#include <sys/param.h>#include <sys/types.h>#include <sys/cdefs.h>#include <stdio.h>#include <netinet/in.h>
| struct | res_sym |
| struct | __res_state |
| #define | __RES 19960801 |
| #define | _PATH_RESCONF "/etc/resolv.conf" |
| #define | MAXNS 3 /*%< max # name servers we'll track */ |
| #define | MAXDFLSRCH 3 /*%< # default domain levels to try */ |
| #define | MAXDNSRCH 6 /*%< max # domains in search path */ |
| #define | LOCALDOMAINPARTS 2 /*%< min levels in name that is "local" */ |
| #define | RES_TIMEOUT 5 /*%< min. seconds between retries */ |
| #define | MAXRESOLVSORT 10 /*%< number of net to sort on */ |
| #define | RES_MAXNDOTS 15 /*%< should reflect bit field size */ |
| #define | nsaddr nsaddr_list[0] /*%< for backward compatibility */ |
| #define | RES_INIT 0x00000001 /*%< address initialized */ |
| #define | RES_DEBUG 0x00000002 /*%< print debug messages */ |
| #define | RES_AAONLY 0x00000004 /*%< authoritative answers only (!IMPL)*/ |
| #define | RES_USEVC 0x00000008 /*%< use virtual circuit */ |
| #define | RES_PRIMARY 0x00000010 /*%< query primary server only (!IMPL) */ |
| #define | RES_IGNTC 0x00000020 /*%< ignore truncation errors */ |
| #define | RES_RECURSE 0x00000040 /*%< recursion desired */ |
| #define | RES_DEFNAMES 0x00000080 /*%< use default domain name */ |
| #define | RES_STAYOPEN 0x00000100 /*%< Keep TCP socket open */ |
| #define | RES_DNSRCH 0x00000200 /*%< search up local domain tree */ |
| #define | RES_INSECURE1 0x00000400 /*%< type 1 security disabled */ |
| #define | RES_INSECURE2 0x00000800 /*%< type 2 security disabled */ |
| #define | RES_NOALIASES 0x00001000 /*%< shuts off HOSTALIASES feature */ |
| #define | RES_USE_INET6 0x00002000 /*%< use/map IPv6 in gethostbyname() */ |
| #define | RES_NOTLDQUERY 0x00004000 /*%< Don't query TLD names */ |
| #define | RES_DEFAULT |
| #define | RES_PRF_STATS 0x00000001 |
| #define | RES_PRF_UPDATE 0x00000002 |
| #define | RES_PRF_CLASS 0x00000004 |
| #define | RES_PRF_CMD 0x00000008 |
| #define | RES_PRF_QUES 0x00000010 |
| #define | RES_PRF_ANS 0x00000020 |
| #define | RES_PRF_AUTH 0x00000040 |
| #define | RES_PRF_ADD 0x00000080 |
| #define | RES_PRF_HEAD1 0x00000100 |
| #define | RES_PRF_HEAD2 0x00000200 |
| #define | RES_PRF_TTLID 0x00000400 |
| #define | RES_PRF_HEADX 0x00000800 |
| #define | RES_PRF_QUERY 0x00001000 |
| #define | RES_PRF_REPLY 0x00002000 |
| #define | RES_PRF_INIT 0x00004000 |
| #define | fp_nquery __fp_nquery |
| #define | fp_query __fp_query |
| #define | hostalias __hostalias |
| #define | p_query __p_query |
| #define | res_close __res_close |
| #define | res_init __res_init |
| #define | res_isourserver __res_isourserver |
| #define | res_mkquery __res_mkquery |
| #define | res_query __res_query |
| #define | res_querydomain __res_querydomain |
| #define | res_search __res_search |
| #define | res_send __res_send |
| #define | b64_ntop __b64_ntop |
| #define | b64_pton __b64_pton |
| #define | dn_comp __dn_comp |
| #define | dn_count_labels __dn_count_labels |
| #define | dn_expand __dn_expand |
| #define | dn_skipname __dn_skipname |
| #define | fp_resstat __fp_resstat |
| #define | loc_aton __loc_aton |
| #define | loc_ntoa __loc_ntoa |
| #define | p_cdname __p_cdname |
| #define | p_cdnname __p_cdnname |
| #define | p_class __p_class |
| #define | p_fqname __p_fqname |
| #define | p_fqnname __p_fqnname |
| #define | p_option __p_option |
| #define | p_secstodate __p_secstodate |
| #define | p_section __p_section |
| #define | p_time __p_time |
| #define | p_type __p_type |
| #define | putlong __putlong |
| #define | putshort __putshort |
| #define | res_dnok __res_dnok |
