19 #ifndef _RTEMS_POSIX_PRIORITYIMPL_H 20 #define _RTEMS_POSIX_PRIORITYIMPL_H 54 #define POSIX_SCHEDULER_MAXIMUM_PRIORITY (PRIORITY_MAXIMUM - 1) 60 #define POSIX_SCHEDULER_MINIMUM_PRIORITY (1) Thread Priority Manipulation Routines.
#define RTEMS_INLINE_ROUTINE
The following (in conjunction with compiler arguments) are used to choose between the use of static i...
Definition: basedefs.h:135
uint32_t Priority_Control
The following type defines the control block used to manage thread priorities.
Definition: score/include/rtems/score/priority.h:56
RTEMS_INLINE_ROUTINE Priority_Control _POSIX_Priority_To_core(int priority)
Convert POSIX priority to SuperCore priority.
Definition: priorityimpl.h:90
RTEMS_INLINE_ROUTINE int _POSIX_Priority_From_core(Priority_Control priority)
Convert SuperCore priority To POSIX priority.
Definition: priorityimpl.h:107
bool _POSIX_Priority_Is_valid(int priority)
Check if POSIX priority is valid.
Definition: psxpriorityisvalid.c:24
1003.1b-1993,2.2.2.80 definition of priority, p.
Definition: priorityimpl.h:54
