctl(int, caddr_t, struct proc *);
287 void rtredirect(struct sockaddr *, struct sockaddr *,
288  struct sockaddr *, int, struct sockaddr *, struct rtentry **);
289 int rtrequest(int, struct sockaddr *,
290  struct sockaddr *, struct sockaddr *, int, struct rtentry **);
291 #endif
292
293 #endif
Definition: route.h:175
Definition: route.h:124
Definition: radix.h:106
Definition: proc.h:5
Definition: route.h:51
Definition: radix.h:41
Definition: route.h:251
Definition: route.h:165
Definition: socket.h:180
Definition: if_var.h:99
Definition: if_var.h:211
Definition: mbuf.h:103
Definition: route.h:60
Definition: route.h:104
Definition: route.h:66
