admin
rtems-admin.git
doxygen
builder
latest
rtems.git
telnetd
passwd.h
1
/* Define a default password for telnetd here.
2
* NOTES:
3
* - this can be overridden at run-time by setting
4
* the "TELNETD_PASSWD" environment variable.
5
* As soon as that variable is set, the new password
6
* is effective - no need to restart telnetd.
7
* - this must be set to an _encrypted_ password, NOT
8
* the cleartext. Use the 'genpw' utility to generate
9
* a password string:
10
11
* 1) Compile 'genpw.c' for the HOST, i.e.
12
* cc -o genpw genpw.c -lcrypt
13
* 1) delete an old password definition from this file.
14
* 2) run './genpw >> passwd.h'. This will append
15
* a new definition to this file.
16
17
* - if no password is defined here, no authentication
18
* is needed, i.e. telnet is open to the world.
19
20
* T. Straumann <strauman@slac.stanford.edu>
21
22
23
/* #undef TELNETD_DEFAULT_PASSWD */
24
/* Default password: 'rtems' */
25
#define TELNETD_DEFAULT_PASSWD "tduDcyLX12owo"