| #define | res_hnok __res_hnok |
| #define | res_mailok __res_mailok |
| #define | res_nameinquery __res_nameinquery |
| #define | res_ownok __res_ownok |
| #define | res_queriesmatch __res_queriesmatch |
| #define | res_randomid __res_randomid |
| #define | sym_ntop __sym_ntop |
| #define | sym_ntos __sym_ntos |
| #define | sym_ston __sym_ston |
| #define | res_send_setqhook __res_send_setqhook |
| #define | res_send_setrhook __res_send_setrhook |
| #define | res_mkupdate __res_mkupdate |
| #define | res_mkupdrec __res_mkupdrec |
| #define | res_freeupdrec __res_freeupdrec |
Typedefs | |
| typedef res_sendhookact(* | res_send_qhook) (struct sockaddr_in *const *ns, const u_char **query, int *querylen, u_char *ans, int anssiz, int *resplen) |
| typedef res_sendhookact(* | res_send_rhook) (const struct sockaddr_in *ns, const u_char *query, int querylen, u_char *ans, int anssiz, int *resplen) |
| typedef struct __res_state * | res_state |
Enumerations | |
| enum | res_sendhookact { res_goahead, res_nextns, res_modified, res_done, res_error } |
| __BEGIN_DECLS void | fp_nquery (const u_char *, int, FILE *) |
| void | fp_query (const u_char *, FILE *) |
| const char * | hostalias (const char *) |
| void | p_query (const u_char *) |
| void | res_close (void) |
| int | res_init (void) |
| int | res_isourserver (const struct sockaddr_in *) |
| int | res_mkquery (int, const char *, int, int, const u_char *, int, const u_char *, u_char *, int) |
| int | res_query (const char *, int, int, u_char *, int) |
| int | res_querydomain (const char *, const char *, int, int, u_char *, int) |
| int | res_search (const char *, int, int, u_char *, int) |
| int | res_send (const u_char *, int, u_char *, int) |
| __BEGIN_DECLS int | res_hnok (const char *) |
| int | res_ownok (const char *) |
| int | res_mailok (const char *) |
| int | res_dnok (const char *) |
| int | sym_ston (const struct res_sym *, const char *, int *) |
| const char * | sym_ntos (const struct res_sym *, int, int *) |
| const char * | sym_ntop (const struct res_sym *, int, int *) |
| int | b64_ntop (u_char const *, size_t, char *, size_t) |
| int | b64_pton (char const *, u_char *, size_t) |
| int | loc_aton (const char *, u_char *) |
| const char * | loc_ntoa (const u_char *, char *) |
| int | dn_skipname (const u_char *, const u_char *) |
| void | fp_resstat (struct __res_state *, FILE *) |
| void | putlong (u_int32_t, u_char *) |
| void | putshort (u_int16_t, u_char *) |
| const char * | p_class (int) |
| const char * | p_time (u_int32_t) |
| const char * | p_type (int) |
| const u_char * | p_cdnname (const u_char *, const u_char *, int, FILE *) |
| const u_char * | p_cdname (const u_char *, const u_char *, FILE *) |
| const u_char * | p_fqnname (const u_char *, const u_char *, int, char *, int) |
| const u_char * | p_fqname (const u_char *, const u_char *, FILE *) |
| const char * | p_option (u_long) |
| char * | p_secstodate (u_long) |
| int | dn_count_labels (const char *) |
| int | dn_comp (const char *, u_char *, int, u_char **, u_char **) |
| int | dn_expand (const u_char *, const u_char *, const u_char *, char *, int) |
| u_int | res_randomid (void) |
| int | res_nameinquery (const char *, int, int, const u_char *, const u_char *) |
| int | res_queriesmatch (const u_char *, const u_char *, const u_char *, const u_char *) |
| const char * | p_section (int, int) |
| void | res_send_setqhook (res_send_qhook) |
| void | res_send_setrhook (res_send_rhook) |
| int | h_errno |
| __END_DECLS struct __res_state | _res |
| const struct res_sym | __p_class_syms [] |
| const struct res_sym | __p_type_syms [] |
| #define RES_DEFAULT |
