23 #ifndef _RTEMS_POSIX_PTIMER_H 24 #define _RTEMS_POSIX_PTIMER_H 67 const struct itimerspec *value,
68 struct itimerspec *ovalue
76 struct itimerspec *value
int timer_gettime(timer_t timerid, struct itimerspec *value)
Set a Per-Process Timer.
Definition: timergettime.c:38
User Defined Configuration Parameters Specific For The POSIX API.
int timer_create(clockid_t clock_id, struct sigevent *evp, timer_t *timerid)
Create a Per-Process Timer.
int timer_settime(timer_t timerid, int flags, const struct itimerspec *value, struct itimerspec *ovalue)
int timer_delete(timer_t timerid)
Delete a Per-Process Timer.
Definition: posix/src/timerdelete.c:35
int timer_getoverrun(timer_t timerid)
Get overrun count for a Per-Process Timer.
Definition: timergetoverrun.c:29
void _POSIX_Timer_Manager_initialization(void)
POSIX Timer Manager Initialization.
Definition: ptimer.c:57
